Results 1 to 3 of 3
06-25-2012, 06:03 PM #1Bronze Member
- Join Date
- Jan 2009
- Posts
- 67
- Location
- Fort White, Fl
- Tractor
- JD 3038E
Installed suspension seat base to JD 3038E
A local dealer gave me an almost new suspension base from a large Kubota. I removed the JD 3038E seat and base matched it up to the new base and marked 4 holes to drill. I installed the new base with the original bolts. I cut down two 5" angle brackets, drilled 4 holes, and bolted them to the top of the base for the seat pin to run through. The seat still flips forward.
The seat switch wire is now too short but can easily be extended. For my test drive I jumpered it.
The seat now puts me up a few inches higher and a few inches further back. Also, the seat no longer adjusts front to back. I'm tall with long legs so it works fine for me.
A quick ride around the property made it obvious it was worth the work. No more spine jarring bumps. At 230 lbs I had to crank the spring tension up almost all the way.
It was about a 2 hour job.JD 3038E, 305 loader, Frontier 60" RFM
06-26-2012, 05:01 AM #2
Re: Installed suspension seat base to JD 3038E
Looks good!
Phil. from Mass.
2008 Kioti ck20 with 380 hours
New to me 2011 K120 loader
06-26-2012, 05:48 AM #3Super Star Member
- Join Date
- Jul 2011
- Posts
- 10,417
- Location
- Yanceyville, North Carolina
- Tractor
- Kubota L4400
Congratulations. Well done.
The PUPIL who does not surpass his Master, fails his Master.
Similar Threads
suspension seat?
By dslanec in forum Cub Cadet Yanmar & CUTsReplies: 5Last Post: 06-02-2012, 02:44 PM -
4310 seat base spring broken
By chickenman in forum John Deere Owning/OperatingReplies: 8Last Post: 05-23-2012, 05:03 PM -
Michigan Seat Highback Suspension Seat, Model# V-5300
By jmsmbry in forum Kubota Owning/OperatingReplies: 0Last Post: 05-02-2010, 10:08 AM -
Suspension seat
By Grand_Pooba in forum Mahindra Owning/OperatingReplies: 1Last Post: 01-11-2008, 11:08 AM -
Swivel seat base
By Gary_in_Indiana in forum CustomizationReplies: 12Last Post: 09-03-2002, 06:34 PM
