Results 1 to 10 of 18
01-23-2012, 03:51 PM #1
HST Operation
I have (and love) a gear transmission. I was thinking about hydros the other day and I was wondering how they work. My lawn mower is hydro but it's pretty simple compared to what I imagine a tractor has. My questions are:
How do you manage to use steering brakes?
What purpose does the clutch serve?
Is the ability to go back/forth quickly hard on the drivetrain?
Do these things have gears driving the wheels like a gear tranny does and the hydraulics just control the ratio/power/speed?
I'm not looking to be "converted." These questions are just to sate my curiosity if anyone feels like educating me. A new tractor is out of the question right now, and I really like my gears anyway (always had standard-tranny cars and trucks -- I just really enjoy clutching and shifting and whatnot).Kubota L3540 HST
Kubota L4300 Gear *gone!*
Ford F-350 6.9L diesel
01-23-2012, 04:23 PM #2Platinum Member
- Join Date
- Feb 2008
- Posts
- 510
- Location
- Panther Lake, Oswego County New York
- Tractor
- Mahindra 2810 HST, Kioti DK35SE HST
Re: HST Operation
With a Hydro there is no clutch. You have 3 ranges. . .Low, medium and high range. Heavy pulling is usually done in Low range, Loader work for the most part and all other work, Medium range works good and High range is for transport.
Most Hydro's have 2 pedals on the right. Pedal on the left is forward and right pedal is reverse.Some have a "rocker pedal" with this style "toe" is forward and "heel" is reverse. The brake pedals are on your left side so using the brakes to help steer is possible, its just a matter of getting use to doing it with a different foot.
The best part of a Hydro, IMO is the ability to go quickly from forward to backward without drivetrain damage and operator fatuige. Great for loader work and rear mounted blowers. I am currently running 2 Hydro's with no problems what so ever. Hope this helps . . .John
Lord, Help me to be the man my dog thinks i am . . .John.
Mahindra 2810HST, 108H loader with Quick tach buckets and forks. Kioti DK35SE HST with loader, Hyd. top link and second set of rear remotes, 60" and 66" buckets, Kubota 900 RTV and a bunch of other good stuff
Buy more equipment, It makes life easier.!
01-23-2012, 05:26 PM #3Super Star Member
- Join Date
- Apr 2000
- Posts
- 11,418
- Location
- Lebanon,NH.
- Tractor
- Kubota L2800HST w/Frontloader & CC 2042
Re: HST Operation
On my Kubota brakes are the same side as F/R pedal...foot of pedal you slow to to stop.
HST for loader work and many rear attachments sure makes the job easier.
Cost for filters fluid will be tad higher $$$'s.
01-23-2012, 05:29 PM #4Bronze Member
- Join Date
- Aug 2010
- Posts
- 98
- Location
- Norman, OK
- Tractor
- Mahindra 3316HST
Re: HST Operation
Beg pardon...there is a clutch on my hydro; it's used for selecting ranges, and also for engaging or disengaging the PTO (clutch, engage lever, release clutch). I also have the brakes on the right, so split-braking (or any braking, really) is a challenge while driving forward. I suppose you could put your heel on the forward pedal and your toe on the appropriate brake. I've never done it, but I have flat, open land with no need to make sharp turns.
I love my hydro, but I would caution anybody to think carefully about using a hydro for mowing or other constant-speed jobs without a cruise control. I'd hate to be holding that pedal down for three hours. For loader work, though, there's nothing finer.
