Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    Default Re: Best solvent to remove excess grease?
    I've always gotten along with brake or carb and choke cleaner. The combination of spray pressure and the solvent action of the liquid either blows it away or makes it easier to wipe off. I like to use a sash brush for getting into the tight spots.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  2. #12
    Gold Member
    Join Date
    Jan 2007
    Posts
    319
    Hillsboro, NH
    Kubota L4310
    I agree with Artisian - post #6, if you want to clean excess grease.
    I grease several times / yr; then typically cleanup 1-2 times.
  3. #13
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Engine Degreaser
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  4. #14
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,387
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    I use white wall cleaner, 1 cup in a spray bottle with water. Spray on let set 10 min. wash off. The thick stuff was to be blowed or wiped off 1st. Works good on exhaust soot also. If not washed off it could do a # on the paint.
  5. #15
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Before it became "bad stuff" for the environment, liquid freon used to be sold as a degreaser. It was excellent and non-flammable; however, the CFC Police put a stop to its use. Perchloroethylene (dry cleaning fluid) also did an admirable job since it was non-flammable. Today, I find the best/cheapest solvent is diesel fuel. I'm convinced many engine cleaners are primarily kerosene/diesel fuel from their smell. Diesel will not harm paint as gasoline and some other solvents. It will remove wax, but wiping an old car with diesel is an old used car salesman's trick. Dull or dead paint can be hidden by wiping with diesel and do no damage to the paint. Instead of buying an expensive solvent, I'd try some of that $3.50/gal diesel on a rag to clean the grease. If you get diesel down inside the grease joints, it won't matter either. Wear your best set of greasemonkey clothes to do the job.
    Jim
  6. #16
    Super Member Highbeam's Avatar
    Join Date
    Feb 2005
    Posts
    5,039
    South Puget Sound, WA
    Kioti CK30HST
    diesel here too. We all have diesel around and it works great. I use it on O-ring motorcycle chains too.
    Kioti CK30HST, FEL w/toothbar, 60" RC, 60" BB, PJ 10k trailer. Weekend warrior hauling 50 miles each way.
  7. #17
    Gold Member Toddao's Avatar
    Join Date
    May 2009
    Posts
    292
    jeffersonville VT
    GC2410TLB
    Default
    Brake cleaner .
Similar Threads
  1. What's your favorite cleaning solvent?
    By JDgreen227 in forum Oil, Fuel & Lubricants
    Last Post: 06-07-2012, 06:13 PM
  2. Brand of cleaning solvent to use
    By banjerpicker in forum Massey Ferguson Owning/Operating
    Last Post: 05-06-2012, 10:49 PM
  3. Excess Grease
    By ritcheyvs in forum Kioti Owning/Operating
    Last Post: 03-28-2012, 10:13 PM
  4. Near impossible to remove grease gun
    By msengstock in forum John Deere Owning/Operating
    Last Post: 01-14-2009, 01:27 PM
  5. Parts Washer Solvent?
    By Iplayfarmer in forum Parts/Repairs
    Last Post: 08-23-2007, 05:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
