Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    1
    sebewaing mi
    framall
    Default suitcase tractor weights
    looking for small suitcase weights
  2. #2
    Administrator
    Join Date
    Mar 1998
    Posts
    9,052
    San Diego, CA
    None currently
    Default
    Welcome to TBN.
    Muhammad Chishti
    Administrator
  3. #3
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,432
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: suitcase tractor weights
    Lowes has 42 pound suitcase weights for $51.00. Welcome aboard. You didn't state what application that you were going to use the weights for.
    The PUPIL who does not surpass his Master, fails his Master.
  4. #4
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,517
    NE Oklahoma
    MF 230 and Mitsubishi D2000
    Welcome to the forum from Oklahoma.
    Ken
    Massey Ferguson 230
    Mitsubishi D2000
  5. #5
    Veteran Member moored4's Avatar
    Join Date
    Jan 2011
    Posts
    2,368
    Great NorthWest /Southwest Washington
    Kubota l245dt, l3540, 8N
    to TBN!
    Happy ing!
    "keep them pots black, shiny, and full of good Food and Fellowship!"
    Moore Cookie
  6. #6
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,042
    Jacksonville, Florida
    JD2555
    I have three tractors that came with weights and I removed all of them from two of the tractors. After some serious headlights looking at the stars, I kind of wish I could put all of the weights on that one tractor. After all it only has about 1300 pounds sitting on the nose of the tractor and it isn't enough!
    All three tractors take completely different weights, not even close to each other, so they aren't interchangable.
    David from jax
    A serious accident is one that money won't fix.
  7. #7
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,074
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    can cast em out of concrete for cheap!
  8. #8
    Platinum Member NHmitch's Avatar
    Join Date
    Mar 2012
    Posts
    761
    SW New Hampshire
    Bolens G154/IsekiTX1300F
    I just bout some from Tractor Supply, they have to order them. They were about $49.00 a piece, and when they arrived, I found that they were made from heavy plastic coated concreate with metal reinforcements. They area great. I didn't think that I would like them, but they do not rattle, they do not rust, and they are very heavy duty. You can find weights at Homedepot, or Lowes, for about $1-$1.50 a pound. A dealer may be about the same, or a bit more. If you want to save money, get a large ammo can, put bolts through it that will attach to your tractor, and fill it with concrete. You can paint it to match your tractor, or leave it green. It might save you a few hundred dollars.
    Mitch
  9. #9
    Join Date
    Mar 2002
    Posts
    42,074
    Central florida
    why waste the can? use a small bathroom sized garbage can as a from, spray it with a release agent ( pam? ) cut some hole / slots for the mounting bolts to stick out.
    use som 8" carriage bolts.. bend them so they are a stiffener and extend into the crete.. use extra wire or rod if needed. use duct tape to seal the form. pour, let set.. pop out.. make another... 2$ form.. no wasted ammo can.. save it for ammo!
    I pour my own weights.. them paint em black.. looks just like cast iron!
  10. #10
    Join Date
    Mar 2012
    Posts
    761
    SW New Hampshire
    Soundguy,
    Thats a great idea, I did use a large ammo can, and I thought that I would need it to hold the concreate together, but that sounds like it will work great. I think that I may try that next, the pam works to get the can off after you pour the concreate? What do you use, quickcrete? Thanks!
    Mitch
Similar Threads
  1. Ballast Anyone have suitcase weights on a DK?
    By IslandTractor in forum Kioti Owning/Operating
    Last Post: 12-05-2007, 01:12 PM
  2. Ballast Suitcase Weights
    By Ductape in forum Yanmar
    Last Post: 03-11-2006, 02:23 PM
  3. Ballast Suitcase Weights
    By Lt74 in forum Cub Cadet Yanmar & CUTs
    Last Post: 11-11-2005, 08:52 PM
  4. Use universal "suitcase" weights on Kubota
    By Dargo in forum Customization
    Last Post: 01-09-2005, 09:04 AM
  5. SUITCASE WEIGHTS
    By WALT in forum Attachments
    Last Post: 05-24-2002, 01:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
