Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Silver Member MoreCowbell's Avatar
    Join Date
    Jun 2010
    Posts
    123
    Clayton, NC
    Kubota BX2350
    Default Using a 3 PH Aerator
    I just finished converting a pull style aerator to work with the 3PH on my kubota BX2350. Since my yard is not perfectly flat, the hitch rides up and down as the aerator rolls on the ground.
    My problem is when the aerator needs to go lower to keep contact with the ground, the 3PH doesn't let it since it was not lowered to that point. I suppose I could just keep the lever pushed down to keep the hitch completely loose, but I'm wondering if anyone has a better idea. Maybe swap my lift links with chains to allow the lift mechanism to completely drop?
    Thanks.
  2. #2
    Join Date
    Nov 2011
    Posts
    122
    Alabama
    John Deere
    Default Re: Using a 3 PH Aerator
    I converted a cultipacker from pull to 3pt. Opposite problem, can't lift as high as I want. If you don't have enough adjustment in lift arms to get low as you want, can you move pins with much trouble? That's what I'm going to do.
  3. #3
    Join Date
    Jun 2010
    Posts
    123
    Clayton, NC
    Kubota BX2350
    Thanks for the reply. I actualy do have the downward travel needed to get the aerator as low as I need. My problem is a little different (and awkward to explain). If I lower the 3PH to allow the aerator to fully engage the ground, that works fine until the ground starts to tilt downward. At that point, the 3PH starts to lift the aerator off the ground as the tractor pitches down.
    I suppose what would be perfect is a float position on the 3PH valve. That would allow the aerator to have its full weight on the ground at all times. I guess the best I can do is sort of a poor man's float by keeping the lever pushed down while aerating.
  4. #4
    Join Date
    Nov 2011
    Posts
    122
    Alabama
    John Deere
    I understand. Can you post pic of your set up? Like to see what everyone else is doing.
  5. #5
    Gold Member
    Join Date
    Jul 2008
    Posts
    482
    near Williamsburg ,Virginia
    TC 35 New Holland and 52 Case VAC,LT25 Woodmizer logmill
    disconnect your solid top link and use a chain instead
  6. #6
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    If I understand correctly, the problem is that the 3PH lever on the BX is the self-returning kind that lowers the 3PH and then automatically centers the lever. This holds the 3PH in the set position rather than letting it float.
    Then when you go over a rise the aerator/3PH will maintain its position and the tines will clear the ground. In a dip the tines are fine since the 3PH floats with upward force on it.
    I have read posts of folks using a bungee cord to hold the lever in the down position. This doesn't seem to put the hydraulic pump in a bind like holding the lever in the up position.
    On my BX there is a return rod near the right tire that can be adjusted so the lowering lever will not automatically return to center. Moving the lever and looking from the rear will indicate the lever. There is a spring and a couple of nuts on the rod.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  7. #7
    Join Date
    Dec 2011
    Posts
    726
    nc PA.
    kubota rtv900: kubota mx5200
    Quote Originally Posted by Carykong View Post
    very good idea. just like letting a snow plow float on the road surface.
  8. #8
    Gold Member
    Join Date
    Jul 2008
    Posts
    383
    Maine
    Kubota B2410, Kubota B7100Dt, Kubota B7100HST
    I do not understand how using chain for a top link will let the implement drop any more than a standard top link.
  9. #9
    Join Date
    Dec 2011
    Posts
    726
    nc PA.
    Quote Originally Posted by KubotaSam View Post
    if the problem is when the front of the tractor starts down a hill, the back end of the tractor will actually start to point more up towards the sky, thus lifting his aereator off the ground. the top link would then actually pull tight and lift it up. however if that top link was not there, the 3ph aerator would just pivot off the two lower links. just like float. in a way you could just disconnect the top link when aerating and then when done, get on level ground and reattach the top link to lift for transport. you are right. i guess the chain would not be necessary.
  10. #10
    Platinum Member nspec's Avatar
    Join Date
    Dec 2007
    Posts
    624
    Southern Rhode Island
    Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
    Default
    I must be missing something. You just put the lever all the way down and it will just follow the contour of the ground. You don't lower your implement until it touches the ground and leave the lever in that position. Doing that will not allow your 3 pt hitch to lower any further. This is normal and you will not cause any damage. You are simply setting the lower limit of the range of travel as the implement floats along with the contour of the land.
Similar Threads
  1. Yanmar Models
    By Neat 1500 in forum Yanmar
    Last Post: 07-19-2017, 06:53 AM
  2. 3-Point Hitch 3 PT Tiller
    By Stormtruck2 in forum John Deere Owning/Operating
    Last Post: 12-31-2010, 11:01 AM
  3. Aerator Conversion to 3 pt Hitch
    By dsails380 in forum Customization
    Last Post: 12-08-2010, 10:18 PM
  4. 3 ph cycling up and down
    By Gary Fowler in forum Yanmar
    Last Post: 09-26-2010, 05:48 AM
  5. Bought a core aerator
    By NoTrespassing in forum Attachments
    Last Post: 05-04-2005, 03:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