01-23-2012, 05:47 PM #5
01-23-2012, 05:58 PM #6Super Member
- Join Date
- Feb 2006
- Posts
- 6,753
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Re: HST Operation
An HST trans is basically a variable displacement pump driving a hyd motor. You control the pump displacement with the foot pedal. The top output torque of the trans is limited by the setting of an internal relief valve to govern the max pressure fed to the motor.
llllarryThis side of 40
JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
IH37 Baler, Hesston Haybine, JD Rake
Bushog, Flail,
SK Tilt Tatch
, KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
01-23-2012, 06:05 PM #7
Re: HST Operation
Not only will you find hours of "opinions" about gear vs hydro, you can even get lots of opinions about 2 pedal vs single pedal. here are my opinions, I like my single pedal best, but I think it is what ever you get used to. I have more hours on gear tractors than hydro. but I will never go back to gear. Hydro is just too convienant to use, and gives so much better control. I have not worn out my hydro yet going back and forth rapidly, and that is the majority of what I do.. Yes I second the motion for the cruise control if you were to mow long stretches with the hydro. Even my el cheapo Kubota has it. My hydro has a clutch, but it is only used as a safety switch to start the tractor, and to engage and disengage the PTO. You don't even need it when changing ranges, just make sure the hydro pedal is centered (neutral) and you are not moving. Some hydro tractors have no clutch, and do the PTO thing with an electrical/hydraulic button. My split brakes are on the right, not so good, but useable by using the cruise lever to maintain forward speed and using right foot to steer via split brakes. Or there is the Kubota/Ballet TuTu shuffle where you cross your legs and brake with your left foot, but since I look terrible in a TuTu, it's not for me. The range lever is a actual gear shift the hydro is in front of that driveline wise, and the final reduction gears are gears. I am not trying to convert you, but if you have never done loader work with a hydro tractor you have missed a major treat in life.
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
01-23-2012, 07:10 PM #8
Re: HST Operation
Thanks for the great answers guys.
TripleR, search on the iPhone app is my weakness. It doesn't let you narrow results in any way, so searching for HST operation will return any thread that has those words anywhere in it. Thank you for helping clear that up my questions. The various differences between manufacturers really confused me.
James, seeing your posts about HST in several other threads got me thinking about it. The far majority of my work is/will be mowing and hogging. Some loader work occasionally but so far I've only used it as a wheel barrow, moved a couple attachments, and knocked down and moved deadwood cluttering my woods trail. Seems like HST would be nice when trying to back up to attachments though. I do use the split brakes a lot but would probably be using cruise too in that case. Maybe someday when I get a new tractor I will look seriously at hydros.
Thanks for responding everyone, cleared up the confusion for me and made my break times much more enjoyable!
Kubota L3540 HST
01-23-2012, 08:04 PM #9
Re: HST Operation
Hey I noticed you are in SW Mo.. if you want to come by some time I live near Branson, and have a Kubota L3400HST, and a gravel pile.. You are welcome to come and try it for yourself if you want.
James K0UA
01-23-2012, 08:15 PM #10
Re: HST Operation
I have 700 plus hours on my gear 7510 and 47 hours on my HST B3200. I was of the opinion when I bought the 7510 that gear was better for mowing. I was WRONG. The HST allows me to slow the forward motion when I hit a rough patch easier than the gear. Would have to downshift or slip clutch. Mowing around objects is much easier. PTO stays the same speed when switching between forward and reverse motion. Not so with the gear. Most of my mowing is small in size so maneuverability is hugely important. The HST is way more maneuverable than the gear even though the latter is the smaller of the two tractors.
Cheers!Caution: Some of my posts may be politically incorrect.
Kubota B7510 & B3200
Similar Threads
1531, 1533 HST pedals
By Semipro in forum Massey Ferguson Buying/PricingReplies: 13Last Post: 10-21-2009, 07:26 PM -
CUT Model suggestions?
By curdy in forum Buying/Pricing/ComparisonsReplies: 14Last Post: 04-09-2009, 07:45 AM -
DK50SE HST
By froggy in forum Kioti Buying/PricingReplies: 10Last Post: 02-23-2009, 09:45 AM -
Grinding Sound !! - Dealer Says NORMAL
By MoyockHeel in forum New Holland Owning/OperatingReplies: 121Last Post: 02-11-2007, 03:38 PM -
Oil & Fuel CK20 HST oil overflowed at dipstick check
By malk315 in forum Kioti Owning/OperatingReplies: 1Last Post: 10-14-2006, 06:08 PM
