Results 31 to 40 of 251
06-03-2012, 03:01 PM #31Silver Member
- Join Date
- May 2004
- Posts
- 118
- Location
- northwestern connecticut
- Tractor
- 1989 Cub Cadet hydro 13/20, 2004, Kioti CK20HST TLB
Re: almost flipped the tractor, really need some help!
For some, a decent book helps a lot. I would suggest Operating Techniques for the Tractor-Loader-Backhoe Revise Edition by GAry J. Ober. I got mine from Equipment Training Resources, HEAVY EQUIPMENT TRAINING VIDEOS & BOOKS | ETR: Equipment Training Resources - Backhoe Training, Loader Training, Excavator Training, Trencher Training and Hydraulics Training Books & Videos, is the web site on the inside cover. The book (about 300 pages) explains the concept of center of gravity and keeping the center of gravity as low as possible. I would think it is still in print and can be shipped to you in Sydney. The book is soft cover and is mostly for full-size Tractor-Loader -Backhoes, but the information and photos is helpful for smaller rigs, in my estimation. As someone must have already stated be sure to wear your seatbelt and keep that front bucket as low as you can. My rig is a very small TLB and the backhoe weighs about 700 LBS and of courses hangs about 5 feet off the back of the tractor. This makes for an excellent counter weight. Happy and safe tractoring!
06-03-2012, 03:15 PM #32Elite Member
- Join Date
- Jan 2009
- Posts
- 2,882
- Location
- From Vt, in Va, going to MS
- Tractor
- Kubota's - B7610, M4700
Looks like you were trying out for a Bobcat style commercial spinning on your front tires!
Seriously, this is a good time to buy a backhoe, or at least a big heavy Box Blade.My rides - '95 Kubota M4700, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, 18', new Woods BH70-X w/ 16" bucket and Woods thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, Winco 12KW PTO generator with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 Hudson HSE Deluxe trailer - 5 Ton to haul
06-03-2012, 03:42 PM #33
Ok I looked up your tractor on Tractordata, and I see it is a 2 speed hydro. so on your hilly terrain, I think you are going to be in LO most of the time with your weight on the 3pt
. and judging by the size of your tractor I am still thinking 750 to 1000 lbs on the rear AND loaded tires for your area, of course the bucket maneuver up high was the final straw in the chain of events that got you where your were. Good luck (and you seem like a lucky guy
) in the future man.
James K0UA
Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
06-03-2012, 05:54 PM #34Gold Member
- Join Date
- Jan 2012
- Posts
- 338
- Location
- Northern Washington
- Tractor
- John Deere 3005
#800 cement block is what i made, Forms are plywood and the 3 point connections are welded inside the cement, just use webbing layers in the cement, believe me anyone with a welder can make this. Easy !!!
2011 John deere 3005, already waxed 5 times.
I drives me boat ! My wife drives me dingy !
06-03-2012, 06:08 PM #35Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,675
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Backhoes aren't really practical as rear ballast unless you have need of a backhoe...even then, they do raise the tractor's center of gravity. Also, a lot of money for a backhoe!!
A box blade would be OK...but not as good as a ballast box and more money (for the box blade) for less weight.Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
06-03-2012, 06:16 PM #36Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,653
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
06-03-2012, 06:39 PM #37Veteran Member
- Join Date
- Nov 2009
- Posts
- 1,701
- Location
- USA
- Tractor
- Bobcat
06-03-2012, 06:39 PM #38
Yep, I spend a lot of time with the FEL in many different types of terrain, so I adjusted my FEL lever so I can comfortably operate it with my elbow resting on the fender. I almost always drive with my left hand on the wheel my right hand on the FEL lever. I've had a few close calls that were saved by a quick downward action of the FEL
And yes...keep it low, especially when loaded.If you don't have it, make it.
If it breaks, weld it.
06-03-2012, 06:46 PM #39Veteran Member
- Join Date
- Mar 2010
- Posts
- 1,221
- Location
- Ontario
- Tractor
- CT235
06-03-2012, 06:50 PM #40Veteran Member
- Join Date
- Nov 2009
- Posts
- 1,701
- Location
- USA
- Tractor
- Bobcat
Similar Threads
Flipped tractor on side now it will not start
By Froggychic in forum Kubota Owning/OperatingReplies: 15Last Post: 03-31-2013, 08:58 PM -
Flipped my BX24
By Chuck1949 in forum Kubota Owning/OperatingReplies: 32Last Post: 10-17-2008, 10:27 PM -
FLIPPED OVER 4115
By HURLEYSLAWNCARE in forum John Deere Owning/OperatingReplies: 4Last Post: 08-26-2007, 09:39 PM -
flipped B2910
By pgilhool in forum Owning/OperatingReplies: 13Last Post: 08-29-2006, 01:07 AM -
Nearly flipped it
By Mrwurm in forum SafetyReplies: 26Last Post: 05-14-2002, 10:23 PM
