Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1
    Join Date
    Jul 2010
    Posts
    133
    oh
    Kubota 2011 MX5100 W/la844 loader, ag/ tires loaded, Massey Ferguson 2010 GC2610 TLB w/ r4 tires, loaded, 60" Belly Mower
    Default nuts came loose on front wheels.....
    this happen to anyone else. ??
    what do i do , new rims, nuts, bolts, studs... where do i get them. ??
    kubota mx5100 4wd. just happened monday.
    candyman
    Attached Thumbnails Attached Thumbnails nuts came loose on front wheels.....-dscn2561-jpg   nuts came loose on front wheels.....-dscn2560-jpg   nuts came loose on front wheels.....-dscn2559-jpg
  2. #2
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,559
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: nuts came loose on front wheels.....
    Wow! At a minimum, I think you'll need a new wheel and probably new lug nuts. Hopefully the studs are still OK, but check them carefully.
  3. #3
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,718
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by candyman View Post
    candyman
    I dont see how the studs could be any good either.. yes to all of your questions, I would start at The dealer. You are supposed to check the tightness upon putting the tractor in service and every 50 hours. A lot of guys don't, and everything is fine, But this time everything was not fine. I don't see how anything but the tire can be salvaged. good luck
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  4. #4
    Join Date
    May 2011
    Posts
    826
    Trent Hills, ON
    Kioti DK40SE HST
    If a break down isn't going to cost you alot of money or kill you, I might try some big thick washers. Take off the nuts, put the washers on and then the nuts, and then tighten and hope the washers bend into a rough taper to take up the slack and roughly centre the wheel holes on the studs.
    I also add maybe a third to the torque spec to help keep things tight and hope you don't snap a stud.
    I found a couple lug nuts I could turn a half turn at my 50hr service which surprised me, but I guess that's why you're supposed to check.
    2011 DK40SE HST
  5. #5
    New Member
    Join Date
    Apr 2012
    Posts
    11
    Greenfield ny
    Ford 2810
    I know that oversize lug nuts are available in certain sizes for just such an occasion. Whether they are available for your tractor I can't say. You would need to take a lug nut to your local NAPA type store or tractor repair mech. and match it up.
  6. #6
    Veteran Member tungularafishcamp's Avatar
    Join Date
    Sep 2010
    Posts
    1,584
    kodiak island, Alaska
    kubota L2800, 1/2 of a L48
    I second the vote for the washers, maybe even make a stack of 3 of different od's weld them together then grind them into an arc. That will be a whole lot cheaper than new rims and might back the nuts off the studs far enuff to get good thread.
    Rick
  7. #7
    Gold Member the6shooter's Avatar
    Join Date
    Dec 2006
    Posts
    455
    oklahoma
    MF 1643
    New wheel or good used wheel, in this case you will probably have stress cracking in the wheel you now have. lug nuts all need replacing.
    At least see the dealer, and get the proper rim size, then google for a replacement.
    david
  8. #8
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,760
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    The washer idea may work in the short term but I would get some new rims on order and swap out when they come in. The rim center hole should be very tight to the tractor hub and it looks like yours is wallowed out a bit. That should be where the weight is carried with the nuts just holding the rim tight to the hub,
    You will need new studs and new rims, so rather than take a chance on damaging the wheel hub, get the new rim now and replace it.
    Check all the bolts now to make sure they are tight.
    This reminds me that I need to check mine with a wrench, rather than just visually as I have about 50 hours on it now.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #9
    Join Date
    May 2008
    Posts
    1,673
    Prince Edward Island, Canada
    Kioti DK45SC
    Last year I happened to notice that a couple of nuts had backed off (fallen off!) of one front wheel on my Kioti DK45. I was lucky that the others were still tight, so no damage to the wheel. I finally found some with the same thread at the local kubota dealer, but the head is a different size so I have to use two different sockets when I check the torque!
    I don't think it would hurt to try the washer-cone approach others have suggested...if it doesn't work out, you can still go to a bunch of new parts.
    BOB
  10. #10
    Super Member woodlandfarms's Avatar
    Join Date
    Jul 2006
    Posts
    5,483
    Los Angeles / SW Washington
    PowerTrac 1850, Kubota RTV x900
    If this vehicle did 50 you would have to replace, but my neighbor who is a mechanic for the state parks had a large deer back hoe in with the same problem. The holes were worse, but he got some plate, cut it down, drilled a hole and welded it on.
    He also advised the owner to start looking for a new used rim, but felt the fix would hold a long time.
    Power-Trac 1850, grapple, hoe, 90" mower, 72" box blade
Similar Threads
  1. Chains JD 2520 Front wheels traction in Snow
    By p0peye in forum John Deere Owning/Operating
    Last Post: 12-07-2010, 06:45 PM
  2. Reversing Front Wheels on a Ford 4610.
    By frankmako in forum New Holland Owning/Operating
    Last Post: 11-02-2010, 12:28 AM
  3. Cracking front wheels
    By Cormac in forum Parts/Repairs
    Last Post: 01-28-2009, 04:29 PM
  4. Ballast Filling front wheels with water
    By andyspain in forum Chinese Tractors
    Last Post: 05-05-2005, 05:53 PM
  5. 1215 front wheels dished out?
    By Stonewall in forum Massey Ferguson Owning/Operating
    Last Post: 03-31-2003, 12:05 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
