Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Gold Member LHS Inc's Avatar
    Join Date
    Nov 2010
    Posts
    357
    Eastern Shore, Maryland
    JD 3520 eHydro w/300CX FEL
    Default Re: Rate this Slope
    Quote Originally Posted by creekbend View Post
    I tend to agree with the other members in regards to the difficulty. By reviewing the posted pictures, I, personally don't perceive any problems due to the slope.
    Thanks for all the replies so far. I will say the second time mowing felt more comfortable than the first.
    JD3520 eHydro, 300CX FEL, Frontier RB 1172 6', Frontier CA2060E, Frontier RC 1060, LandPride FSP 1000 3pt Spinner Spreader, Leibach 6' Disc, Leibach 2 bottom plow, Ford 5' 3pt finish mower, Kubota ZD-28, Gravely 14 hp 50" walk behind, Stihl Trimmers and Pruners, Diamond 18' Landscape Trailer, 13' High Side trailer, 2001 Chevy 2500 HD 4x4, 2000 Chevy 1500 Z71, JD4010, 3210 Bush Hog 10' Rotary Cutter
    IF YOU DO WHAT YOU'VE ALWAYS DONE YOU"LL GET WHAT YOU"VE ALWAYS GOTTEN.
  2. #12
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Quote Originally Posted by LHS Inc View Post
    In retrospect, it is much better to be Safe than Sorry. Just a suggestion? Have you ever considered purchasing a Tiltmeter? They aren't very expensive and are even listed in TBN's Store. There are several threads and posts in regards to them.
    The PUPIL who does not surpass his Master, fails his Master.
  3. #13
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Mow it however you feel the most comfortable. Slopes can be decieving until you start across it. Another thing if you keep you fel on keep it as low as you can.
  4. #14
    Platinum Member Mark Page's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Maryland
    Massey Ferguson 2615 48hp, 4wd, loader
    I have a pc. of pasture that I mow occcassionally. The back end of which is 26 degrees. It levels out to 12 degrees at the front. I have no problems side hilling the 12-16 degree slope, from 17 degrees to 21 degrees I mow down hill with the throttle closed, the rest I leave for the deer.
    Sometimes I think it might not be a bad thing that these machines don't have 4 wheel brakes.
    I wouldn't think twice about mowing your hill side hill or up and down.
    Gear Up and Throttle Down.
    2011 Massey 2615, 7ft Woods Rear Discharge Finish Mower, 6 ft Lucknow Snow Blower, Danuser post hole digger with 12" and 24" augers, 350 lb 3 pt broadcast spreader, 7ft scraper blade, 7 ft. drag harrow, JD GT 275 rider with 38" snow blower attachment.
  5. #15
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by Misfire View Post
    What slope?
    Around here we call that flat land.
    Unless that pic is very deceiving, you should have no problem mowing that up, down, or across.
    +2 You don't know how good you've got it. There will come a time though when you reach the limits of your tractor set up. That is when you have to be paying attention with your ROPS up and your seat belt fastened. Take care.
  6. #16
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Looks like an easy slope to mow, I have way steeper places to deal with in my locale.
  7. #17
    Join Date
    Jan 2010
    Posts
    66
    JD5045e
  8. #18
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    2,105
    Northeastern Minnesota
    Kubota M7-171, Kubota M110GX, IH 4386, IH1486, Case 301.8, Kubota L6060, plus many others
    Default
    I often hear people talking about tippy CUTs but I haven't seen many pictures. Is there a thread where everyone posts their tipped over tractor so we can see what it takes?
    Kubota M7-171, L6060, RTV 900XT, GR2120
  9. #19
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,197
    Branson, Mo.
    Kioti DK35se Hydrostat
    Well I will add my 2 cents. Compared to what we have here in Branson, That looks pretty good. Sure better safe than sorry, and take all due precautions, There is no reason not too. Also look out for unseen rocks on the high side and holes on the low side that can make things worse. But like one of the guys said, that looks like what we call flat land around here. If you keep your bucket low and have filled tires, a lot of the time the tractor will slide sideways first before it would tip. Be ready to steer down hill, make sure you are in 4wd to prevent the back tires from breaking loose on damp grass and causing the tractor to run away. Be safe and have fun.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  10. #20
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,373
    Lancaster County, PA
    Kubota L3200, Ford 1210
    What you see and what you feel are often two different things. Below (hopefully) is a shot of a small piece of the approx. 5 acres I used to mow for my MIL. The picture shows it to be a lot more tame than it felt. There were a few other areas similar to but not as bad as this. When we mowed for Mom, I'd have my #3 Son on the B7500 doing the flatter stuff.
    Although the little Ford is almost tip-proof with the 5' deck behind it, that slope is about the limit for what i care to do sidehill. With anything other than very dry grass, the tractor would crab its way along the section where I am in the picture. Even so, it required one cheek on the left fender.
    The ground is about 18" lower on the left side of the concrete wall at the left of the photo. It's very nearly flush on the upper side. A few times the mower pulled the tractor sideways while making the cut at the bottom and the deck slid over the wall. At least twice the kubota had to come to the rescue with enough chain for #3 Son to be on the flat above.
    Rate this Slope-moms-slope-jpg
Similar Threads
  1. Too much slope
    By lakngulf in forum Trailers & Transportation
    Last Post: 12-11-2009, 06:11 PM
  2. What is the going rate....
    By warhammer in forum Rural Living
    Last Post: 05-06-2008, 12:38 AM
  3. what the going rate
    By daddy723 in forum John Deere Buying/Pricing
    Last Post: 02-22-2008, 02:08 PM
  4. What's the going rate?
    By Rowski in forum Related Topics
    Last Post: 09-09-2002, 06:01 PM
  5. Slope
    By stevewilli in forum Kubota Buying/Pricing
    Last Post: 12-09-2001, 10:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
