Results 11 to 20 of 34
02-20-2012, 04:21 PM #11
Re: lynch pin help
I got mine at TSC also. They are not in their online catalog so maybe it is a store-by-store thing. The black ones are used on all CAT 2 implements.
Also, the bales only go one way for a secure hold. The flat side of the pin has to go against the implement or the bail is very weak. You may already know this.2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
2002 Kubota L48 TLB, 12", 18", 24" HD buckets
2001 Kubota BX2200, Turf, LA211 FEL
7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
02-20-2012, 05:10 PM #12Veteran Member
- Join Date
- Dec 2008
- Posts
- 1,278
- Location
- Up-State New York
- Tractor
- Grand L 3540 HST-3, R4's
Re: lynch pin help
He is your Friend, Your Partner, Your Defender, Your Dog. You Are His Life, His Love, His Leader. He Will Be Yours, Faithful And True, To The Last Beat Of His Heart. ...Unknown
02-20-2012, 05:12 PM #13Veteran Member
- Join Date
- Dec 2008
- Posts
- 1,278
- Location
- Up-State New York
- Tractor
Re: lynch pin help
02-20-2012, 05:13 PM #14Platinum Member
- Join Date
- Jan 2012
- Posts
- 933
- Tractor
- 2012 John Deere 3520 Deluxe Cab
Re: lynch pin help
i found that if you spray wd-40 or any other lubricant in these things no matter what brand you buy, they work very very well. I have even bought bulk packs where some of them arent working at all and a little wd40, they will work flawlessly with lots of bite. i suggest you try this.
02-20-2012, 06:14 PM #15Gold Member
- Join Date
- Oct 2008
- Posts
- 484
- Location
- Greensboro, NC
- Tractor
- Didn't intend to have a Deere fleet - it just happened
Re: lynch pin help
I've found some of the lynch pins have the tension of the spring backwards. I take the springs off and rebend them. Easy to do with a vise holding one end of the spring. Just need to pull the free end in the opposite direction till it works backward to the original direction. Then the pins will close like a rat trap.
02-20-2012, 07:21 PM #16Gold Member
- Join Date
- Oct 2003
- Posts
- 325
- Location
- Central Maine
- Tractor
- John Deere 4600, Craftsman YT4000
Re: lynch pin help
I'm "going green" - my "4-wheeler" is a John Deere 4600 HST!
02-20-2012, 11:07 PM #17Veteran Member
- Join Date
- Jul 2003
- Posts
- 1,993
- Location
- MN
- Tractor
- Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
Re: lynch pin help
There is also a bobby pin sort of looking type, or what you would put in the hole of a hitch pin. But big. Takes a hammer to put in & out.
There used to be special plow pins, curved washer sorta like the one guy makes in his picture, with a pin in it & a cotter key in the pin. the curve of the washer protects the cotter key. Likely these are hard to find any more.
I've also used giant cotter key. When you need to plow, and lost everything else, you rummage through the shop and - hey, I didn't even know I had cotter keys that fat!
Just some other options.
--->Paul
02-21-2012, 08:04 AM #18Platinum Member
- Join Date
- Jan 2011
- Posts
- 603
- Location
- Southern Ontario, Can
- Tractor
- New Holland 3045/2010
Re: lynch pin help
So you think that they are not breaking but coming unlocked?“If at first you don't succeed, you are running about average.”
M. H. Alderson
02-21-2012, 08:10 AM #19Super Member
- Join Date
- Nov 2011
- Posts
- 6,468
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
Re: lynch pin help
TSC has the cheap pins for a quarter a piece, I bought 5 bucks worth and will add chains to a set and throw the rest in the box on the tractor. Good idea?
Murph ------------ Sent from my HP laptop
Nothing runs like a Deere when being chased by a Kioti
02-21-2012, 08:22 AM #20Platinum Member
- Join Date
- Jan 2011
- Posts
- 603
- Location
- Tractor
Re: lynch pin help
Thanks for the replies! I think I will see if I can get the black jobbers and use pull ties as insurance.
M. H. Alderson
Similar Threads
DMM-60 Drive shaft to tranny input shaft roll pin (spring pin) gone
By malk315 in forum Kioti Owning/OperatingReplies: 6Last Post: 12-30-2012, 11:51 AM -
Hitch pin size
By Rathpr in forum AttachmentsReplies: 19Last Post: 03-14-2011, 10:45 AM -
12 pin to 6 pin attachment connector
By overseas in forum Bobcat Construction EquipmentReplies: 1Last Post: 02-18-2011, 03:02 AM -
Hitch Pin Wear
By wkpoor in forum Trailers & TransportationReplies: 5Last Post: 09-29-2009, 10:08 AM -
Lynch pin
By RedRocker in forum Kioti Owning/OperatingReplies: 10Last Post: 10-07-2008, 11:25 PM
