Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Gold Member
    Join Date
    Mar 2010
    Posts
    253
    East Texas
    Default Re: Pulling over trees...
    Quote Originally Posted by lastborn View Post
    Wyobuckaroo, I want to hear more about that tree popper. Do you know where the link is?
    Thanks
    Here you go. I thought I had a picture of one in use but could not find. The choker attaches to the tree.
    I save some of the old smaller tires. I then clip them to a chain, cable or rope when pulling. If it gives, the tires will help bring it down.
    Attached Thumbnails Attached Thumbnails Pulling over trees...-1a-jpg   Pulling over trees...-1b-jpg
  2. #22
    Join Date
    Apr 2012
    Posts
    67
    Southwest MO
    Kubota L4200-GST 4WD
    I have a 5ft Bucket that was bent by heavy round bales on a spike, after putting the bucket in the stump are you using the curl of the Loader to straighten it or moving the tractor?
    Quote Originally Posted by SuperCobra View Post
    I thought I would show a couple of pictures on how you can straighten a bent bucket by putting it in the stump. To bend the bucket, repeat the process in the other direction!
  3. #23
    Elite Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    3,198
    Beaver Dam Wisconsin then to Hohenwald, TN
    John Deere 3720
    Quote Originally Posted by pat32rf View Post
    You have never seen a chain under tension break! Few people have because the chain moves faster than your eye can follow...
    Interestingly, I have. I had my 10K winch on my truck tied to a couple small trees and the back of the truck tied to a tree to keep it locked down. The choker chain was a smallish one and not to good of shape but I was really working the winch with about 20 feet extended yet. The choker popped and started flying toward the truck about 5' in the air and I just reached up and snagged it before it hit the truck. Certainly lucky but next time I am using a heavier duty choker.
    JD 3720 with R4s and bulldozer capabilities.
    X740
    13 Millimeter = 1/2"--------25 Milimeters=1"-----------100 Millimeter = 4"----------1 Meter = 40---------1 Kilometer = 3300' or 5:8 ratio
    A 13mm will but will be just slightly larger than a 1/2" nut.
  4. #24
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    1,994
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by Deere Dude View Post
    Yes to the heavier chain. But your truck getting smashed is way preferable to your hand being torn off. Next time, get the heck outta the way. If you haven't seen the video of a ship's anchor chain breaking that Mace(?) posted a while back, go search for it. You'll never grab at it again.
  5. #25
    Join Date
    Aug 2007
    Posts
    149
    Spotsy, VA
    NH TC40DA
    Quote Originally Posted by stonypass View Post
    I was curling. If you stick it in too far (or not far enough) you might end up with an additional bend.
  6. #26
    Join Date
    Apr 2012
    Posts
    67
    Southwest MO
    My bend is worse at the leading edge of the bucket, but there is some further back as well. Guess I should not put the edge too far into the stump and work slowly.
  7. #27
    Join Date
    Jul 2004
    Posts
    1,986
    Bancroft, Ontario
    JD4300
    Just took another look at that broken strap. Did it break where the hook was wrapped around the tree and hooked back onto the strap????
  8. #28
    Join Date
    Jan 2008
    Posts
    2,347
    Western PA
    John Deere 5083E MFWD, Kubota L3400 HST
    Quote Originally Posted by ETpilot View Post
    Anybody every try the bi-pod idea? looks like its pretty time consuming to set up/PITA but it might work well?
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR)
    JD 550 Dozer 6 way blade and winch
    JD 450B Track Loader
    Case 480C Backhoe W/ Extend-a-hoe
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    ''08 700R Raptor
Similar Threads
  1. Trees Really Do Grow!
    By Gale Hawkins in forum Rural Living
    Last Post: 02-03-2012, 04:45 AM
  2. Box Scraper Want to uproot scrub trees and vines
    By skiprt in forum Attachments
    Last Post: 05-18-2011, 11:47 PM
  3. Pulling Trees and Saplings
    By SandburRanch in forum Land Clearing Equipment
    Last Post: 12-04-2010, 06:22 PM
  4. Pruning the Olive trees
    By rox in forum Rural Living
    Last Post: 02-09-2007, 06:24 PM
  5. Suggestions for removing Flowering Pear trees
    By jdgreg in forum Projects
    Last Post: 04-20-2006, 12:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
