Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    New Member
    Join Date
    May 2009
    Posts
    20
    Wisconsin
    JD X320
    Default Rock buckets
    Anyone run a rockbucket on 2320/ 2520 deere or Kubota equivalent or are they even capable of handling one? Are there better ways with dealing with rocks? ....... in my neck of the woods they seem to grow better than just about anything else . Hope to have my first compact tractor next year and this info would be helpful.
  2. #2
    Join Date
    Oct 2011
    Posts
    1,829
    Monrovia, California
    Kubota BX25
    Default Re: Rock buckets
    Not the pro am I but at 2. acres do you really want to spend that cash?
    What if you made a crude screed / a sifter , set it in the middle, sift away, haul away rocks and respread clean fill ?
    Post pics of the property!
    Regards,
    Artisan
    Kubota 2012 BX25 (23H.P. / 17.7pto)
    14' Dump / Carson 12K Tow Trailer w/ movable Winch,
    Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
    Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
    Stayin' Alive (This click could save a life...)
  3. #3
    Join Date
    Dec 2002
    Posts
    1,922
    Foster, RI
    JD 750
    Quote Originally Posted by jc21 View Post
    Smallest rock bucket I've seen is made by Paladin. They have a 51" bucket that weighs around 270 Lbs. Not sure how you are planning to use this as scooping and grubbing rocks out are two different situations. Vernig makes a bucket that looks strong enough to grub rocks out but their smallest weighs over 500Lbs. If you are going to grub rocks as opposed to scooping, a 3 point attachment such as a middle buster comes in way more handy to pop rocks out. It would be helpful to know how you need to work these rocks.
  4. #4
    Join Date
    Apr 2010
    Posts
    975
    Quote Originally Posted by arrow View Post
    ^^ he makes a good point. Makes sense to use a combo of a rear implement to run over the land and pop out the pop-able rocks and a bucket to scoop them for relocation. Rock buckets are heavy and you will severely limit the size of rock you can then pick up. Sort of a catch-22 situation!
  5. #5
    Veteran Member Jerry/MT's Avatar
    Join Date
    Feb 2008
    Posts
    1,806
    Western Montana
    New Holland TD95D, Ford 4610 & Ferguson TO-30
    I live at what was once the bottom of Glacial Lake Missoula and our ranch is loaded with great topsoil that it studded with rock fragments from the size of a Volkswagen on down. These fragments were torn from the Mission mountains by huge glciers during ancient ice ages and were floated out over the lake when these glaciers "calved" and were deposited by melting or by the repeated draining of the lake during the cataclysmic floods that formed the chaneled scablands of Eastern Washington.
    The picture below gives you an idea of the medium size rocks we have to deal with. This one is too big for the trackhoe to pick up so a hole was dug that would put the upper surface of this rock three feet below grade and then it was pushed into the hole. Not easily seen in this picture is the the small rock fragments, 10 inches or less. Anything less than about 3-4 inches we don't deal with on the large scale. These small rock fragments are generally hand picked and removed in gardens and flower beds but in the pasteiures 3-4 inch rocks are rolled down after seeding.
    We are reclaiming an old pond, ~100 ft in diameter, and if were not covered by 5-6 inches of fresh snow I'd show the rocks we have there. After disking the area three times, I handpicked the 1 foot to 2-1/2 ft rocks and carried them to the ditch with the loader, one of our rock "storage" locations. Next, I used our Ferguson TO-30 and a 5 ft landscape rake (that I reinforced!) and windrowed the rocks. I only broke three tine bolts! (IF I had a rock bucket, this is when I would use it to scoop the windrows to remove the rocks. They are not designed to grub rocks out of the ground.) I will then use the rake to make small piles of thes windrows that I can scoop up with a loader bucket. we will then seed the area, put hot wire fence around it to keep the cows out and have a neighbor roll the remaining rocks down.
    Some folks use rock pickers to get these smaller rocks picked but we can't justify the expense of this piece of equipment. We have resisted "farming up " some of our pastures because of these rock issues. We are going to try frost seeding and some other techniques to improve the pastures, taking more time and using less $'s.
    I don' have any idea of your rock problems or how you intend to use a rock bucket, Certainly one would be handy on our place but were looking at close to $2000 plus shpg for a 7 footer with 3 inch spacing and it's just not in the budget.I thought about making a "screen to sift rocks out and that might be a possibility but it would probably cost as much as rock bucket just for the steel.
    I hope this give you some ideas for how you might deal with your rock problems
  6. #6
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    546
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    Gotta know, was the excavators thumb able to hold the ROCK while it was put in the truck?
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  7. #7
    Join Date
    Feb 2008
    Posts
    1,806
    Western Montana
    Quote Originally Posted by Mark Page View Post
    No that's why he's burying it! We had about four of them that had to be buried. Too big to pick up. the cat was able to move some toward the ditch or a fence line.
    If you need any rocks for landscaping you can have all you want for frree. Just come get 'em.(Grin)
  8. #8
    Join Date
    Apr 2010
    Posts
    975
    Quote Originally Posted by Jerry/MT View Post
    So, free is not the "installed price"?
  9. #9
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,665
    central Wisconsin
    Kubota B7800
    I have one on my B7800 and it does just fine. It is not a sifter but a manipulator/lifting bucket. I checked the specs on the 2320/ 2520 Deere and they are comparable. If you get the right attachment for what you want to do you will be happy. In the end what you can actually do with your attachment should equal what you want to do with it.
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  10. #10
    Join Date
    Feb 2008
    Posts
    1,806
    Western Montana
    Quote Originally Posted by Ford tractor View Post
    Ya' got that right! The rocks are free, shipping and handling are extra.
Similar Threads
  1. Gravel Driveway Questions
    By cdhd2001 in forum Projects
    Last Post: 04-21-2007, 02:21 AM
  2. Double duty rock tooth bar ?
    By bcarwell in forum Attachments
    Last Post: 02-11-2007, 06:10 PM
  3. MILONZI ROCK BUCKET
    By flINTLOCK in forum Attachments
    Last Post: 02-05-2007, 08:25 AM
  4. Front-End Loader Rock bucket toothbar FEL attachment ?
    Last Post: 01-21-2007, 09:00 PM
  5. Waterfall & more rock walls
    By Richard in forum Photos
    Last Post: 09-01-2001, 10:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
