Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jul 2012
    Posts
    2
    ardmore,OK
    Troy-bilt
    Default What is my Troy-Bilt tiller??
    I have purchased a bargain priced Troy-Bilt tiller cultivator. It does not have the swing-away pto, it is strictly a tiller.
    It is powered by a Kohler Magnum 8. I need to figure out how old it is & obtain owners manuals and parts lists. It starts and runs and tills pretty well. It needs new tines & the drag-bar/depth control is missing. Any help would be appreciated.
    Thanks....bigbird73401
  2. #2
    Join Date
    Sep 2005
    Posts
    164
    Page County, VA
    Kubota L3901, L3130, L225
    Default Re: What is my Troy-Bilt tiller??
    If is is a Troy-bilt, there should be numbers on the top or side of the transmission housing and post back. You may have to clean off dirt or grease to find it. Is it a cast or stamped steel trans housing?
    '06 Cummins 5.9, L3901HST, L3130HST, L225, and too many toys... Err...attachments to list.
    MEP 002a/003a generators (6)
  3. #3
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    I've found deals on tines on ebay. It is likely a Horse model. You're lucky to get that engine. I would contact Troy Bilt for the manuals and such. I would google for the parts. You should have a dealer near by, stop in and see if they can help.
    I have Horse model I bought in in 1973, I've been though 3 or 4 sets of tines and an occassional spark plug and 1 drive belt and it still runs great. The
    original invoice shows I paid $326 dollars for it.
    Dainger is right, you're going to need that serial number.
    I'd like to have a Big Red, but for $2,200 dollars I'll stick with my Horse.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  4. #4
    New Member
    Join Date
    Jul 2012
    Posts
    2
    ardmore,OK
    Troy-bilt
    Quote Originally Posted by dangier_VA View Post
    It is definitely a Troy-Bilt...the serial number is stamped on the right top side of the cast iron transmission case 207012 M
    The number stamped on the post on top of the transmission is TH1261.
    The number on the rear of the transmission cover is TH10031.
    There is a number on the left of the transmission cover 182.
    Bigbird 73401
Similar Threads
  1. Troy Bilt tiller
    By Ivan49 in forum General Lawn & Garden
    Last Post: 03-02-2012, 08:39 AM
  2. TROY BILT BUILT TILLER
    By JDAILEY in forum Rototillers
    Last Post: 02-21-2012, 03:46 PM
  3. Troy Bilt pony tiller
    By steviep in forum Rototillers
    Last Post: 06-07-2011, 12:37 AM
  4. troy bilt tiller model #
    By willamkodiak in forum Parts/Repairs
    Last Post: 05-30-2009, 08:06 PM
  5. troy bilt tiller
    By jweaver in forum Rototillers
    Last Post: 04-27-2009, 01:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
