Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Join Date
    May 2001
    Posts
    336
    Summerside, OH
    NH TC33D; RTV900; Gravely Professional
    Default Re: Making a pond with a tractor ?
    Ron--
    Sorry for using code. A keyway is a slot under the (or just the bottom of the dam--hard to find words) which goes well below the deepest point of the pond bottom. Clay is layered into the keyway and then built up to the top of the dam. The end result, in our case, is that for a pond 12' deep at the middle, the dam is a bar of clay about 20' +/- from top to bottom. Even if hydraulics somehow ate away the entire side of the pond on the dam side so that it had a flat bottom, water would not be able to migrate under the dam. Also, the keyway interrupts two rock strata so that water can't wick along the rock and permeate the dam. I was able to find a photo of our keyway in mid-work which shows the concept.
    Attached Images Attached Images
  2. #22
    Epic Contributor
    R.I.P.
    jinman's Avatar
    Join Date
    Feb 2001
    Posts
    21,014
    Texas - Wise County - Sunset
    NHTC45D, NH LB75B, Ford Jubilee
    Rick, your advice is right on target in my opinion. Your "keyway" picture tells a story that is undeniable. Can you give us some details as to pond size, cost, and what type of overflow pipe you put into the dam? Also, was there a natural gulley you dammed up or did you have to excavate?
  3. #23
    Join Date
    Jul 2002
    Posts
    72
    North Alabama
    L3710DT, 4wd, R4's
    Eventhough I would love the seat time, my opinion is that you're better off getting a dozer to do it, particularly with it being spring fed.
  4. #24
    New Member
    Join Date
    Dec 2001
    Posts
    20
    CT (Central & NW)
    JD4300, JD240, JD335
    Jim you must be staying up too late, at 10 minutes per yard it would take 733.33 hours to move 4400 yards.
  5. #25
    Join Date
    Feb 2002
    Posts
    540
    Mukwonago, WI
    BX2200, '52 8N
    Yeah that would only be like 92 days at 8 hours a day.... [img]/forums/images/graemlins/shocked.gif[/img]
  6. #26
    Join Date
    Jun 2003
    Posts
    148
    Central California Foothills
    Kubota 3410
    Thanks for all of the input. Hopefully next week I will have another estimate or two. Will also try to take and post some photos if I can figure out exactly how to do that. Maybe my daughter can teach her dad how to create a web page where I can post photos and progress on projects. Re Fish and Game - I will check that out carefully - I have heard that putting in a pond without their "permit" could present a problem. The person I obtained the first quote from said that they were easy to work with here and encouraged pond building. . . but I will proceed carefully.
  7. #27
    Join Date
    Jul 2001
    Posts
    1,076
    Cooke County, Texas
    JD4320 with TNT, electric diverter, cruise control and air suspension seat.
    You should check out www.pondboss.com.
    It is an excellent site for information about tanks and ponds. It also publishes a magazine about ponds & all the aspects of building, maintaining and stocking them.
  8. #28
    Gold Member
    Join Date
    Apr 2003
    Posts
    308
    Grayson County TX
    Kioti DK35
    The town of Whitesboro TX is about 4 miles from our place. My wife noticed and pointed out the PondBoss office the last time we went into town.
    I'm so glad they are close by, because the 1/3 acre pond I have is just not big enough [img]/forums/images/graemlins/smile.gif[/img] Someday, I'll grab someone there and let them tell me how to expand it properly [img]/forums/images/graemlins/grin.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
