Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,110
    KY @ TN line
    2011 LS R3039
    Default Re: My Bridge/ Culvert Project. (Pics)
    Good job, I like that Razr.
  2. #22
    Gold Member cartod's Avatar
    Join Date
    Aug 2008
    Posts
    280
    Northern, West Virginia
    JD 3320
    Thanks for the comments, yea the razor makes my time to and from my house to work site much ffffaster. I went ahead and added another 5 inches or so of dirt over top of the pipe.
    JD 3320 end loader, 5' rear cutter, box blade, tiller,artillian forks, Fit rite hydraulic top link.
    JD GX255 lawn tractor
    1978 JD 400
  3. #23
    Join Date
    Aug 2008
    Posts
    280
    JD 3320
    Quote Originally Posted by foreman Etexas View Post
    Attachment 271171My suggestion is go wider at top of hill,take those hills out further so you can kick the water off the road and have room to work with tractor at later date if your ditches need fixed.
    I am widening today.
    1978 JD 400
  4. #24
    Join Date
    Aug 2008
    Posts
    280
    JD 3320
    Quote Originally Posted by TripleR View Post
    I would put the rip rap a little thicker along the sides. My son helped a friend of his on a job and they laid a lot of it by hand to get good coverage and packed it in.
    If you have hills, you will find you really can't have too much rip rap or other rock, I keep some stored and wish I had more. I have 1", 2" and 6" minus in three separate piles.
    You sure have moved a lot of stuff with a relatively small tractor, you are to be commended.
    Yea it's not a real big tractor, but pulling dirt with a box blade down a hill is easy when you have gravity.
    1978 JD 400
  5. #25
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,482
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by cartod View Post
    I'm gonna take that dump truck across it tomorrow, do you think I have enough dirt over top of the pipe?
    Did you pack the sides of the culvert as you back filled it? If not I would not take that truck across the pipe it will likely crush it. After it gets rained on several times see if it settles any. You may luck out and not have any issues but if it crushes it down any it has to bee done over. My brother tried on his crossing and it crushed it.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  6. #26
    Veteran Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    2,029
    texas
    kubota M7040 &m7040
    If you get your ditches all the way up I would suggested maybe using some of that rip rap all the way up to top. Looks GOOD
    While you had the dump truck empty should have wheel rolled the driveway in,then could have run your boxblade rippers and rip drive lightly before put rock down(helps tie it in).
    If it was my drive here would run a white rock base pack down some then come back with something like a small blue rock,its packs nicely and no dust or top it with oil sand.
    We had a crew come in with a asphalt machine but it was high and didnt do the whole driveway cause couldnt afford it but it was nice,uniform,and the kids love riding the toys down the hill,lol.
  7. #27
    Join Date
    Aug 2008
    Posts
    280
    JD 3320
    I did not pack the sides probably as well as can be as my tractor (jd3320) only weighs about 5000 lbs and I could not work on both sides of the pipe while filling around it.
    I think I will let it pack for a month or so before I run anything big across it.
    So the consensus is to use all of the rip rap to build the edges at the bridge up?
    1978 JD 400
  8. #28
    Join Date
    Jul 2011
    Posts
    2,029
    texas
    kubota M7040 &m7040
    I was talking about adding more rip rap on both sides all the way up,line it solid to keep it from washing,I personally would not wont to mow that slope with a weedeater,I would rock only no grass seed and spray it to keep weeds down. Just my opinion....
  9. #29
    Member
    Join Date
    Apr 2000
    Posts
    42
    NH
    L4740, BX1500
    send some pics of the riprap and crowning. runoff from downpours is gonna be one of your main enemies. That looks like one heck of a hill too.
  10. #30
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    13,675
    Missouri
    Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
    We had to do this in a couple of places due to erosion where we had ditches, without it, we just kept "repairing" the washouts. Most of our roads don't have ditches.
Similar Threads
  1. Creek Culvert Project
    By TNhobbyfarmer in forum Projects
    Last Post: 06-01-2007, 09:47 PM
  2. Pond - New Culvert Project
    By tractordk in forum Projects
    Last Post: 05-16-2007, 05:39 PM
  3. Bridge project
    By MikeD74T in forum Projects
    Last Post: 09-29-2006, 09:44 AM
  4. Culvert Project
    By FL_Cracker in forum Projects
    Last Post: 07-08-2005, 10:06 PM
  5. Culvert Project
    By Harv in forum Projects
    Last Post: 04-04-2001, 02:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
