Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Gold Member deezler's Avatar
    Join Date
    Jan 2012
    Posts
    457
    Southeast MI
    Cub Cadet 7305
    Default Re: CUT/SCUT fuel consumption?
    ^ That's actually a pretty good argument. Engines are inherently more efficient when operated closer to full throttle (less pumping losses past a partially closed throttle plate) except that with modern fuel injected engines, they enrich the A/F ratio as you approach full throttle to keep the piston and exhaust gas temperatures lower (safer). In short, it can be complicated.
    After ~40 hours put on my new Cub Cadet 7305 CUT, I am amazed with the rate of fuel consumption. Seems to be about 0.5 gals/hr, even when brush hogging or dirt digging. Awesome stuff. Well, except that I always assume the tank is low enough to hold a full 5 gallon jug, and then over full it and dump diesel all over my tractor. Doh!
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Join Date
    Jun 2010
    Posts
    1,276
    Southern California
    International Harvester 284, Yanmar 1401D, Yanmar 240
    Quote Originally Posted by deezler View Post
    ...Engines are inherently more efficient when operated closer to full throttle (less pumping losses past a partially closed throttle plate)...
    The diesels in our tractors don't have a throttle plate, though. But still, generally, it will be more efficient to run a lower powered engine at high fractional power loading than a high powered one at a lower setting.
    Let's say I have a load that will take about 10 horsepower to run. I have a choice of my diesel IH 464 or my gas IH 284, rated about 45 and 25 PTO horsepower respectively. The presumption would be the diesel engine would use less fuel, since it is diesel, and, with such a light load, will loaf along. The data show differently. (Attached is the 464 test; the 284 test is above)
    The 464 burns 1.4 gallons per hour to make that power, and is producing 7.18 horsepower-hours per gallon. The gasoline 284 burns 1.3 gallons per hour to make little more power-12 horsepower, and makes 9.07 horsepower-hours per gallon of fuel. Running the big diesel at 44 PTO horsepower, though, burns only a little over 3 gallons per hour, more than quadrupling the power for a little over twice the fuel consumption, and it produces 14 horsepower-hours per gallon of fuel.
    This shows the importance of having well-matched implements and tasks to one's machine. It would be more efficient to run a heavier load on the bigger machine than it would to let it loaf in front of an undersized one. With that said, there are many other contributing factors to overall efficiency, but in purely mechanical terms, it is generally more efficient to operate at a higher percentage of output than less.
    Attached Thumbnails Attached Thumbnails CUT/SCUT fuel consumption?-ih464-test-page-002.jpg
  4. #23
    Platinum Member bigdad's Avatar
    Join Date
    Feb 2006
    Posts
    598
    West Central Illinois
    Kubota B7510
    Quote Originally Posted by RaydaKub View Post
    Yeah, I think my cousin said his 400hp Ford takes 450 gallons to fill up and he does it every other day in spring or fall work. At $4 a gallon, that'll get your attention in a hurry. As compared to my BX that I've had for almost 9 months and have burned through about 15 gallons total.
    It's a question to be answered for curiosity sake, but hardly relevant.
    Does your cousin fill at the pump?
  5. #24
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    1,053
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by bigdad View Post
    No, he buys bulk. The land he farms stretches about 15 miles and he just has a truck come out to where ever it is.
  6. #25
    Join Date
    Feb 2006
    Posts
    598
    Kubota B7510
    He has to pay four bucks a gallon bulk? I pay that at the pump here in Illinois. Guess I don't have it that bad.
  7. #26
    Join Date
    Sep 2011
    Posts
    1,053
    Rochester, MN
    Kubota BX2230
    Well, that was quoted in an off-hand way a year or 2 ago. I guess if you take the road tax off and add the sales tax, it probably comes down to $3.75. And he uses enough for his grain trucks that it probably all feels the same. Even so, 450 gallons at $3.75 would still get your attention every 2 days.
  8. #27
    Super Member JDgreen227's Avatar
    Join Date
    Nov 2003
    Posts
    6,737
    Central Michigan
    4210 MFWD Ehydro--'89 JD 318
    I put about 90-95 hours a year on my deere and about 80% of that is mowing which I have calculated as burning close to .625 gph @ $4 per gallon which is about $240 a year. For the amount of work my tractor accomplishes for that much cost for fuel...heck, my NEWSPAPER costs more a day than my Deere does to operate and the paper doesn't put a big s*** eating grin on my face when I open up the barn and admire my toy...
    Attached Thumbnails Attached Thumbnails CUT/SCUT fuel consumption?-023.jpg
    Always be willing to admit your shortcomings, there is no shame in not knowing how to do something. The shame is in NOT admitting you don't know how to do it.
    If you have a small truck, limit yourself to small loads, if you want to carry the big stuff, get a big truck.
    Never be ashamed of making a mistake. The only people who never (bleep) up are people who never try to do something new.
  9. #28
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    3,868
    SW Pa.
    Massey Ferguson GC2400
    My Massey GC2400 is using just about .5 to .6 gph also. That's mowing, tilling, or snow removal.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  10. #29
    Join Date
    Feb 2011
    Posts
    1,743
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    allis chalmers CA, primary used for mowing. put 5 gallons of gas in it. and turn on the PTO to get the blades spinning, and then adjust between 1,2,3 rd gear (out of 4 gears) for getting a good cut at fastest speed. figure approx 0.75 to 1 gallon an hour. i forget how many acres, but figure about 7 gallons of gas for 7 to 8 acres worth of finishing mowing. pending on how tall grass is, and gear i can place tractor in, that means any were from 3 to 4 hours to 6 to 9 hours seat time.
    ford 555c TLB, loader work
    put 10 gallons of diseal in it in the morning, and about 6 to 10 hours later i am near empty again. normally loader work, digging in a pile of dirt and then going as fast as can between places dirt needs to go.
    backhoe work, if my body is able to keep up. i am around 3/4ths throttle. and going like crazy. i see less desial usage. i am not actually using that much power, and just wanting the higher GPM of hyd oil to the cylinders. and may get 14 to 20 hours of work time out of 10 gallons of diseal.
    it has been way to many years since a riding lawn mower been used here on the farm. but i want to say they used more gas, and took long to mow than the allis chalmers CA tractor takes.
    Ryan
Similar Threads
  1. Oil & Fuel DieselAdditive
    By Piperflyer in forum Owning/Operating
    Last Post: 06-23-2011, 11:35 AM
  2. Oil & Fuel Diesel additive or not?
    By Jeffery8mm in forum Mahindra Owning/Operating
    Last Post: 05-14-2009, 10:54 PM
  3. Oil & Fuel 2305 fuel consumption
    By SI2305 in forum John Deere Owning/Operating
    Last Post: 09-23-2006, 04:20 PM
  4. Oil & Fuel Fuel Consumption
    By gduff in forum Kubota Owning/Operating
    Last Post: 07-02-2004, 10:37 PM
  5. Oil & Fuel Which fuel should I use
    By DDT in forum Owning/Operating
    Last Post: 02-02-2003, 08:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
