Results 1 to 6 of 6
02-17-2012, 07:28 PM #1
Pull Type BrushHog To 3pt
Well I'm done with using my pull type King Kutter brush hog, I'm converting it to a 3pt hitch, Here's some of my progress today. I flipped up the pull type frame and threw on the chain to lift it, I have a single tail wheel kit for the rear. But I was wondering with the toplink it slides under a steel support, it hooks fine but should I cut it off drill and put a pin in? Also is a Clevis hitch better or just a pair of cat-1 bolts?
Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
02-18-2012, 12:54 AM #2
Re: Pull Type BrushHog To 3pt
What are you going to use for lift frame going to the rear? If it going to be solid then use a clevis at the top link to allow for following ground contour. If the rear lift is flexible then the way you have it hooked should be fine. If it moves on the top hook more than you like you could just weld a piece of round stock to the old drawbar to fill up the hook hole some.
Dennis
CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
04-05-2012, 10:22 PM #3
I finished this a few weeks ago. But got to use it today! Long day today
04-06-2012, 08:33 AM #4Veteran Member
- Join Date
- May 2006
- Posts
- 2,074
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
Looks like you got it working really good. Can you show another close up pic of the mower? Looks like you went from the dual tail wheels to a single?
Nothing could be finer than riding my JD790 in South Carolina!!
2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, Leinbach PHD with 9" & 12" augers, King Kutter II 60" Rototiller, Leinbach middlebuster, Leinbach #11 Field Cultivator, boom pole, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
Nothing runs like a Deere, or smells like a John....
04-06-2012, 08:46 PM #5
Yes works whole lot better. The tail wheels before was for the pull type and were stationary, I only got 1 frame which was free, so I went with 1 tail wheel. I can get more pictures tomorrow, was gone all day today. Was backing up into 1-3 inch samplings and tractor didn't even know it. Not bad for a king Kutter,
04-06-2012, 09:38 PM #6
Here ya go. Went out with a flashlight, all it took was a weld on piece of angle iron and a hole to pivot on. The rest was all bolt on. I have a spring on to keep the chain out of the pto shaft when when theirs slack in it. Can use paint later but works great now
Similar Threads
Pull type combine - small grain recommendations
By JoeBiscuit in forum AttachmentsReplies: 18Last Post: 06-20-2012, 09:19 AM -
Rotary Cutter length of 8' pull type
By MikeF in forum AttachmentsReplies: 0Last Post: 05-20-2011, 10:16 AM -
disk new pull type 8 o 10 tires model makes please help
By ohio farmer04 in forum AttachmentsReplies: 8Last Post: 04-10-2011, 07:02 PM -
Sickle Bar 3 pt & pull type sickle mowers
By Builder in forum AttachmentsReplies: 11Last Post: 07-26-2009, 04:17 PM -
Rotary Cutters:3pth or pull type?
By scotd1 in forum AttachmentsReplies: 9Last Post: 05-27-2001, 07:54 PM
