Results 241 to 250 of 251
11-18-2012, 10:34 AM #241Veteran Member
- Join Date
- Feb 2012
- Posts
- 1,654
- Location
- Holland, PA
- Tractor
- 2012 Kubota L5740HSTC3, 1986 Case IH 255, 1986 Gravely 8199G
Re: almost flipped the tractor, really need some help!
Welcome also. I wish there was a seatbelt light on the dash to remind me, no buzzers or nannys, just a light. If I'm moving the tractor out to let it warm up and get off, I'm probably safe going thirty feet straight ahead...
But once I go to work, it's easy to forget. And I'm a 100% wearer in the car.
When I pick up a back wheel boy do I check my belt mentally. But I need to make it part of my start up mental procedure. My smaller open tractor has a ROPS and belt, and I use that belt constantly, but somehow getting in the cab, I'm fiddling with the heat or the stereo while the engine warms up, and I forget the belt. Hopefully not any more. I think the backhoe will solve the OP's issues, but geez just pay extra attention on slopes. Gravity makes it all work but keep your apples in the applecart.
11-18-2012, 11:04 AM #242Gold Member
- Join Date
- Jan 2012
- Posts
- 288
- Location
- Southern Oregon
- Tractor
- Kioti DK45SE Hst
dgoyette, the background scenery in your pic looks beautiful!
Kioti DK45SE HST w/ backhoe, forks, PHD, box blade, chipper. Living off-grid, Listeroid 6/1 backup, masonry stove, thermal mass H2O storage
"Those who would give up Essential Liberty to purchase a little Temp Safety, deserve neither Liberty nor Safety." Ben Franklin, 1775
"The 2nd Amendment is the RESET button of the US Constitution"
11-20-2012, 08:32 PM #243
Thanks for the Welcome! I have had a couple of years of practice but in many ways still a newbie as I learn new things all the time. I also confess to not using the seatbelt as recommended. I will make a point to start using it so the belt and ROPs can do their job should I ever roll it.
Thanks!
11-20-2012, 08:45 PM #244Silver Member
- Join Date
- Jul 2010
- Posts
- 118
- Location
- Rolla, ND
- Tractor
- John deere 2305, X520 and LX188
Holy smokes!!!!
Fortunately, you were going up and down and not sidehill.
You could "liquid fill" the front and rear tires, but the calcium carbonate solutions rusts the H out of the tires.
I had the tires on my JD2305 "foam rubber filled" which increased the weigt from 50 to 300 pounds on each of the rear tires, and permanently flat-proofs them. It was an arm and a leg to have them foamed, but I found a less expensive place (after the fact, of course).
You could:
foam fill the rear tires;
Install rear wheel weights
install weight on the back
or
Keep off the slopes, don't lift anything too heavy with the FEL and by all means, keep the FEL Low to the ground.
Get it in to the dealer about the problem going up slopes before the warranty runs out. By the look of the second picture, some of your H-Gard hydraulic fluid could have run out.
The main thing - You are not hurt or in a wheel chair for eternity.
Foam fill the tires.
SC
11-20-2012, 08:47 PM #245
11-20-2012, 09:06 PM #246Banned
- Join Date
- Nov 2012
- Posts
- 109
- Location
- east coast
- Tractor
- deere,kubota,case,sears,new holland, Mf
11-20-2012, 11:20 PM #247Gold Member
- Join Date
- Oct 2012
- Posts
- 281
- Location
- Southern Utah
- Tractor
- John Deere 3120
11-21-2012, 08:30 AM #248New Member
- Join Date
- Nov 2012
- Posts
- 12
- Location
- weld, maine
- Tractor
- john deere 550 dozer 1987 / Kubota B2920 2010 / JD 260 skid steere 2003
I know a guy who did this in a John deere 260 skid steer carrying a boulder too high on level ground. It shook him up so much that either him or his wife decided to sell it. Thats how I aquired it. He had 26 hours on it and used it for snow removal and lite landscape work. It was garaged next to his Lexus . As corperate executive he could afford the extra BIG toy, for a while anyway. Glad your ok. JG
11-21-2012, 12:26 PM #249Super Member
- Join Date
- Dec 2008
- Posts
- 5,264
- Location
- North Carolina
- Tractor
- Kubota BX2200
Which is bigger?: a) $100 per month since the Big Bang or b) the US National Debt.
"write these words down GOLD WILL TAKE A $600.00 DECLINE IN THE NEXT 6 MONTHS" Grumpy Old Man 12/6/12 NY Spot price bid last via Kitco 1701.80
"Good, I'll be a buyer!" -EE_Bota 12/6/2012
11-21-2012, 02:29 PM #250
Similar Threads
Flipped tractor on side now it will not start
By Froggychic in forum Kubota Owning/OperatingReplies: 15Last Post: 03-31-2013, 08:58 PM -
Flipped my BX24
By Chuck1949 in forum Kubota Owning/OperatingReplies: 32Last Post: 10-17-2008, 10:27 PM -
FLIPPED OVER 4115
By HURLEYSLAWNCARE in forum John Deere Owning/OperatingReplies: 4Last Post: 08-26-2007, 09:39 PM -
flipped B2910
By pgilhool in forum Owning/OperatingReplies: 13Last Post: 08-29-2006, 01:07 AM -
Nearly flipped it
By Mrwurm in forum SafetyReplies: 26Last Post: 05-14-2002, 10:23 PM
