Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 79
  1. #21
    LD1
    LD1 is online now
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,469
    Central Ohio
    Kubota l3400
    Default Re: I think my tail wheel is too big
    Quote Originally Posted by RoyJackson View Post
    You would think that would result in ether the weld pulling or binding of the tail wheel...
    If just the shaft is bent, how would that bind the wheel? And if it was welded properly, you could bend that shaft in a circle and still not break the weld.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  2. #22
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    15,669
    Bethel, Vermont
    John Deere 4400 MFWD
    Quote Originally Posted by LD1 View Post
    I'm writing about the shaft the wheel/fork assembly pivots around. I would think that would have bent some when (and if) the previous owner backed into something...according to the OP, it seems to pivot easily.
    Just conjecture on my part.
    Roy Jackson
    A fear of weapons is a sign of retarded sexual and emotional maturity...
  3. #23
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,060
    Ontario, NY
    Kubota BX24
    Not necessarily...
    The link is to a Land Pride cutter operator's manual. It should open to page 44 (which shows the tail wheel bracket):
    http://www.landpride.com/ari/attach/...s/312-849p.pdf
    And here's the actual pic I pulled from the manual. The picture shows the tail wheel fork canted back from the factory
    Roy- I agree its should be canted- but with the canted angle AND bent shaft just contributes to the rubbing.
    take a look at the pics I posted
    Attached Thumbnails Attached Thumbnails I think my tail wheel is too big-tail-wheel2.jpg
  4. #24
    Join Date
    Nov 2001
    Posts
    15,669
    Bethel, Vermont
    Quote Originally Posted by radioman View Post
    Yeah, I saw that when you first posted the pics..even enlarged the pic to get a closer look.
    As I wrote previous, I'm still thinking the tail wheel assemble may have come from a another cutter (looking at the differences in the paint weathering. Speculation on my part.
    So, I wonder how Mike (the OP) is going to fix it?
    Roy Jackson
  5. #25
    Elite Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    3,423
    Los Angeles / SW Washington
    PowerTrac 1850
    Zebra has it right. The assessment of the photo close up is an optical illusion. Take a look at the cant at the top of the shaft. It matches the cant at the bottom. Add to all of this the subtle fish eye effect of the lense and while there might be a subtle tweak on the wheel it is not what is causing the binding. The wheel looks to be from an old deer implement.
    Carl
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
  6. #26
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,062
    Somewhere north of Roseau,MN
    Fordson Major Diesel, Ford 1510, John Deere L111
    Mike, perhaps you should pull the wheel/caster assembly out so you can actually see the whole shaft? They come off real easily and that would answer your question as to whether it's bent once and for all. Hard to diagnose what you can't see.
    Joe
    Ford 1510
    Du-Al 105 Loader
    "The Thumb" Grapple
    Bush Hog RBC60 Rear Blade
    Woods HC54 Rotary Cutter
    Tarter 5' Heavy-Duty Hinge Back Box Blade
    Buhler Farm King Y600 Snowblower
  7. #27
    Super Member
    Join Date
    Feb 2006
    Posts
    6,754
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by aczlan View Post
    IMO,it is the vertical shaft that is bent.
    The washer in the green box should be parallel to the ground and the bottom of the vertical tube, not at an angle to them.
    Attachment 260572
    Aaron Z
    Yes. Astoundingly obvious. Yet we have debate.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, Hesston Haybine, JD Rake
    Bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  8. #28
    LD1
    LD1 is online now
    Join Date
    Apr 2008
    Posts
    7,469
    Central Ohio
    Kubota l3400
    Quote Originally Posted by SPYDERLK View Post
    larry
    And even if it is a "different wheel" and is "supposed" to be bent like that (which I doubt), the obvious solution is to heat up the shaft, and bend it so it wont rub. Problem solved very simply. Who cares what the wheel is off of or wether it is "actually" bent or not. Just modify it to work. Its not rocket science
    Ford 5500 Backhoe
    JD 261 3PH mower
    Dolmar 7900
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  9. #29
    Join Date
    Jun 2010
    Posts
    1,062
    YES!!!
    Joe
    Ford 1510
    Du-Al 105 Loader
    "The Thumb" Grapple
  10. #30
    Veteran Member Depmandog's Avatar
    Join Date
    Nov 2010
    Posts
    1,304
    Buckner MO
    2005 Kubota L5030 GST; Farmall 706
    Default
    Yup, what I said twenty posts ago. It's a ten minute fix.
    Do get yourself a flexing top link. I had this EXACT problem on a used land pride that came with my tractor. Original owner was using a solid top link and bent the tail wheel on some humps. I fixed the tail wheel, got a 4' piece of 1/4" chain and two clevises. Replaced the top link with chain with a clevis on each end and it works like a charm. Total cost - less than ten bucks.
    Dean
    "Get busy living, or get busy dying" - Morgan Freeman in "The Shawshank Redemption"
Similar Threads
  1. steering wheel spinner knobs
    By ninefinger in forum Customization
    Last Post: 03-10-2011, 07:11 PM
  2. Bush hog tail wheel not pivoting?
    By Kenfyoozed in forum Parts/Repairs
    Last Post: 06-23-2010, 10:52 AM
  3. Global Warming News
    By KB9UDE in forum Rural Living
    Last Post: 03-11-2010, 08:06 AM
  4. Howes Brush hog tail wheel
    By okie350 in forum Parts/Repairs
    Last Post: 05-29-2009, 07:55 AM
  5. Farm Force 'xb' cutter - tail wheel question
    By 44trxfun in forum Attachments
    Last Post: 06-11-2008, 08:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
