Results 11 to 20 of 31
06-27-2012, 12:51 PM #11
Re: My Bridge/ Culvert Project. (Pics)
Here is an update. I have put about 16" above the culvert as suggested. Rip rap is on the way. I will crown the road and ditch the edges last, before I gravel it. This will be an access road for trucks and deliveries while we build our dream home on the lot. I will take pics of the build as we progress.
What gravel do you recommend for the road?
JD 3320 end loader, 5' rear cutter, box blade, tiller,artillian forks, Fit rite hydraulic top link.
JD GX255 lawn tractor
1978 JD 400
06-27-2012, 01:51 PM #12
I'm gonna take that dump truck across it tomorrow, do you think I have enough dirt over top of the pipe?
1978 JD 400
06-27-2012, 01:58 PM #13
Its tough to tell by the pictures, but a little more wouldn't hurt. I'm not sure how strong that pipe will be with a big heavy truck going over it. Like other have said, water can run down the middle of the road and wash ruts in it. Looking at the photos, it doesn't look like that will be a huge problem. For a home built road done with a small tractor, it looks pretty darn good to me.
Dave,
BX2350
06-27-2012, 02:18 PM #14
To me that also looks good! We build roads on occasion (1-5 mile) and some codes call for processed road gravel. And other few have we have used crushed asphalt. DO NOT USE CRUSHED CONCRETE!!!! It get so dusty it's horrible and never binds well. Crushed Asphalt is probably the best way to go, it holds up to our tandem and quad axle dump trucks well even 40ton lowboys.
Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
06-27-2012, 02:42 PM #15Veteran Member
- Join Date
- Nov 2011
- Posts
- 1,091
- Location
- Near Winnipeg, Mb, Canada
- Tractor
- John Deere 2305, 2320,Z465
Look into geotek fabric. I think its well worth the money. It also saves on gravel for years to come.
Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
06-27-2012, 02:46 PM #16Veteran Member
- Join Date
- Nov 2011
- Posts
- 1,091
- Location
- Tractor
Look into geotek fabric. Its not cheap but will save you money in reduced amounts of gravel now and in the years to come.
06-27-2012, 03:48 PM #17
Rip rap is complete. I have about 10 tons left over. Slight miscalculation.
1978 JD 400
06-27-2012, 04:15 PM #18
06-27-2012, 04:42 PM #19Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,675
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
I would put the rip rap a little thicker along the sides. My son helped a friend of his on a job and they laid a lot of it by hand to get good coverage and packed it in.
If you have hills, you will find you really can't have too much rip rap or other rock, I keep some stored and wish I had more. I have 1", 2" and 6" minus in three separate piles.
You sure have moved a lot of stuff with a relatively small tractor, you are to be commended.
06-27-2012, 05:24 PM #20Veteran Member
- Join Date
- May 2006
- Posts
- 2,073
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
Nothing could be finer than riding my JD790 in South Carolina!!
2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, Leinbach PHD with 9" & 12" augers, King Kutter II 60" Rototiller, Leinbach middlebuster, Leinbach #11 Field Cultivator, boom pole, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
Nothing runs like a Deere, or smells like a John....
Similar Threads
Creek Culvert Project
By TNhobbyfarmer in forum ProjectsReplies: 39Last Post: 06-01-2007, 09:47 PM -
Pond - New Culvert Project
By tractordk in forum ProjectsReplies: 5Last Post: 05-16-2007, 05:39 PM -
Bridge project
By MikeD74T in forum ProjectsReplies: 5Last Post: 09-29-2006, 09:44 AM -
Culvert Project
By FL_Cracker in forum ProjectsReplies: 1Last Post: 07-08-2005, 10:06 PM -
Culvert Project
By Harv in forum ProjectsReplies: 72Last Post: 04-04-2001, 02:47 AM
