Results 1 to 10 of 14
04-27-2012, 07:58 PM #1New Member
- Join Date
- Apr 2012
- Posts
- 17
- Location
- pueblo west co
- Tractor
- jd 3320/cat 242 skid steer
4 wheel dr
hello
just bought a jd 3320 4x4
just one question how do you put it in 4wheel dr
i put the leaver in the up position ,its the leaver just above the e brake the lite on the dash lites up, but the front tires dont move
any idea thanks
04-27-2012, 08:44 PM #2New Member
- Join Date
- Apr 2009
- Posts
- 24
- Location
- LaPorte, IN
- Tractor
- JD 3120
If the 4 wheel drive indicator is lit, you are in 4 wheel drive. Not sure what you mean. Are the front wheels locked up, skidding while the rear wheels turn? Have you checked the front axle for fluid level? Be sure the tractor is in gear (e hydro range selector is easy to disengage). Let us know how it turns out. The 3x20 series are great machines.
JD3120, 300xFEL, 1060BB, 447BH, Woods PR8400 RFM
04-27-2012, 10:44 PM #3New Member
- Join Date
- Apr 2012
- Posts
- 17
- Location
- pueblo west co
- Tractor
Re: 4 wheel dr
when i raise the front end up ,and go forward or backwards the front wheels dont move when in 4 wheel dr. aren't they suppose to turn
thanks
04-28-2012, 01:43 AM #4Platinum Member
- Join Date
- Sep 2009
- Posts
- 546
- Location
- Maryland
- Tractor
- Massey Ferguson 2615 48hp, 4wd, loader
Re: 4 wheel dr
Are you saying they drag? AS I'm new to 4wd tractors, but something sounds very wrong. Do they turn when your in 2wd?
Gear Up and Throttle Down.
2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
04-28-2012, 11:56 PM #5New Member
- Join Date
- Apr 2012
- Posts
- 17
- Location
- pueblo west co
- Tractor
Re: 4 wheel dr
hello,
yes they roll back in forth , but when i lower the bucket down, an raise the front end off the ground and move forward & back in 4x4 the wheels dont roll
they should roll when in 4x4.
talked to the john deere dealer an he's going to take a look at it
i checked the 4x4 leaver an it's moving, the lite on the dash is lit when i ingage the 4x4
thanks
04-29-2012, 04:46 AM #6Veteran Member
- Join Date
- Jul 2003
- Posts
- 1,993
- Location
- MN
- Tractor
- Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
Re: 4 wheel dr
Yea, think you are on to something there, if everything is right they should be turning when up in the air....
--->Paul
04-29-2012, 05:48 AM #7Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Re: 4 wheel dr
Are you looking at both sides? They are not positract so only one side may be turning. With the wheels lifted and 4 WD engaged , can you hold one side so it doesnt turn and then turn the other wheel by hand? If you can then something is not engaged properly.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
04-29-2012, 11:27 AM #8Veteran Member
- Join Date
- Jul 2004
- Posts
- 1,553
- Location
- Bancroft, Ontario
- Tractor
- JD4300
Re: 4 wheel dr
Put it in 4wd and lift it so ONE wheel only is in the air, then try to turn it by hand. If it will spin, then you have a problem.
04-30-2012, 02:12 PM #9New Member
- Join Date
- Apr 2012
- Posts
- 17
- Location
- pueblo west co
- Tractor
Re: 4 wheel dr
find my problem broken driveshaft ,
thanks
04-30-2012, 02:14 PM #10New Member
- Join Date
- Apr 2012
- Posts
- 17
- Location
- pueblo west co
- Tractor
Re: 4 wheel dr
not a cheap repair i take it, just put a call into the place i bought it from
thanks guys
Similar Threads
Yanmar Models
By Neat 1500 in forum YanmarReplies: 14Last Post: 02-24-2012, 10:15 PM -
Tires Converting tires on Yanmar 1500D
By benhood in forum YanmarReplies: 32Last Post: 08-01-2011, 09:21 AM -
Dual Brakes on an HST tractor
By Lockport in forum Owning/OperatingReplies: 65Last Post: 07-06-2011, 10:58 AM -
4 wheel dr disengages???
By hjarrett in forum Kubota Owning/OperatingReplies: 8Last Post: 08-07-2010, 01:50 PM
