Page 8 of 8 FirstFirst ... 5678
Results 71 to 80 of 80
  1. #71
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,975
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    Default Re: I think I really messed up new tractor
    Quote Originally Posted by jcliburn View Post
    This is how I made sure my QA never accidentally comes unlatched again.
    Looks like that would take the Q out of QA.
    The system isn't broken...
    ...it's fixed!
  2. #72
    Gold Member jcliburn's Avatar
    Join Date
    Apr 2009
    Posts
    278
    Lawrence County, Mississippi
    Kubota MX5100
    Quote Originally Posted by Short Game View Post
    Heh, good observation.
    I use it only when the grapple is attached. Before I added it, I kept getting big limbs and debris kicking up underneath and knocking a lever into the unlocked position. The first time it happened, the grapple detached from one side and bent the torque tube between the QA plates, just like the OP.
    No more.
    p.s.: I also added an expanded metal shield to the back of the grapple.
  3. #73
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,756
    Branson, Mo.
    Kioti DK35se Hydrostat
    You know when I first looked at your photo, I was thinking Wow! that takes all of the Q out of the QA. but then I realized that the shackles have a screw in pin not shown on the back side that takes you probably less than 15 seconds extra to hook up or disconnect as you only have to unscrew one to get both levers free. It is just that the photo is hard to understand at first since the screw part of the shackle is not showing.. Pretty cool
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  4. #74
    Join Date
    Apr 2009
    Posts
    278
    Kubota MX5100
    Quote Originally Posted by k0ua View Post
    James K0UA
    You're correct, James. It takes a few seconds to spin out the shackle screw and unhook one side. After unhooking, I usually just fish one end of the cable through the U-bolt and secure the loose shackle to the the other shackle when I'm not using the grapple. (Does that make sense?)
    It never occurred to me that one might think it was permanently locked down!
  5. #75
    Veteran Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    2,190
    Southern VT
    '10 Kioti DK 40se/hst
    Like the look of those cable clamps- are they something special- never seen anything but cable clamps with nutz and shackles before these...
    2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
    Scag Wildcat: Kawasaki 26HP.
    Bunch of STIHL chainsaws : 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
  6. #76
    Veteran Member kevinj's Avatar
    Join Date
    Jul 2003
    Posts
    1,302
    West MI
    BX-1860, L3940HSTC, B7500
    Quote Originally Posted by The Haymaker View Post
    Or it wasn't correctly seated/ locked.
    I only threw that out as I had a Markham bucket that would fall off due to being made wrong for the Kubota QA.
    Some have had the levers get knocked open and cause a problem.
    If you look at a Kubota QA you will see the top edge is rebated and if the attachment does not have full plate the attachment will set low and have about 1/2" of space underneath by the pins and then it can come off.
    I had to put a 1/2" x 2 1/2" bar stock onto my bucket to make it fit properly.
    Attached Thumbnails Attached Thumbnails I think I really messed up new tractor-5-17-2007-002.jpg   I think I really messed up new tractor-5-17-2007-005.jpg   I think I really messed up new tractor-5-17-2007-007.jpg   I think I really messed up new tractor-5-17-2007-006.jpg
    Kevin
    BX1860, mower, snowblower - B7500HST, FEL, Bush Hog - Grand L3940 HSTC, FEL, snowblower, 6' Landpride brush hog, 6' King Kutter tiller, Corn Pro 18+5 Fifth Wheel, 1950 Farmall M
  7. #77
    Join Date
    Apr 2009
    Posts
    278
    Kubota MX5100
    Quote Originally Posted by Coyote machine View Post
    A swaging tool would've come in mighty handy, but I don't have one.
    3/16" wire rope; appropriately sized thimbles; and a pair of these from Home Depot.
  8. #78
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,975
    Sunny SW Washington
    That is a nice clean clamp setup.
    ...it's fixed!
  9. #79
    New Member
    Join Date
    Jun 2011
    Posts
    23
    Spfld, MA - Corinth, ME
    (2)Simplicity 6216; JD 112: YM1702D: JD 420C
    Wow, I never saw so many posts to a problem in such a short time. I'm glad to see the problem resolved satisfactorally(sp?), with so many helpful comments. I've noticed some posts never seem to get any replied.
    I threw out a question recently, re my VTEK FEL w/a QA, wondering if there were any other attachments to fit, w/no replies.
    I have tried to lift a bundle of logs which almost dumped the tractor, as it was not on the level. I agree w/some of the other posters, that you must be very careful lifting a long log.
  10. #80
    New Member
    Join Date
    Mar 2010
    Posts
    6
    E. Tennessee (relocated from IL/MI)
    1971 JD 4020 Diesel, Kubota 3430
    [QUOTE=NCCrestonMtn;2648085]I tried to pic up a tree with my grapple that was apparently to heavy for my loader. It was about 30ft. I just wanted to pic one end up to make the sawing a little easier. I got it up to high...picked the tree up. It rocked a little then the right side loader quick connect popped off the grapple. The loader is pretty bent up. Take a look at the pictures and let me know if the tractor needs to go back to the dealer.
    Put a damper on the weekend!
    Fairly predictable. Need to keep loader loads evenly distributed and low to the ground. Here the uneven load coupled with height put a twist on the loader frame and apparently twisted the QA right out of the bracket on the grapple. QA has very little securing it to the grapple.
    Be very thankful someone was not hurt or killed.
    Common problem with small tractors & loaders -- very easy to overload. I'm guessing that grapple alone was 50% or more of rated load. I have Kubota L3400 with loader and I am very conscious of this issue. I've had a JD 4020D with a loader rated for much bigger tractor and there is a huge difference between these two units.
    I use a grapple on my Kubota LV75 and its incredible hydraulic lift keeps me cautious. As my dad used to say, "It doesn't take long to get hurt." And that applies to flesh, bone & steel.
Similar Threads
  1. Buying the first Test Tractor
    By JOHNTHOMAS in forum Kubota Buying/Pricing
    Last Post: 04-12-2013, 08:03 AM
  2. Bad Oil New Tractor
    By broker than broke in forum Buying/Pricing/Comparisons
    Last Post: 12-23-2010, 08:25 PM
  3. Tractor Failed To Start/White Gunk in Fuel
    By dmccarty in forum Oil, Fuel & Lubricants
    Last Post: 06-30-2010, 07:54 AM
  4. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 10:56 AM
  5. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
