Results 111 to 120 of 251
06-05-2012, 08:02 AM #111Elite Member
- Join Date
- Sep 2009
- Posts
- 3,185
- Location
- Murray, KY
- Tractor
- 265 MF / JD 310B Backhoe
Re: almost flipped the tractor, really need some help!
I can see all this happening to an new to tractor owner.
We know in detail about where/how to add rear weight from posters.
What surprized me in looking at photo just posted again was the design of the FEL mounting. The mounting brackets by design means the loader weight is really on the front axle only as I see it.
We have a JD310B old backhoe. We were looking for a FEL for the 265 MF and when this JD FEL since it came with a free tractor and backhoe.
I know we are talking apples and oranges between these to classes of JD's but the mounting point is more like 3 foot more towards the rear tires on our backhoe.
I see nothing fake looking with the photos. If one has been around much equipment one knows a lot of things can happen. The rear wheels just wanted to be in front.
06-05-2012, 08:23 AM #112Bronze Member
- Join Date
- Oct 2011
- Posts
- 84
- Location
- Australia
- Tractor
- N/A
Looks like a winter day in the Blue Mountains? I reckon at least the location is legit
mate .. get some fill and hire a dozer to do any bulk earthworks, not worth the risk on those slopes
06-05-2012, 08:25 AM #113Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,678
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Got to disagree with you there...
Loader bucket too high going downslope, no appreciable weight on the 3PH and no weight in the tires.
Then a sudden jab on the brakes (especially if he was traveling faster then he should have been)...and the front wheels full lock to the right...he's lucky it didn't continue the rollover.
Yep, I can see that happening easily.
And, why would one risk a rather expensive piece of equipment for a TBN thread or other internet posting? That makes no sense whatsoever.
He probably could have eased the tractor back down with the loader (until gravity took over) but I suspect he panicked and jumped off.Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
06-05-2012, 09:20 AM #114Veteran Member
- Join Date
- Jan 2011
- Posts
- 2,368
- Location
- Great NorthWest /Southwest Washington
- Tractor
- Kubota l245dt, l3540, 8N
Roy said "I suspect he panicked and jumped off."
Maybe he didn't use his seatbelt like he should have and he got bucked off!
"keep them pots black, shiny, and full of good Food and Fellowship!"
Moore Cookie
06-05-2012, 09:32 AM #115
06-05-2012, 09:50 AM #116Platinum Member
- Join Date
- Apr 2011
- Posts
- 575
- Tractor
- New Holland Boomer 50
06-05-2012, 09:55 AM #117Veteran Member
- Join Date
- Oct 2011
- Posts
- 1,829
- Location
- Monrovia, California
- Tractor
- Kubota BX25
Another angle...
Regards,
Artisan
Kubota 2012 BX25 (23H.P. / 17.7pto)
14' Dump / Carson 12K Tow Trailer w/ movable Winch,
Canopy, Tunes, Stabilizer Soft Pads, 10"-12"BH Buckets, FEL Grapple, Fasse Valved & Switched,
Fire Extinguisher, ChainSaw Mount, Protective Surround / Enclosure in the works.
Stayin' Alive (This click could save a life...)
06-05-2012, 10:03 AM #118Veteran Member
- Join Date
- Mar 2010
- Posts
- 1,223
- Location
- Ontario
- Tractor
- CT235
Staged??? that's hilarious.
Tim.
06-05-2012, 11:12 AM #119Bronze Member
- Join Date
- Apr 2011
- Posts
- 91
- Location
- So MD
- Tractor
- MF 2660 LP, Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
I'm impressed with the CAD capability being an engineer myself; I understand what you are showing. Neat stuff.
I do not think the photos were doctored or "photoshopped." I do say it is likely that the tractor got jacked up a little bit, the pranksters decided they could run it up higher, hold it in place with a strap and take the pictures. Motive? There are thousands of publicity attempts these days,almost per day, just very few on serious minded tractor forums. If you get a rise out of a large number of people then the pranksters are happy. In this case they should be very happy. I readily admit I could be wrong but I say that is the most LIKELY circumstance. Unfortunately we have no way to know for sure.jwr
MF2660 LowProfile, 7'BushHog, 5' FEL mounted hydraulic cutter, Landpride 6' finish mower, Kubota BX2200, Kubota B2150, 5' snowblower,blade, Pequea 1018 deckover trailer, half interest in Massey Harris Pacer family heirloom...
06-05-2012, 11:39 AM #120
I am betting it happened just the way the OP said it did.. I am also betting it scared the crap out of him.. risk a brand new tractor for a stunt? I don't think so.
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
Similar Threads
Flipped tractor on side now it will not start
By Froggychic in forum Kubota Owning/OperatingReplies: 15Last Post: 03-31-2013, 08:58 PM -
Flipped my BX24
By Chuck1949 in forum Kubota Owning/OperatingReplies: 32Last Post: 10-17-2008, 10:27 PM -
FLIPPED OVER 4115
By HURLEYSLAWNCARE in forum John Deere Owning/OperatingReplies: 4Last Post: 08-26-2007, 09:39 PM -
flipped B2910
By pgilhool in forum Owning/OperatingReplies: 13Last Post: 08-29-2006, 01:07 AM -
Nearly flipped it
By Mrwurm in forum SafetyReplies: 26Last Post: 05-14-2002, 10:23 PM
