Results 21 to 30 of 34
08-22-2012, 07:27 AM #21Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,851
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
Re: Rate this Slope
We have a lot of slopes and they are hard to gauge in pictures and even looking at them on foot at times as opposed to from the seat. I doubt that I will ever get "comfortable" on some of our slopes no matter how many times I mow them; maybe that's a good thing, keeps me careful.
I've found the more you use a tractor though and more slopes you encounter the less uncomfortable you get, I do notice my going from a big tractor to a smaller one always makes the smaller one feel more tippy.
08-22-2012 07:27 AM # ADS
08-22-2012, 09:30 AM #22Veteran Member
- Join Date
- Mar 2009
- Posts
- 1,067
- Location
- Lee, IL
- Tractor
- John Deere 1070
Re: Rate this Slope
I don't have 4wd, but I thought that I had heard somewhere that it was better not to use 4x4 on a side slope. I thought it was better to slide a little than to grab because that may be the cause of tipping. I could see going down a hill 4x4 would be better because then you have 4 wheel braking/ engine braking.
08-22-2012, 09:33 AM #23Veteran Member
- Join Date
- Mar 2009
- Posts
- 1,067
- Location
- Lee, IL
- Tractor
- John Deere 1070
08-22-2012, 09:37 AM #24Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,851
- Location
- Missouri
- Tractor
Re: Rate this Slope
We started out with a new 2WD Massey Ferguson 375 and traded it in on a 4WD Massey Ferguson 375 in a few months, so our experience was a 4WD worked better. The only time I ever lost control of a tractor on a slope was with that 2WD tractor; didn't turn over, but scared the snot out of me.
I don't know if our experience is indicative of anything, just what works best all around for us.
08-22-2012, 09:59 AM #25Member
- Join Date
- Jun 2012
- Posts
- 36
- Location
- buckhannon,wv
- Tractor
- johndeere770 johndeere318
08-22-2012, 10:38 AM #26Super Member
- Join Date
- Feb 2008
- Posts
- 7,866
- Location
- somewhere usa
- Tractor
- stuff
Re: Rate this Slope
cobb71,
If you do much of that stuff Just be safe, fix your rops.
08-22-2012, 11:11 AM #27Veteran Member
- Join Date
- Nov 2011
- Posts
- 1,123
- Location
- Near Winnipeg, Mb, Canada
- Tractor
- John Deere 2305, 2320,Z465
Re: Rate this Slope
Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
08-22-2012, 11:26 AM #28Veteran Member
- Join Date
- Feb 2011
- Posts
- 1,743
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
Re: Rate this Slope
take your time and do what you feel is safe. as you get experience you will end up pushing things more and more. hopefully not to point of rolling tractor.
for myself on steeper hills, mowing up and down is not really an option at the road side ditch. and take the hills at an angle.
i will go slower on steep hills for sure. slower i go less chance of when hitting a bump on high side or going into a hole on the low side. and all of a sudden tipping over. the slow speed gives me more reaction time to correct things.
i rarely will drive across a steep hill. to much can go wrong way to quickly. steep hills for me are any were from 25 to 45 degree angles.
have rear tires filled with a fluid can help reduce COG further down on tractor. vs adding weights higher up on the tractor. to help reduce tipping over.Ryan
08-22-2012, 12:01 PM #29
08-22-2012, 01:53 PM #30
Re: Rate this Slope
I stopped my tractor on my side slope and climbed off. I put a large carpenter's protractor across the rear end with a level and determined that my slope was around 20-22 degrees. It felt very tippy to me. Then I put a hand on the roll bar and pushed. I found I could just barely lift the back wheel of my BX. Knowing that I'm sitting higher, that shifts the COG even more. I mounted 50 lbs of wheel weights on each side for good measure and that helped. Tires were already loaded.
Keep it low and just go slow!
Similar Threads
Too much slope
By lakngulf in forum Trailers & TransportationReplies: 14Last Post: 12-11-2009, 06:11 PM -
What is the going rate....
By warhammer in forum Rural LivingReplies: 10Last Post: 05-06-2008, 12:38 AM -
what the going rate
By daddy723 in forum John Deere Buying/PricingReplies: 4Last Post: 02-22-2008, 02:08 PM -
What's the going rate?
By Rowski in forum Related TopicsReplies: 19Last Post: 09-09-2002, 06:01 PM -
Slope
By stevewilli in forum Kubota Buying/PricingReplies: 11Last Post: 12-09-2001, 10:39 PM
