Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
  1. #11
    Silver Member catskinner's Avatar
    Join Date
    May 2010
    Posts
    139
    SE MI
    AC 170
    Default Re: air compressor
    hockey pucks makes good mounts when bolting to the floor.
  2. #12
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,042
    Jacksonville, Florida
    JD2555
    Raspy nailed it right! CFM is the question that needs answering!
    I had a compressor for sale that a friend was interested in, but he bought a "bigger one" from the box store. He couldn't run his impact wrench with the new one for a complete set of tires (doing a tire rotation)without having to wait on it to build up. He came over with his impact and we did my truck tires with that air compressor and it never even slowed down. He ended up buying mine and hooking the two up in tandom. He uses the cheap one for airing up tires and such, and mine (or both of them together) when he needs some serious air.
    The size of the tank has very little to do with the performance of the unit as a whole.
    David from jax
    A serious accident is one that money won't fix.
  3. #13
    Join Date
    Feb 2012
    Posts
    541
    sioux city, ia
    Oliver 1855, Case 1840, Cub 1550
    I have a IR 60 gal 2 stage, bought new in 1987, works great, no problems and is still on pallet. Makes it is easy to drain tank. I installed 2' lenght of 1/2" hydralic hose and plumbed garage with 1/2" galvanized pipe, sloped down hill back to tank. I use IR synthetic oil. A two stage will give you 150 psi +, and single stage 125 psi max. Be sure to get enough CFM, check max use on your tools.
  4. #14
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    35,097
    Texas
    That used to be correct, and as a general rule still is, but there are exceptions. I've had this Industrial Air by Coleman PowerMate for over 6 years. It comes on at 125 psi and kicks off between 150 and 155 psi running on 120 volt.
    And prices have sure gone up. I paid $536.08, including sales tax, at Northern Tool in Sept. '05. But Northern Tool doesn't have these anymore.
    Bird
  5. #15
    Platinum Member Raspy's Avatar
    Join Date
    Dec 2006
    Posts
    757
    Northern Nevada
    NH TC29DA Bolens G14 Skytrac 5028 Dodge Cummins Jeep Rubicon Grizzly 700
    Larry,
    230 volts at 15 Amps is only 4.6 horsepower. If that is the "max" it can draw it must be full locked rotor amps, not running amps. So it's more likely about 3 horsepower.
    More important information is the cu ft output at 90 PSI.
    Overstated horsepower figures are common in the industry.
    Another clue is to look at the motor plate and see what it says. If it says SPL, it means it's less than advertised on the compressor spec sheet. If it says 5 Horsepower, it means 5 running horsepower.
    People should buy the biggest compressor they can afford and have power to run, for a shop, or match the output in CFM to the tool they want to operate. 18 CFM at 90 psi will comfortably run a 12 CFM tool at 90 psi, etc.
    And single stage compressors will generally put out more CFM in the practical working range, than two stage compressors. Two stage is for working pressures over about 130 lbs.
    I just hate all the misleading advertising that goes on.
    John
    I only exaggerate enough to compensate for being taken with a grain of salt.
  6. #16
    Join Date
    Mar 2000
    Posts
    35,097
    Texas
    John, after some class action lawsuits, some of the exaggerated horsepower ratings came way down, although I'm no sure they all came down far enough. You know I once had a "3.5 hp" oilless Craftsman by DeVilbiss and they later went to labelling the same compressor as "4 hp". And now I think they're rated at 1.6 running hp. I also used to have this same model Puma air-compressor when they were labelled as "6 hp". The dealer told me at that time that they called them an "imitation 6 hp" and showed me one of their actual 5 hp motors that, of course, was much larger. I see the Puma is now labelled as 3 hp and I'm not sure that isn't still exaggerating a bit.
    Bird
  7. #17
    Join Date
    Dec 2006
    Posts
    757
    Northern Nevada
    Bird,
    Exactly.
    Have you seen the 6 HP shop vacs that run on a 15 amp 120 volt circuit? I think they take the gallon size of the barrel and call that the HP. It would be OK if nobody believed them, but................oh well.
    John
  8. #18
    Join Date
    Mar 2000
    Posts
    35,097
    Texas
    Quote Originally Posted by Raspy View Post
    Bird,
    Exactly.
    My 12 gallon Craftsman shop vac is labelled as a 5 hp. You don't think that's an exaggeration, do you?
    Bird
  9. #19
    Platinum Member westbrooklawn's Avatar
    Join Date
    Apr 2005
    Posts
    641
    North Carolina
    kubota L3400HST
    The specs on the Eaton compressors look very good, and the 5 year unlimited warranty is exceptional. Another thing I like about their website is that they give db ratings for their compressors. Their $541 single stage is 74db (pretty quiet), and 11.2 cfm at 90lb. That seems like a lot of compressor for the money, however shipping isn't include so that may drive the cost up considerably. Does anyone have experience with these compressors?
    3 - 25 HP Air Compressors : Piston Air Compressors for Sale : EatonCompressor.com
    L3400HST, L463 FEL, Markham toothbar, Markham Grapple, Woods BH80-X, 5 1/2' United box blade,6' Leinbach scrape blade, Pallet forks, 5' King Kutter RM, 56" First choice tiller, Leinbach rake
  10. #20
    Super Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    5,255
    Texas -from the brush and pear to the piney woods
    110 TLB
    Best you can get: Rolair.
    Rolair Systems
    "“The budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed lest Rome becomes bankrupt. People must again learn to work, instead of living on public assistance.” Cicero — 55 BC
    Obama= Jobs lost by the thousands, reinvented by the hundreds.
    The Second Amendment. Defender of the rest.
Similar Threads
  1. Harbor Freight Tools that don't suck
    By Travelover in forum Parts/Repairs
    Last Post: Today, 04:11 AM
  2. TSC Job Smart air compressor
    By RichZ in forum Related Topics
    Last Post: 02-14-2013, 10:18 PM
  3. IR 60 gal Air Compressor oiled
    By Alan L. in forum Related Topics
    Last Post: 09-21-2011, 07:53 PM
  4. air compressor repair
    By retiredmgn in forum Welding
    Last Post: 04-30-2011, 07:15 PM
  5. Air Filters??
    By RadarTech in forum Kubota Owning/Operating
    Last Post: 06-25-2010, 02:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
