Page 3 of 26 FirstFirst 12345613 ... LastLast
Results 21 to 30 of 251
  1. #21
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    Default Re: almost flipped the tractor, really need some help!
    Gotta get them rear tires filled(or rear wheel weightsalmost flipped the tractor, really need some help!-jd-wheel-weights-jpg if you dont wonna load the tires)and with the ripper you have could weld a bracket were you can add some suitcase weights to each side of the back of it(or in middle)almost flipped the tractor, really need some help!-jd-weights-jpg.
  2. #22
    Gold Member
    Join Date
    Jun 2007
    Posts
    258
    Clinton Hollow NY
    A bit surprising that the dealer didn't suggest loaded tires and carrying an implement (at least for ballast), if he was familiar with your terrain and experience.
    Live customers tend to generate repeat business.
    As a comparison, the bucket on my TN70a is 610kg.
    TN70a EHSS 16x16, FWD, road transmission, open station with tilt, R4 w/810TL MSL FEL soft ride option, FOPS
    MF1040 w/MF1016 FEL, FWD, R1s, frozen clutch...
    I do know everything, just not all at once. It's a virtual memory problem.
  3. #23
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,922
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    In addition to all the aforementioned, I would give serious consideration to getting a second, lighter bucket to add to your selection of equipment.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  4. #24
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    953
    Gator Country
    New Holland TC40D HST 4WD FEL/BH
    Glad your OK. Did you clean and disinfect that tractor seat?
    We have a Back Hoe on our so I don't usually have your situation. Even though our ground is rather flat (after all, I live in Florida) I have been doing some digging with the front bucket to make a pond area. The way out after a number of bucket loads has gotten a bit steep.
    One day when I had the BH off so we could use the 3PH I took some loads of dirt out of the hole for filling elsewhere. This was the first time I had used the tractor without the BH on.
    What a difference!
    While I was backing out of the hole with the bucket full the tractor started to lift the rear. I took it slow, kept the FEL low and was in 4WD. I made it out and emptied the bucket.
    Before making additional loads I put the tiller on the 3PH.
    What a difference!
    I no longer had a front-heavy machine that wanted to lift the rear.
    We found that when we don't have the BH on the rear we need to keep something on the 3PH. We find we like the tiller better then a bush-hog, disk, plow or such (don't have a box blade)
    We like the tiller because it adds sufficient weight but does not stick out so far behind the tractor like the mower and is heavier then the disk or plow.
    Also, when doing loader work or just if I need to lift the front bucket I keep my one hand on the loader stick while I drive with the other - that way I can drop the bucket if needed.
    New Holland Workmaster 45 2WD Gear
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
  5. #25
    Elite Member bullbreaker's Avatar
    Join Date
    Mar 2009
    Posts
    2,930
    SW FLA
    1/3 PARTNERSHIP IN BOTA 7060 (PLANT NURSERY OPERATION) SOLD MY PERSONAL L3400 DT BOTA
    Real glad to hear your ok !
    Sometimes some of us let pride get in the way and we would not want anyone to even know something like that happened to us. Very humble and wise of you to share your experience, if in future it keeps people thinking about safety even one your thread like countless others in past more than well worth it.
    Boone
    BTW: Big Thanks for not posting pic of underwear you were wearing when that happened !
    2 CHRONICLES 7 : 14 (KJV)
  6. #26
    Elite Member Mousefield's Avatar
    Join Date
    Aug 2008
    Posts
    2,636
    Qualicum Beach on Vancouver Island, BC. Canada
    Sold 2008 CK35 HST
    Quote Originally Posted by bullbreaker View Post
    Boone
    We learn from fellow members, I second the thanks for sharing your story and pics. Glad it didn't flip, could have been real nasty.
  7. #27
    Silver Member heviduty's Avatar
    Join Date
    Apr 2012
    Posts
    194
    central NC
    Kubota L3400HST/LA463 loader JD 318 / 3ph(cat. 0)
    Dang man, just ...DANG!
    I've been up on two wheels, going downhill, backwards, so just looking at the pictures scares me!
    Three things every FEL user should know (and some of us learned the hard way):
    1. Keep 4WD engaged unless you are on pavement. Most tractors don't have front wheel brakes.
    2. Rear ballast. Fill your rear tires (no more than 70%), but that's not enough. There are some good posts on TBN about making your own weight box, or you can keep something heavy attached to your 3 point hitch.
    3. Keep the bucket no more than a foot or so off the ground when traveling.
  8. #28
    Super Member
    Join Date
    Feb 2002
    Posts
    5,319
    western,pa.
    Kioti DK 35
    Close call.
    Glad your OK.
    More ballast and carrying the bucket lower may help this from happening again in the future.
    Once the wheels are off the ground (like in your photos) lowering the loader boom and pressing the bucket into the ground will push the rear wheels back down onto the ground.
    Vince,
    Kioti DK 35
    Hustler Super Z
  9. #29
    Super Member radioman's Avatar
    Join Date
    May 2008
    Posts
    5,878
    Ontario, NY
    Kubota BX24
    all good replies. We all can't say it enough - you need rear ballast. it doesnt matter if you have liquid ballast in rear tires, or have a weight box, or cast weight to go in rims, heavier implement then the rippers, add a custom made concrete weight to do on rippers bar- or any combination of above. take your pick.
  10. #30
    Super Member Mace Canute's Avatar
    Join Date
    Nov 2006
    Posts
    9,428
    Saskatoon, Saskatchewan
    This seems to be typical of a lot of new tractors these days...put a loader on them that is way to big for the machine (I don't care what the dealer says). It's OBVIOUS it's too much loader when AN EMPTY BUCKET can tip the tractor onto it's nose when driving straight downhill.
    Just for comparison, my unballasted 6500 pound 3010 has a 6 foot wide non 4 way bucket (148 loader) and 22" more wheelbase compared to that 3000 pound 4105 and I never have issues with stability.
Similar Threads
  1. Flipped tractor on side now it will not start
    By Froggychic in forum Kubota Owning/Operating
    Last Post: 09-08-2014, 11:11 AM
  2. Flipped my BX24
    By Chuck1949 in forum Kubota Owning/Operating
    Last Post: 10-17-2008, 10:27 PM
  3. FLIPPED OVER 4115
    By HURLEYSLAWNCARE in forum John Deere Owning/Operating
    Last Post: 08-26-2007, 09:39 PM
  4. flipped B2910
    By pgilhool in forum Owning/Operating
    Last Post: 08-29-2006, 01:07 AM
  5. Nearly flipped it
    By Mrwurm in forum Safety
    Last Post: 05-14-2002, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
