Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Gold Member
    Join Date
    Jul 2008
    Posts
    482
    near Williamsburg ,Virginia
    TC 35 New Holland and 52 Case VAC,LT25 Woodmizer logmill
    Default Re: Using a 3 PH Aerator
    If you just disconnect your solid top link,your aerator will float and follow the contours of the ground. The chain application as your top link will give the option to raise the aerator while making a tight turn. Of course ,ya have to have enough slack in the chain so the implement will float,yet short enough so you can raise the tines slightly off the ground. Experiment. No chain? Make big wide gentle turns.
    I have a 60" woods plug aerator. I really have to get the aerator off the ground when making a tight turn or risk breaking some of the spoons which are rather hard and brittle steel. Somehow I know this happens.
  2. #12
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    Quote Originally Posted by nspec View Post
    I must be missing something. You just put the lever all the way down and it will just follow the contour of the ground. You don't lower your implement until it touches the ground and leave the lever in that position. Doing that will not allow your 3 pt hitch to lower any further. This is normal and you will not cause any damage. You are simply setting the lower limit of the range of travel as the implement floats along with the contour of the land.
    In my first post that was covered. The BX has a self-centering lever. When the 3PH is lowered the lever returns to center when it stops lowering. That locks in the setting.
    The trick is to do something that will keep the lever forward (down) like it is designed on most tractors.
  3. #13
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    Quote Originally Posted by Carykong View Post
    I'm not sure what the OP's aerator looks like or how it operates but if a chain (or nothing) was used on one of mine the top of the implement would likely pivot on the lower pins and smash into the tractor.
  4. #14
    Join Date
    Mar 2010
    Posts
    82
    VA
    JD 1026R
    I guess I'm still (like others) missing something though. You be able to keep "lowering" (as far as the control is concerned) the 3pt long after the implement has touched the ground. This will not lower the implement more of course, but it will lower the lowest point the 3pt will allow the implement to settle to. This will allow it to follow contours.
    I understand you don't have position control, my old 2305 used to work the same way. The way I was taught to think of 3pt is not to think of the 3pt lever as controlling the height of the implement, you are always only controlling the lowest the implement can go. The implement can always ride up.
    If the problem is that the implement can't settle far enough to follow terrain no matter how you run the lever then you have a different issue, which is that the 3pt just doesn't have enough range of motion. The only simple way to help in that case would be to disconnect the top linkage while running, which would allow the implement to pivot down somewhat further... Of course you would have to get off the tractor to hook back up in order to raise when turning. A more involved solution might be possible too, if you have plenty of ground clearance with the implement raised and have access to a welder you could move the attachment points upward on the implement... giving you depth when down at the cost of clearance when up.
    Hope this helps,
    Hunter
  5. #15
    Gold Member
    Join Date
    Jul 2008
    Posts
    482
    gwdixon, you make a good point. when you said "I'm not sure what the OP's aerator looks like or how it operates but if a chain (or nothing) was used on one of mine the top of the implement would likely pivot on the lower pins and smash into the tractor."
    Some experimentation and country engineering may be called on here. How about a rigid bar/pipe attached to the aerator where the top link is normally attached extending to one of lower arms to keep the aerator from pivoting and tumbling? The chain will still come in handy if ya want to raise the aerator without having to dismount.
  6. #16
    Silver Member MoreCowbell's Avatar
    Join Date
    Jun 2010
    Posts
    123
    Clayton, NC
    Kubota BX2350
    I think using a chain for the top link would work great if the aerator was the type that extended relatively far from the hitch. I use a chain for a dethacher that is configured like that and it "floats" nicely.
    Unfortunately, I build my aerator so that it is right up against the lower link pins (see attached photos). A top link chain would result in the aerator rotating quite a bit.
    I think I like the idea of a bungee or a hook to hold the 3PH lever down to create the float behavour. Thanks for all the replies.
    Attached Thumbnails Attached Thumbnails Using a 3 PH Aerator-aerator1-jpg   Using a 3 PH Aerator-aerator2-jpg
  7. #17
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,009
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by MoreCowbell View Post
    Wow MoreCowbell. I just picked up an aerator last night that looks exactly like this one, except it is pull type. For now. You've given me a fantastic look at what could be done. Thanks!
  8. #18
    Join Date
    Jun 2010
    Posts
    123
    Clayton, NC
    Kubota BX2350
    RaydaKub,
    We probably have the same aerator. I bought mine a couple weeks ago on sale from Northern Tool. If you need better pictures of what I did to modify it, let me know.
    I also made a couple of concrete weights that rest in the tray. The tray seems to be sized for standard size concrete blocks but there is not room to fit enough blocks. I was shooting for 150 lbs. Since a cubic foot of Quikrete weighs about that amount, I formed two 15'x14"x4" blocks. The whole setup works real nicely.
    -Rob
  9. #19
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    If you'd bought a MF with draft control and lowering speed your problem would be solved. I turned the garden over yesterday with a middle buster.
    Each trench is the same as the on before.
    Other than Massey I'm not sure if anyone makes tractors with this feature any more.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  10. #20
    Join Date
    Sep 2011
    Posts
    2,009
    Rochester, MN
    Kubota BX2230
    RaydaKub,
    I don't know if we do or not. I bought mine off craigslist, it's an Agri-Fab I think, but your normal carry wheel operation appears to be backwards from mine based off the lock pin.
    I'd like to come up with some way to use the 3ph, either to mount or to lift it, but retain the pull type so my neighbor can feel free to borrow it as well.
    I got 25-10lb plates from a universal gym last fall. I put 16 of the plates on mine and that worked pretty well. I usually have them bolted in groups of 6 to a 24" drawbar for rear weight for FEL work. Thought I might have to fasten them somehow, but they just laid there.
Similar Threads
  1. Yanmar Models
    By Neat 1500 in forum Yanmar
    Last Post: 07-19-2017, 06:53 AM
  2. 3-Point Hitch 3 PT Tiller
    By Stormtruck2 in forum John Deere Owning/Operating
    Last Post: 12-31-2010, 11:01 AM
  3. Aerator Conversion to 3 pt Hitch
    By dsails380 in forum Customization
    Last Post: 12-08-2010, 10:18 PM
  4. 3 ph cycling up and down
    By Gary Fowler in forum Yanmar
    Last Post: 09-26-2010, 05:48 AM
  5. Bought a core aerator
    By NoTrespassing in forum Attachments
    Last Post: 05-04-2005, 03:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
