Results 1 to 4 of 4
04-27-2012, 02:32 PM #1Bronze Member
- Join Date
- Dec 2003
- Posts
- 94
- Location
- Northern VA
- Tractor
- Bobcat CT235
30 gallon Fuel Caddy - Change fuel - Cleanout?
I just picked up a 30 gallon fuel caddy off of Craigs list. It was used with gasoline and I want to use it to fuel up my Bobcat. I have drained out all of the gas and have the bottom drain hole open along with the refill opening. I plan on leaving them open a day to 'dry' out the insides.
Do I need to do anything else to 'clean it out' before I pour in Diesel and use it to fuel up my tractor?
04-27-2012, 04:40 PM #2Elite Member
- Join Date
- Sep 2010
- Posts
- 2,972
- Location
- 35 miles North of Memphis,TN
- Tractor
- kubota L3000dt, ford 8n1952
Re: 30 gallon Fuel Caddy - Change fuel - Cleanout?
IMHO, it looks good to me, the way you have done it..Ymight give it a lite rinse and shake with a little diesel and dump it in a jar for a look see?
Okay, Legal disclaimer: Old but not senile, definitely do not have the answer to everything!
04-28-2012, 11:28 PM #3
Every so often there will be a news story about the state police going to ski areas and ticketing bus drivers because they are adding gas to their diesel because they bought fuel down "south" without anti-gel and now it's gelled up. My point is that a little gas is not going to hurt anything, if you let it evaporate then you'll be fine. The only thing I would look for is any dirt or debris inside the tank and remove it.
Kubota L4240,Case 580K backhoe, Case 450 Dozer
04-29-2012, 12:55 AM #4Super Member
- Join Date
- Feb 2008
- Posts
- 7,738
- Location
- somewhere usa
- Tractor
- stuff
I agree with crazyal, make sure you get any trash or sediment out. A little gas isn't going to hurt anything.
Similar Threads
Oil & Fuel Ford 5600 fuel system trouble?
By klw5600 in forum New Holland Owning/OperatingReplies: 5Last Post: 02-02-2013, 02:42 PM -
Oil & Fuel Fuel problems (algae)
By rxk9394 in forum Kubota Owning/OperatingReplies: 13Last Post: 01-08-2010, 04:36 PM -
minimum size tank for off road fuel
By automech in forum Oil, Fuel & LubricantsReplies: 28Last Post: 10-15-2008, 02:17 PM -
Oil & Fuel Fuel Filter Change - Fuel Spill
By bcarter in forum Kubota Owning/OperatingReplies: 5Last Post: 12-08-2004, 10:19 AM -
Oil & Fuel Fuel Filter Change - Opinions?
By buckle97 in forum Kubota Owning/OperatingReplies: 20Last Post: 04-04-2004, 11:30 AM
