Results 21 to 27 of 27
06-06-2012, 11:43 AM #21
Re: suitcase tractor weights
Those concrete weights are clever! Thx.
NorCal M5
2006 New Holland TC34DA
06-06-2012 11:43 AM # ADS
06-06-2012, 12:25 PM #22Gold Member
- Join Date
- Jul 2007
- Posts
- 466
- Location
- Ohio hill country
- Tractor
- 2006 TC45A
06-06-2012, 01:22 PM #23Platinum Member
- Join Date
- Mar 2012
- Posts
- 793
- Location
- SW New Hampshire
- Tractor
- Bolens G154/IsekiTX1300F
The suitcase weights come in just under 200lbs, and then I have both front tires loaded, so about 300+ lbs. It has made all the difference in the world. I use to have my front end in the air all the time, and now I have not had that happen once, and I feel so much more stable. I am still careful, but it is a huge help!
Mitch
06-06-2012, 01:30 PM #24
06-06-2012, 03:46 PM #25Gold Member
- Join Date
- Jul 2007
- Posts
- 466
- Location
- Ohio hill country
- Tractor
- 2006 TC45A
2006 TC45A
06-10-2012, 08:03 AM #26Silver Member
- Join Date
- Jun 2010
- Posts
- 193
- Location
- N. Mississippi
- Tractor
- Ford 1510
My problem is not so much the front end popping up in the air as it is skidding as a make a turn. Will the weights help with that? The concrete is a good idea and so is the rotor. I wonder about combining them?
___________________________
1986 Ford 1510
5' Bushhog (no name version)
5' Finish Mower
26 gal Femco 12v trailer sprayer
2000 52" Great Dane Surfer (18hp Kohler Command)
________________________________
“Being a wealthy redneck has its advantages...”
Willie Robertson, CEO Duck Commander
The decisions you make will determine whether you win... or lose.
06-10-2012, 01:28 PM #27Platinum Member
- Join Date
- Mar 2012
- Posts
- 793
- Location
- SW New Hampshire
- Tractor
The weight should drastically improve that issue. It sound like your tractor is just pushing forward and skidding because you do not have enough weight for the front tires to contact the ground adequately for proper turning. I would try adding the weight and go from there. The weights that sound guy developed should give you more than adequate weight and they will not rust. I like the rotor idea, but you have to worry long term rusting, and corrosion. I would give it a try, and if you want, combine the two, but either way it should solve you problem. Suitcase weights run about one dollar a pound to purchase, and that adds up very quickly. I bought mine, however any future weights are going to be the cast concrete type that sound guy made. Let us know what you end up doing, and if it helps..
Originally Posted by MikeA57
Mitch
Similar Threads
Ballast Anyone have suitcase weights on a DK?
By IslandTractor in forum Kioti Owning/OperatingReplies: 10Last Post: 12-05-2007, 01:12 PM -
Ballast Suitcase Weights
By Ductape in forum YanmarReplies: 20Last Post: 03-11-2006, 02:23 PM -
By Lt74 in forum Cub Cadet Yanmar & CUTsReplies: 29Last Post: 11-11-2005, 08:52 PM -
Use universal "suitcase" weights on Kubota
By Dargo in forum CustomizationReplies: 23Last Post: 01-09-2005, 09:04 AM -
SUITCASE WEIGHTS
By WALT in forum AttachmentsReplies: 8Last Post: 05-24-2002, 01:22 PM
