Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    6
    huntsville alabama
    JD 4310
    Default 3 point hitch Draw Bar
    Hi Guys, new to the form (and tractors)and thought I would start out with a question. I want to pull a farm trailer that has a ball reviver with my JD 4310 and I was thinking of getting one of those bars that goes between the 3 point hitch and put a ball on it. Is there anything wrong with this or is there anything I need to know?
    Thanks
    Damon
  2. #2
    Veteran Member jlsmith's Avatar
    Join Date
    Aug 2010
    Posts
    1,263
    Murchison, Tx.
    MF 285 Long 560 MF2670 CX100
    Default Re: 3 point hitch Draw Bar
    That's what I use and it works fine.
  3. #3
    Join Date
    Jul 2011
    Posts
    920
    Central wisconsin
    International 2500a
    that will work,that's what i do
  4. #4
    bcp
    bcp is online now
    Join Date
    Jul 2009
    Posts
    2,232
    SW WA
    Kubota BX2360
    You need something to keep it from rotating when pulling or braking.
    Bruce
  5. #5
    Join Date
    Jul 2003
    Posts
    1,993
    MN
    Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
    The simple bar wants to rotate, and will put some stresses on the trailer hitch, as it rotates fore & aft. They make clips that go one one end to keep the bar from rotating, or better yet is the type like this site sells, that has a vertical bar and uses the top link, with a reciever hitch tube so you can put in a ball hitch, pin hitch, etc. It keeps the hitch level and stable at all times.
    The other issue is a safety issue. If the trailer gets tail-heavy, or you come down a steep hill and try to stop, the 3pt hitch can rear up and slam upwards pretty badly, damaging something or jacknifing the tractor or at least startling the heck out of you. Best to use a short chain from the 3pt hitch to the regular drawbar to limit the upward movement of the 3pt hitch.
    --->Paul
  6. #6
    Join Date
    Jan 2012
    Posts
    933
    2012 John Deere 3520 Deluxe Cab
    this is the cheapest setup i found instead of using just a draw bar. i bought one and so did a few others on here. just an idea for you.
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    also, what RAMBLER said, i chain is a good idea to make sure the 3pt hitch doesnt suddenly jump up with a offset load. Heres what i did with the ebay hitch. put a grade 8 bolt in the rear with chain
    Uploaded with ImageShack.us
    Uploaded with ImageShack.us[/
  7. #7
    Super Star Member jinman's Avatar
    Join Date
    Feb 2001
    Posts
    18,751
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    The attachment is the proper setup for a 3PH drawbar with a ball. Just remember if you put in the drawbar stays to the toplink bracket, don't go changing your 3PH lever to a higher setting. Doing that will test your relief valve and may bend the stays. The blue bracket on the left side in this photo is a common way of keeping the drawbar from rotating. Notice it has a cutout slot for the drawbar stay and will only work on the left side.
    Jim
  8. #8
    Join Date
    Aug 2005
    Posts
    1,020
    Guernsey Co. Ohio
    Ford 3000
    The cheapest and easiest way is to just put a ball on the swinging draw bar.
  9. #9
    Join Date
    Jan 2012
    Posts
    756
    Ma
    Kubota b2920
    I've got one that is a triangle shape and connects to the lower arms and top link and has a 2" receiver in the bottom center. Its got cross bracing making it very heavy and strong and that gives a place to hook safety chains if you've got them. You can raise and lower it with the 3pt so you can just back up to something, hook it on, move it and then drop it again without having to leave your seat. I believe it went for about $150 at the dealer.
  10. #10
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,711
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Mine is somewhat similar in design to shortthrow5 except that my lower horizontal cross bar is a 300 lb elevator weight that is my ballast as well.
    Best of all worlds!
Similar Threads
  1. 3 point receiver hitch (completed)
    By pharmvet in forum Projects
    Last Post: 10-13-2011, 09:42 PM
  2. 1715 3 point hitch
    By Kosmo in forum New Holland Owning/Operating
    Last Post: 10-06-2011, 09:32 PM
  3. Agco ST30X 3 point hitch bleeding down
    By swamptiger626 in forum Hydraulics
    Last Post: 09-22-2011, 11:32 PM
  4. is there a drawbar lock for telescoping 3pt arms
    By dirtbikekid1090 in forum Attachments
    Last Post: 08-28-2011, 11:11 PM
  5. Do I need a 3 point quick hitch?
    By PapaPerk in forum Attachments
    Last Post: 08-13-2011, 10:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
