Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    Default Re: Advice on box blade usage
    I think a few loads of top soil delivered to the spot would give you something to work with.
    If pigs have been in that spot for a while the nitrogen content in the soil is gonna' be out of site. Grass likely will not grow, don't ask how I know this.
    Can you move the pigs to another location like maybe your freezer?
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  2. #12
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I use a landplane for this type of job works fast and easy to do. First picture is of a harrow I started with for smoothing and covering seed. Second pic is of the 8' landplane and third and fourth are pictures of a grade done with the fel and landplane.
  3. #13
    Epic Contributor
    Join Date
    May 2004
    Posts
    25,927
    Northeast Ohio
    Kubota B2910, Simplicity 18 CFC, Cub Cadet 782
    Quote Originally Posted by joshuabardwell View Post
    ... and I'd still like to hear any input on how to grade the area reasonably smooth again for planting without eventually unearthing my fence line.
    Sounds like you're going to have to move soil back to the fence line to build it up ....
    My technique for smoothing areas - which I was given by another TBN member - is this:
    Go in overlapping circles and figure 8's ..... the key is varying the pattern so that any given piece of ground is attacked from variety of angles and directions.
    Start with the boxblade all the way down to fill in any obvious deep ruts or holes (and to fill the box)
    Then raise it bit by bit, as the area becomes smoother, until it is just resting on the surface .... on my kubota B2910 that between 4 and 5 on the position control lever - 4 is on the ground, 5 is just above it .... and will drop material.
    BTW - how big of an area is this ?
  4. #14
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by Mark Page View Post
    Already been done. Actually, these pigs are for our customers' freezers, but same difference. The place should have at least a few months rest before new pigs are on it. Depending on what feed prices do in response to the drought, we may actually sit the next season out. It'll be sad not to have piggies here, but it doesn't make sense to do it if we lose money.
  5. #15
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by rswyan View Post
    Thanks for the advice. In answer to your question, it's not too big--about 50'x40'. You can see it in the attached photo.
    Advice on box blade usage-8-15-2012-10-51-a
  6. #16
    Epic Contributor
    Join Date
    May 2004
    Posts
    25,927
    Northeast Ohio
    You're quite welcome.
    Got it.
    It's certainly do-able in that area .... just be mindful of the fence
    You'll be limited as to your travel path in the corners and on the edges - if you need to fill there, dump it in, in 4" to 6" lifts, and then run over it with the tractor while you have the FEL on and bucket full to compact it.
    After that if you can drop the FEL nearby while you are blading the area it will make it a little easier - just remember without the weight of the FEL on, the front wheels will probably lose traction pretty quickly with a full box.
    Looks like we are operating similarly sized tractors - you running a 60" boxblade ?
  7. #17
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Nah--72". I really wanted to thoroughly cover my tracks and be able to get up against stuff like the fence or shed. It does get a bit too full at times and I have to raise it up to get going again, but it does the job.
  8. #18
    Epic Contributor
    Join Date
    May 2004
    Posts
    25,927
    Northeast Ohio
    Right - our tractors appear to about the same physical size - but you've got about 1000 lbs more weight than I do - which should help traction-wise.
    Yup - same deal here with my 60" Woods ....
  9. #19
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,900
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Joshua, I would probably have a dumptruck load of top soil (or ever how many loads are needed) brought in and just spread it out over the holes. I think you would be a lot happier with the results going that route. Of course, as soon as you get it smoothed up, plant some grass right away and water it. Once it comes up, it should help prevent erosion. Good luck!
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  10. #20
    Gold Member
    Join Date
    Mar 2012
    Posts
    273
    Chesterfield, VA
    LS3037H
    Can you move the pig area to the left of its current location to the grassy area away from the fence to let them level out the new area?
Similar Threads
  1. Box Scraper box blade advice
    By digger2 in forum Attachments
    Last Post: 11-10-2015, 12:24 PM
  2. Box Scraper Need some advice\recomendations on a cutter and box blade for an L2800.
    By clovergamecock in forum Attachments
    Last Post: 02-22-2007, 07:20 PM
  3. Grading Box blade usage
    By Erniel29 in forum Owning/Operating
    Last Post: 10-31-2005, 06:14 PM
  4. Advice on a used Tractor Supply Box Blade ->>>
    By PapaPerk in forum Attachments
    Last Post: 11-11-2004, 09:59 AM
  5. box blade advice
    By KJN128 in forum Attachments
    Last Post: 07-27-2002, 09:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
