for now, i just pull 2 pins and then 2 bolts that hold the gear box onto the frame. which drops the PTO shaft, gear box, and auger bit. (gear box is the heavist) splitting them up i can man handle them and just lay them down on a couple pallets. but i really need to get a chain hoist and toss attach it to a beam in the shed. so i can just backup, hook up chain, undo hitch, and let it hang.
pending on how i am feeling / worn out, i may go as far as undo bolt were pto shaft hooks up to gear box, and then undo the shear bolt / pin that holds the auger bit to the gear box. to make things more lighter to move around. ya it takes a few more minutes to undo a couple bolts / pins. but not about to kill myself either. or need to take pain meds after moving it.
