Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
  1. #11
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,245
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    Default Re: Post photos of your improvised tool box for your SCUT
    Quote Originally Posted by lost in wisconsin View Post
    WOW
    That is sweet. I would be afraid to put my chain or any sharp tools inside of that fearing I might actually scratch it.
    Again, very nice fabrication.
    Thank you very much. When I purchased our kubota 5740 last year I fabricated a similar one for it but this time I went with a bumper/shackle center design with quad flash L.E.D. oval strobe lights in it. I use the FEL tubes for tow slings and they are kept in there by machined aluminum caps that I made. You'll notice the caps on the FEL, they are black. Never enough room on a tractor but this system works for me
    For the longer items I needed to carry I went with these rubber clamps and this is how it looks.
    ...Excellence is not a skill. It is an attitude...
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  2. #12
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    Quote Originally Posted by Don87 View Post
    With my hands............SWMBO, drives the tractor
    I can't find the photo's right now, but if you have the ballast box.......which you should..........stand up pieces if 4 inch drain pipe , in the corners, before you fill the box with concrete. Instant tool holder
    So... are you walking behind SWMBO?
    I don't have a Ballast Box yet. I don't have anything on the front of the tractor. When I make one, I'll definitely put some drain pipe in the corners.
  3. #13
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    Quote Originally Posted by roush9799 View Post
    Maybe you could clamp a piece or 2 of pvc pipe to the Rops and slide the handles of the tools in there. For a toolbox on my 2520 I have been eyeballing the space between the rops behind the seat. Just need to find a box to fit there. I usually like to carry a putty knife, knife and a few hand tools when mowing around the farm. That baler twine sneaks up and wraps my blades and I have to cut it off. Went to net wrap last year, my twine problem is slowly going away.
    I have a friend who put plastic pipe on the ROPS. I'd like to see some photos of other's installations. We have some great ideas in this community.
  4. #14
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    Attachment 279003Attachment 279004Attachment 279005Attachment 279007
    Good morning,
    This is what we did for our 2520. I wanted something that mounted behind the seat yet did not create an interference with the seat or the 3 pt arm. My preference would have been plastic but I found this generic metal toolbox at our local Fleet Farm.
    I did paint the box as the green on it was closer to an Oliver green vs JD. Not a big deal. The installation was quite basic in that I used an existing hole on the rear frame and then similar to the extinguisher mounting, drilled a hole on the left hand side and used a #12 self tapping screw. Once it was secured to the frame, I added a rubber mat at the bottom for less rattle. I did need to add some washers/spacers on the SMV sign in order that there would be no interference with the opening and closing of the lid.
    The toolbox measures 16 x 6 x 6. The main reason for the toolbox was to have a place for my chain, my kubota tow strap and a few tools (channel locks, vice-grip, & screwdrivers).
    I love what you did. I have less space between the SMV sign and the back of the seat than you do, but I could shift a box to the right side. Thanks for sending the info.
  5. #15
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    I dont know if you have a ballast box or not but as Don noted, we also carry our tools in PVC pipes installed in our ballast box
    I don't have a FEL, but if I get one, I like the ideas I see on your ballast box.
  6. #16
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    Quote Originally Posted by grnspot110 View Post
    Slightly bigger tractor, but this is what I have on my 790:
    Plate w/ tubes for hammer & big screwdriver/prybar.
    Attachment 279021
    Ammo box clamped to loader frame.
    Attachment 279022
    Chain tray between grille guard uprights.
    Attachment 279023
    Ballast box has scrap iron in it, tray about 8" down from the top is old galvanized grainery door. chainsaw sleeve on one side & tubes for axe, shovel, rake, etc. on the other side.
    Attachment 279024
    Attachment 279025
    Your chain tray on the front looks like something I could do. The frame in the front has room for 4 suitcase weights, but I don't usually have them on the tractor. I don't have a grille guard, so a tool box on the front frame would act like a bumper.
    I don't have room for the other ideas, but I like them.
  7. #17
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    Pixguy - looking good! How much weight do you figure your ballast box will give you?
  8. #18
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,492
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    I keep a rake, peevy, or iron bar in the loader torque tube or the grapple tube. My not so fancy tool box sits on a shelf I put across the fenders and supported by two pieces of light angle sandwiched on the rops
    Attached Thumbnails Attached Thumbnails Post photos of your improvised tool box for your SCUT-stump1-jpg   Post photos of your improvised tool box for your SCUT-sawshelf_1-jpg
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  9. #19
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    Quote Originally Posted by herringchoker View Post
    The pipes work great for shovels, etc. Don't forget drain holes in the bottom so water doesn't collect. Here's mine.
    I like that hitch attached to the ballast box. Great idea!
  10. #20
    Member
    Join Date
    Mar 2012
    Posts
    38
    PA
    John Deere 2305
    4shorts -
    Amazing!!! That latching system is sweet.
Similar Threads
  1. Grading Rear weight box/tool box for PT-425
    By KentT in forum Power Trac
    Last Post: 05-07-2015, 08:48 PM
  2. Replies: 20
    Last Post: 05-09-2010, 03:27 PM
  3. Box Scraper Rankin box scraper for SCUT.
    By newbomb_turk in forum Attachments
    Last Post: 04-30-2009, 01:37 AM
  4. Replies: 7
    Last Post: 12-17-2008, 05:28 PM
  5. Wimpy NH tool tray replaced with tool box.
    By Osconda in forum Customization
    Last Post: 07-03-2006, 11:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
