Results 11 to 19 of 19
05-29-2012, 12:33 PM #11
Re: Rotary Cutter Selection Assistance
If the OP doesn't intend to cut grass and needs to operate in woods and between rocks, I'm wondering if this might be a good job for a rough cut flail mower? Where is Leonz when you need him? Not sure if mulchnig sapplings is an appropriate job for a flail.
That's the problem with trouble.
It always starts out as such fun."
- Randall Brown
05-29-2012 12:33 PM # ADS
05-29-2012, 01:00 PM #12Silver Member
- Join Date
- Feb 2004
- Posts
- 134
- Location
- Southwest Louisiana
- Tractor
- L4740
I recently purchased a Bush Hog 285 (5'), which is one step up from the standard Squealer (?) model. I thought it was what I wanted; dry painted, 120 hp gear box, thicker deck metal, taller sides, just overall heavier duty. The dealer asked what size tractor I owned, and when I told him- TC33DA, with fel, he commented that the tractor would have it's hands full.....he was right! I also use a quick hitch which throws the cutter approx. 6" further back. It isn't a problem, but I would not want any less tractor weight, or more cutter weight. I wouldn't even try to cut without the fel bucket. While I like the heavy duty stuff, the dry paint was what I was really after, about all I do now is cut pasture.
In the process of trading, tractors and tools, moving up a few hp, and going to 6' tools. I went back to the Woods Brush Bull; due to it's design, the Woods will shed the cut grass off the top MUCH better than the Bush Hog. I also previously had Modern, which is built like the Bush Hog. I think all three are good cutters, the decks rusting out was the reason for replacement (the Woods did last about 1 year longer). If I wasn't cutting in mud, they seldom got washed, but sweeping grass off the deck was necessary for the Bush Hog & Modern.
Heard of the slip clutch "locking up", after a few years, and non maintenance, (which is one of my faults) for that reason, I preferred the shear bolt shaft. The 285 only came with a clutch, so I kept my old shaft off the rusted Woods, but never installed it. Don't even know if it would swap."Life is tough, but it's a lot harder if you're stupid!".......John Wayne
05-29-2012, 01:07 PM #13Super Star Member
- Join Date
- Jul 2011
- Posts
- 10,959
- Location
- Yanceyville, North Carolina
- Tractor
- Kubota L4400
All the other TBN members have pretty well covered the suggestions and issues in regards to aiding and assisting you in making a decision. I would like to add one note utilizing suggestive thought. Before you mow, walk the area beforehand and spot the areas of concern that have large rocks or abandoned equipment or trash that might have been dumped on the property. If you have access to an ATV, this will provide a means to expedite the task faster. Just carry a can of RED spray paint with you and mark the areas of concern. By doing this, you will lessen your chances of damaging your mower and your tractor. Best wishes.
The PUPIL who does not surpass his Master, fails his Master.
10-29-2012, 10:35 PM #14Gold Member
- Join Date
- Nov 2007
- Posts
- 368
- Location
- PA
- Tractor
- Kubota L3130 HST 4x4
Sorry for waiting so long between posts, but shortly after starting the thread my need went to zero in a hurry. You see, I only needed this to maintain some trails where we allowed our dog to run free. Unfortunately a very fast growing tumor stole him from us. How a very healthy dog with no symptoms can go from 100% one day to being consumed with a massive tumor that the best surgeons couldn't remove is still painful nearly 5 months later.
Flash forward...
After adopting another rescue dog I stumbled on a barely used LandPride RCR2672. It's big and heavy and does what I need.
Thanks for all that shared their advice in this post.Kubota L3130 HST 4x4, FEL LA723 w/QA, Backhoe BH90, L2185 72" front snow blower, 7' back blade, carry all, Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Approximately 230 hours
10-30-2012, 10:14 AM #15Platinum Member
- Join Date
- Jun 2006
- Posts
- 703
- Location
- Northern Alabama
- Tractor
- 2012 Kioti DK45SE, 1994 JD LX176
Nice find! That is one of the mowers that was on my (very) short list. It should provide you with many years of service.
11-03-2012, 08:10 AM #16Gold Member
- Join Date
- Nov 2007
- Posts
- 368
- Location
- PA
- Tractor
11-03-2012, 01:08 PM #17
11-03-2012, 05:46 PM #18Veteran Member
- Join Date
- Sep 2008
- Posts
- 1,560
- Location
- Central MA, Lakes Region NH
- Tractor
- Kubota L4610 and John Deere 410
That is too bad about your dog. I've been through a lot with my 3 and have come close to losing 2 of them. Anyways, congrats on the mower, that is a great mower from what I have read on here (no personal experience).
I had been searching for a used heavy duty brush hog for a while, and the RCR2672 was one of the 4 or so I was looking for. I finally found a Brown 472 which is similar, and let me say, it is incredible the difference between my old Woods BB60 light duty model, and this cutter. I never knew difference would be so great. You made an excellent choice!Kubota L4610 and John Deere 410 - WR Long 64" Grapple (best attachment ever!) QA front forks, rear forks, Brown 472 HD Rotary Mower, homemade 3 pt log splitter, Land Pride rake/blade combo, Land Pride HRL 3578 box blade (Hydro scarifiers), Shaver SC50 3 pt. Stumpgrinder, FitRiteHydraulics TnT, 6" Vermeer PTO Chipper (Hydro feed), 2 bottom Disc Plow, Ratchet Rake
Rear Remotes Install
How to search TBN
11-16-2012, 09:39 PM #19Member
- Join Date
- Mar 2010
- Posts
- 38
I was going to start a new thread but this one looks like a good one to ask about a similar question. I have a Woods MD160 that I think it is time to replace. Bought new in 2000. Doesn't leak and not much of any signs of rust yet but I am wanting to replace it while it still has some trade in value. Anyway, I have been looking hard at the SQ160 Bush Hog and the BB60 Woods. Those both weigh a little over 600 pounds each. I am putting it on a TT45A New Holland. This is a 40 HP tractor. Mostly use for mowing CRP and trails. Would never try to cut anything more than a couple of inches. I have one dealer that has told me he would trade for 1025.00 including the slip clutch and front chain on the SQ160 and two other dealers are basically at 1600.00 trade difference on an BB60. Hard to trade for the Woods if I can get the SQ160 for 575.00 less but I am wondering if the SQ160 is built as tough as the BB60. It does weigh a few pounds more but it just doesn't look as solid at the tail wheel to me. Any suggestions or experiences would be helpful. Thanks!
Similar Threads
Rotary Cutter Rotary cutter help
By Matt_W in forum AttachmentsReplies: 18Last Post: 05-18-2010, 05:25 PM -
Rotary Cutter Rough Cut Rotary Cutter Recommendation
By Charles Billings in forum AttachmentsReplies: 25Last Post: 03-13-2010, 11:46 AM -
Rotary Cutter Best way to get stump jumper & blades off rotary cutter?
By Dargo in forum AttachmentsReplies: 13Last Post: 07-24-2006, 09:51 AM -
Rotary Cutter Rotary Cutter Abuse
By jinman in forum AttachmentsReplies: 11Last Post: 07-13-2004, 02:32 AM -
Rotary Cutter Rotary Cutter Design
By paccorti in forum AttachmentsReplies: 9Last Post: 06-09-2001, 02:22 PM
