Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
  1. #1
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default What to use for snow clearing?
    Okay so I have a back blade, box blade and snow blower, but what do I use to remove snow from a interlocking brick driveway. I don't want to wreck it after spending close to 45k on it. Idon't want to scratch it or hit an edge. For heavy snow the blower works fine but doesn't remove everything. I want it bare. Is a pto /power broom a good idea or is there something better?
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  2. #2
    Veteran Member JJZ 109's Avatar
    Join Date
    Feb 2009
    Posts
    1,884
    Near Lake Ontario
    Bobcat S185 skid steer - JD X394 - JD GT235
    Default Re: What to use for snow clearing?
    Quote Originally Posted by yelbike View Post
    Possibly rig some sort of hard rubber edge to your back blade?
    It probably looks marvelous during the non winter seasons, but would not have been my first choice.
    Time loves to be wasted. From that waste their is no salvage - Henry Ford
    _____________________________________________
    Also - 2017 Ford F250 Crew Cab. 6.2, Ingot Silver/Bobcat 709 backhoe/Erskine 73" blower /TSC QA boom pole/ Bradco 48" forks /CAM Superline 6x12 dump / (2) Kristi 7x18 enclosed trailers/PJ 4+16 14k tilt bed
  3. #3
    Platinum Member joeyd's Avatar
    Join Date
    Jul 2010
    Posts
    670
    North Idaho
    TYM 353HST
    Check the Snow Removal Forum, a lot of people bolt on a rubber edge to their blade and it works like a squeege on concrete/asphalt drives. I would think it would work the same on your driveway.
    Isa 43:2-3
  4. #4
    Join Date
    May 2011
    Posts
    826
    Trent Hills, ON
    Kioti DK40SE HST
    Urethane edge is what you would put on a truck plow. I guess you could put one on the back blade but it might be too light to make the urethane conform to the driveway.
    I've used a strip of car tire tread on the bottom of my ATV plow that worked well for a while on my rough rough gravel driveway. Probably the tread section of a high load rated pickup tire would last for years, but cutting it might be a challenge. I used a skil-saw for the car tires but it was all the saw could do and all I wanted to hold onto
    2011 DK40SE HST
  5. #5
    Gold Member GregbkH's Avatar
    Join Date
    Jun 2011
    Posts
    318
    Wisconsin
    2010 New Holland 3045
    Heated driveway.
  6. #6
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,251
    Central Ohio
    Kubota MX5100
    I have never had a need to try it, but I hear good results with using a piece of PVC pipe, with a cut lengthways, and slipped over the edge.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  7. #7
    Super Member
    Join Date
    Apr 2000
    Posts
    6,597
    central New York
    all makes and models
    Here in central NY we have many places that have gone to the power broom for that job. They will handle snow to the middle of the center axle and then it feeds over the top so a 24" diameter will normally handle snow up to ten inches without an issue.
    They do sweep it clean so even the cracks should come clean unless packed from traffic.
  8. #8
    Join Date
    Aug 2005
    Posts
    1,491
    Guernsey Co. Ohio
    Ford 3000, JD 2550
    I’m still trying to wrap my head around a $45k driveway.
    For lighter snow, the broom would work well. But, I’m guessing you see a lot of heavy snowfalls. The plastic/rubber cutting edge will work fine as long as the bricks are still fairly even. After a couple years, I doubt it works anymore. It’s just a hunch, but I don’t think it’ll be possible to get it completely clear of a heavy snow at that point.
  9. #9
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    For 45 grand for a driveway it should be heated AND serve beer!!!!
    Murph
  10. #10
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    I use a rubber edge but on my front blade. I am sure that you could do the same although on you back blade. I made my rubber edge out of a barn mat - very heavy rubber material about 1" thick. I left the steel cutting edge on, extended the rubber about 1.5" below the steel blade then added a 1/8 " plate on top to hold it tight.
    What to use for snow clearing?-image-1757597190-png
    I would guess that a polyurethane edge may be a bit too stiff and pull up some of your brick edges.
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
Similar Threads
  1. Rotary Cutter 60" or 72" Bush Hog for brush clearing with 40hp
    By IslandTractor in forum Attachments
    Last Post: 11-03-2011, 11:00 AM
  2. Tractor Sizing Kubota use from conservationand clearing then to farming
    By ih364 in forum Kubota Buying/Pricing
    Last Post: 10-19-2011, 07:47 AM
  3. Cost of clearing a path?
    By Blackhammer in forum Land Clearing Equipment
    Last Post: 07-05-2009, 08:04 AM
  4. Clearing progress, brush is evil
    By Highbeam in forum Photos
    Last Post: 05-04-2005, 11:44 AM
  5. Clearing project
    By Knute in forum Kubota Owning/Operating
    Last Post: 07-16-2003, 09:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
