Results 1 to 10 of 12
08-26-2012, 10:14 AM #1Member
- Join Date
- Aug 2012
- Posts
- 30
- Location
- orlando fl
- Tractor
- scag turf tiger 61", gx95, sold f525
quick attach backhoe bucket on deere 110 tlb
hello. I am looking to buy a 110 tlb, and came across this 30" bucket, whick looks like it would fit the 110, but the part # and cubic ft cap. does not match. Its a really good price, but if its not for a 110 with the quick coupler, then it would be nothing but a several hundred pound paper weight (that I would have to move by hand at this point) could any current owners give me measurements as to the outer (or inner width) of the two hook up 'rails' and also maybe the distance from the center of the round notch (up front) to the center of the beveled notch at the back. I would have to assume if the hook up width and lenght are the same then it should work. thanks to all who read and or reply.
08-26-2012, 11:38 PM #2Super Member
- Join Date
- Feb 2008
- Posts
- 7,737
- Location
- somewhere usa
- Tractor
- stuff
Re: quick attach backhoe bucket on deere 110 tlb
I can check this out in the morning for you.
08-27-2012, 08:53 PM #3
I just went out to the tractor and made a quick measurement in the dark. I got 9 7/16 on the outside and 8 3/16 on the inside of the mount. The bucket is on the tractor, but a quick(not exact) tip to center of the radius of the round mating section is about 2". I hope these measurement will help you. I did not measure from the center to the beveled notch. That bucket sure does look like the same design. hope it fits.
2009 JD TLB 110, Box Blade, Forks
MF 1650 garden tractor
JD870 gone
08-27-2012, 09:48 PM #4Super Member
- Join Date
- Feb 2008
- Posts
- 7,737
- Location
- somewhere usa
- Tractor
- stuff
On mine the inside and outside width is the same as ugo4it but the round mating section is approximately 3" diameter. Be aware that there are two different models of adaptors for the 110. I should also note that I didn't see a listing for the 110 with the LVA 13360 and I looked at all the 30" QA buckets.
08-30-2012, 10:19 PM #5Member
- Join Date
- Aug 2012
- Posts
- 30
- Location
- orlando fl
- Tractor
May I ask what you mean by there are two different models of adapters for the 110? Is it production date specific? Would they both look the same? Also I got a reply, but not really an answer from someone at johndeere.com/ parts help. They stated that they can not find that part # anywhere, so they feel it must be part of a 'package' or bundle, then proceeded to tell me they they (in the parts dept) can not look up packages/ bundles. I would like to thank you for the measurements you did get.
08-30-2012, 10:42 PM #6
Just to be clear I believe the dia. of the shaft on my bucket would be about 3" also. I was giving a reference from the top tip to the center of the shaft(bolt) but a quick(not exact) tip to center of the radius of the round mating section is about 2" My TLB is a 2009 and I can make more measurements if you need, a few more number and you should be sure. That bucket sure looks like it would fit.
JD870 gone
08-31-2012, 06:51 AM #7Super Member
- Join Date
- Feb 2008
- Posts
- 7,737
- Location
- somewhere usa
- Tractor
- stuff
I bought the 110 new in 2005 with pin on buckets then in 2010 I found I needed to change over to QA style to add the PA30 auger. That is when the issue of two QA styles came up and had to determine I was getting the correct models so it would all match up. I suspect that the bucket you have pictured would work on the later model QA adaptor which is what I have. I haven't seen the older style up close to know what the difference is. If in doubt I would get the backhoe first and then add the buckets when you know for sure what you need.
08-31-2012, 11:38 PM #8Member
- Join Date
- Aug 2012
- Posts
- 30
- Location
- orlando fl
- Tractor
I would like to thank you (all) again very much for everything you have done. I have added a picture with a line illustrating the last measurement I would like. this should be the deciding factor. I guess I will just take my chances if there are more than one q/c styles. I am just concerned that this could be from a larger piece of equipment like maybe a med size excavator, and not be able to use it. I would not do any heavy digging with it, just some light scraping and shapeing, along with some other outside the box uses with it. please have a wonderful weekend everybody.
09-01-2012, 08:32 AM #9
JD870 gone
09-01-2012, 08:39 AM #10
Similar Threads
JD 110 TLB loader bucket/joystick problem
By courtney chalker in forum Owning/OperatingReplies: 2Last Post: 10-29-2011, 02:18 PM -
jd 110 tlb 4 in 1 bucket problems
By doradog in forum Parts/RepairsReplies: 5Last Post: 02-24-2010, 11:05 AM -
Snow bucket for 110 tlb?
By ME83 in forum John Deere Buying/PricingReplies: 8Last Post: 11-20-2009, 08:29 PM -
430 Quick Attach Bucket to skid steer attach
By CLinton_in_FL in forum John Deere Owning/OperatingReplies: 3Last Post: 07-17-2006, 11:57 AM -
110 tlb bucket interchangeable
By 4710and110TLB in forum John Deere Owning/OperatingReplies: 4Last Post: 01-31-2004, 12:32 AM
