adjustments to short end top links to have 2 on each end.
fill like a kid in a candy store, and told to get as much as you want and what ever you want....
been thinking hydraulics. and more so hydraulics ran in shops, and factories. i thought about making "loops" that go all the way around machine. this could possibly allow for "smaller diameter" piping, and help balance pressure / GPM of hyd oil through out the system.
figure the pipes could be placed one on top of one other. with some "pipe holders" holding the pipes to some stand offs. i am going to assume some implements / STB setups going to require power beyond, and various valving setups. so there would need to be a way. to easily TEE into these main hyd lines. and come off of them for the valves and like. perhaps the supports that come up from the frame. turn these supports into actual TEE's themselves. and just place a end cap into the TEE. and let customer choose what they want as far as what they want for valving and were they want the valves.
example i would assume someone might want "power beyond" type of setup. to connect 2 or more 20x8 feet sections together. and just having a single engine out of the 2 sections running everything.
some may want some sort of electronic valve (proportional valve), with a "manual override" for attaching / UN-attaching implements.
some may not need / want short end hydraulic links.
i could almost see someone might wanting a pipe that loops around an entire section, and have a hyd accumulator on that line.
i would assume what ever way the engines were pointed more specifically the variable displacement pumps were nearest to. that the hyd to the "transmission/s" would be tee'ed off and sent down. (closer the better)
the entire machine would look like a triangle on wheels. if it had implements on both 20feet sides that were folded up. but how many degrees do these implements fold back into the center of the machine? "clearance"
with links being below the main frame. i would imagine 45 degree would be MAX, but what about 67.5 degree angle. i do not know about that 67.5 angle. would still most likely place most of the weight of implement in transport mode onto the links. vs allowing the implement to rest on top of the STB.
stating links are below main frame. someone may want for what ever reason. move a link or links to above the main frame. it would be nice to see say 8" maybe 10" inches all the way around the top of the frame. just to "mount" something.
getting off track again...
never really thought about it but 20 x 8 would kinda look like a hay wagon.
i wonder if it would be possible to shrink the "width down" from 20 feet to what ever smaller it could be achieved. just thinking 8 tires that are 1.5 width, 2 feet diameter for 20x8. that would be a lot of ground pressure. something smaller than 20 feet...a smaller width would really help reduce the weight i would imagine.
