Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
  1. #31
    Veteran Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    2,042
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: lynch pin help
    Quote Originally Posted by Zebrafive View Post
    I am thinking the lock pins that hold the lift link pins to my lower 3pt arms have a ring that you have to turn to release, like a split ring. I'll check my tractor and report back.
    Pins do have a split ring, hole in each end of ther pin, you thread the split ring thru the end hole to keep the pin in. JD part number AL114597
    Attached Thumbnails Attached Thumbnails lynch pin help-clip-010.jpg   lynch pin help-clip-009.jpg
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  2. #32
    Platinum Member bironacad's Avatar
    Join Date
    Jan 2011
    Posts
    603
    Southern Ontario, Can
    New Holland 3045/2010
    If you look at the image in the first post you will see not all lynch pins are created equal, lol, I like the idea of threading it through a hole but this was not an option with the pins I have been able to obtain.
    “If at first you don't succeed, you are running about average.”
    M. H. Alderson
  3. #33
    Silver Member gaproperty's Avatar
    Join Date
    Dec 2010
    Posts
    169
    Kubota 4740
    Default
    HOw to loose linch pins blowing snow! I believe how it happens is..... We all hit things (curbs etc...). Because to many of the blowers are attached to a 3 pt hitch arms with a pin that is not a clevis style. The pin sticks out from one side mount of the blower, as apposed to a clevis mount, bends with a hit and abrupt stop. After the pins bend every force there after forces the arms off center thus putting pressure on the linch pin. Metal fatigue acts on the linch and eventually breaks.
  4. #34
    Join Date
    Jan 2011
    Posts
    603
    Quote Originally Posted by Short Game View Post
    Get the high powered black ones. But look out for them. They will bite you both opening and closing them.
    Did a couple of days of Bush Hogging with no problems using the Black Lynch Pins, thanks!
    M. H. Alderson
Similar Threads
  1. DMM-60 Drive shaft to tranny input shaft roll pin (spring pin) gone
    By malk315 in forum Kioti Owning/Operating
    Last Post: 12-30-2012, 11:51 AM
  2. Hitch pin size
    By Rathpr in forum Attachments
    Last Post: 03-14-2011, 10:45 AM
  3. 12 pin to 6 pin attachment connector
    By overseas in forum Bobcat Construction Equipment
    Last Post: 02-18-2011, 03:02 AM
  4. Hitch Pin Wear
    By wkpoor in forum Trailers & Transportation
    Last Post: 09-29-2009, 10:08 AM
  5. Lynch pin
    By RedRocker in forum Kioti Owning/Operating
    Last Post: 10-07-2008, 11:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
