Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
  1. #1
    Join Date
    Feb 2012
    Posts
    71
    Newtown, Ct
    Kubota L35 "1998",Kubota RTV900 "2010"
    Default grab chain length
    hey everyone, I just put grab hooks on my L35 loader and now need to get the chain. Without getting too technical, what would a good length be to purchase or make? 10 feet, 15 feet?
    raider.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    bcp
    bcp is online now
    Join Date
    Jul 2009
    Posts
    2,304
    SW WA
    Kubota BX2360
    Default Re: grab chain length
    I found two short ones more useful than one long one. I usually carry two that are 8-10 ft.
    Bruce
  4. #3
    Join Date
    May 2012
    Posts
    2,359
    Knoxville, TN
    Bobcat CT225
    I only have one at the moment. It's 10 feet and has done me well for skidding small (6" max) tree parts to a brush pile and pulling out T-posts from the ground. If I was going to skid larger logs, I'd probably want closer to 15 feet... but hey, maybe not.
  5. #4
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,953
    Yanceyville, North Carolina
    Kubota L4400
    I have several chains in various lengths. In regards to the length, it would really depend on what you are planning to do. I, myself, like to haul a chain with me that is a little longer than what I think that I will need for the intended or planned task. One never knows what one might encounter. I don't like going back to the shop to get another chain because the first one was too short. Most times I have two chains with me. I keep them in PVC pipe on my tractor. Just my thoughts. Everyone does things differently. Best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  6. #5
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    1,538
    Lancaster County, PA
    Kubota L3200, Ford 1210
    I have chains ranging from 4 to 20 feet. It's nice to have a selection plus some things need more than one chain to be used at a time. For instance, to pick an implement it is handy to use one chain as a bridle to hang it level and grab it with a second chain so it can easily be rotated. While working alone, some loads like poles need two points of attachment because they won't balance on their own.
    When in doubt, I grab a longer chain than I think I need. With the bucket attachment method I've been using for the last 10 years the extra chain can be kept out of the way easily by dropping it into the slots that aren't used for the load. The attachments are short pieces of angle with slots that accept up to 3/8" chain. They've seen loads heavy enough to get the rear wheels off the ground and were never affected. Here are pictures showing the buckets of the (now gone) B7500 and the L3200:
    Attached Thumbnails Attached Thumbnails grab chain length-chain-hooks.jpg   grab chain length-level-1.jpg
  7. #6
    Join Date
    May 2012
    Posts
    1,028
    Me
    Mahindra Max28XL HST
    Default
    Quote Originally Posted by chim
    That looks like a great design. It eliminated hooks facing different directions. While u said they worked fine, did u have any concern stressing them in one direction vs. another? It looks like u bolted them in, so a non welder could create the same thing.
    Thanks for the pics.
    "The only thing necessary for the triumph [of evil] is for good men to do nothing." Edmund Burke*
    “If you continue in My word, then you are truly disciples of Mine;and you will know the truth, and the truth will make you free.” Ancient of Days
  8. #7
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,676
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    Start with a couple of ten footers and go from there. You can hook them together for a 20 if needed. With time you will probably end up with a whole assortment depending on what you do with your tractor. To me it is what you need for hooks ( grab, slip, one of each, choker ... ) rather than the chain length that make me go get another one. If you got grab hooks on the bucket a chain with a grab hook on one end and a slip hook on the other would be a good way to start.
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  9. #8
    Join Date
    May 2012
    Posts
    1,028
    Me
    Default
    Quote Originally Posted by Gordon Gould
    Did u see chims angle iron solution? Unless someone points out a flaw, that design seems to be one of the best I've seen.
  10. #9
    Join Date
    Feb 2012
    Posts
    71
    Newtown, Ct
    Chim, that is a great setup. My loader bucket has 3 grab hooks on it. I have not used any chains yet, but will for mostly tree work. Sounds like start with a 10 footer and go from there. Would I put a grab hook on each end or some combination for dragging logs?
    Raider
    thanks everyone for the info. This site is a great source.
    is there spell check on this site?
  11. #10
    Join Date
    May 2012
    Posts
    2,359
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by Raider43 View Post
    There are a few good threads on TBN about bucket mods, including discussions of hooks. Here is a search URL that will get you started.
    The angle iron with slits cut for grab-hooks is pretty clever, since they work both directions, unlike a hook. Also, since they spread the contact point with the bucket out a bit, they may be less likely to bend the bucket--but that's just a guess. The best configuration I have heard of is to have grab hooks at the outside edges and a slip hook in the middle. If you need to use the middle as a grab hook, you just run the chain through the slip hook to one of the outside grab hooks. Another configuration that I like is to have a receiver hitch welded to the center of the bucket. You can then stick a ball in, to move a trailer, or stick a hitch-mounted slip hook, or really anything else that will go into a receiver. Pretty versatile, although you do want to be careful that you don't collapse the top of your bucket.
Similar Threads
  1. New type of chain grab hooks
    By B58Hustler in forum Attachments
    Last Post: 08-03-2012, 09:59 PM
  2. Bolt on chain style grab hooks
    By mike194 in forum Customization
    Last Post: 10-28-2008, 10:46 PM
  3. Source for G70 Grab/Slip Chain Hooks
    By GaryBDavis in forum Trailers & Transportation
    Last Post: 03-26-2008, 07:24 PM
  4. Marking chain length
    By AlanB in forum Parts/Repairs
    Last Post: 10-02-2006, 03:10 PM
  5. Length of chain
    By Richard in forum Attachments
    Last Post: 12-20-2000, 04:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
