Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,424
    Tucson AZ
    New Holland TC-45
    Default Re: OUT DARN STUMP!
    Quote Originally Posted by AGGIE00 View Post
    Don't quite understand not using full rpms. Just feather the controls when you need to finness the bucket.
    Generally speaking smaller back hoe units move much quicker than their big brothers.
    On my little guy 1,200 to 1,300 works out just fine. Big guys use brute force, in my case it is more of finesse.
    On top of that, less noise and less fuel.
    ::"I STARTED out with nothing....I still have most of it."
    New Holland TC45 1,300+ hours - FEL - back hoe - post hole digger - Hydraulic Gannon - cement mixer - pressure washer - 1975 Dodge 500 flat bed - 1974 chevy C65 6 yard dump truck.
    All home made by me. loading forks - 2 drags - roller - Sheep's Foot - Pusher (to unload flat bed truck.) - pickle fork digger - Log splitter -
  2. #12
    New Member
    Join Date
    Apr 2009
    Posts
    24
    LaPorte, IN
    JD 3120
    Great photo! Congrats on the new tractor and hoe. I have a similar setup (3120 with 447 backhoe) and have removed over 20 stumps up to 16" in diameter. So much fun I started pulling stumps for neighbors! LOL. Got paid a little, too.
    Like most, I found out the hard way that low RPM's work better. Same power, just slower movement. The little hoe can cut through up to 4" roots if you get the curl right on the the bucket. Once you learn how, you can take out average 15" stumps in an hour or less. What a tool!
    Enjoy, and stay safe.
    JD3120, 300xFEL, 1060BB, 447BH, Woods PR8400 RFM
  3. #13
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I always hated cherry picker operators who crammed the throttle to the floor everytime they moved the cable even if it was just to pick up a small item. They claimed they got better control (BS is what I say) just lots of noise and waste of fuel and damage to the engine when you are not looking for speed no need to run 3K rpm when idle will do.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  4. #14
    Member Dogtrainer's Avatar
    Join Date
    Apr 2012
    Posts
    49
    Browns Valley,ca
    JD 3320
    Stump 2 has been safely removed. I find that like the controls on the tower truck at the fire department, moving over and down controls at the same time slows the action of both motions.
    Getting better!
    Only your DOG really knows who you are. Pray it never learns to talk.
  5. #15
    Silver Member paulemar's Avatar
    Join Date
    May 2011
    Posts
    117
    Pittsburgh, PA
    Kubota BX25, 60" MMM, 3 point hitch
    Default
    Aren't you glad that you don't have to hire someone else to do that for you? Or even worse, dig it up by hand!
    BX25, "60" MMM, 3 point hitch, Brinly 12" cat 0 1 bottom plow, TSC Countyline carry all, Kubota ballast box, 4X4 Loyal drag harrow, BXpanded Piranha tooth bar, Bro-Tek rear skid plate, Bro-Tek wheel spacers, Bro-Tek backhoe ripper tooth. Kubota BX2763A front plow, Phoenix T4 48" rototiller, Harbor Freight Quick Hitch, BXpanded Quick-on Work light Kit.
  6. #16
    Join Date
    Apr 2012
    Posts
    49
    Browns Valley,ca
    JD 3320
    Quote Originally Posted by paulemar View Post
    Oh yes! I've dug out 1 stump in my life many years ago. NEVER AGAIN!
Similar Threads
  1. Floating a Tree Stump with a B3030
    By WaxMan in forum Kubota Owning/Operating
    Last Post: 09-03-2012, 08:31 AM
  2. Stump removal
    By wedge40 in forum Projects
    Last Post: 07-07-2009, 05:16 PM
  3. Stump Removal and Brotek Ripper
    By spk64 in forum Kubota Owning/Operating
    Last Post: 11-11-2008, 08:00 PM
  4. Tree Stump Killer
    By koziol41 in forum Rural Living
    Last Post: 03-24-2007, 03:06 PM
  5. Replies: 58
    Last Post: 10-26-2006, 09:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
