Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
  1. #11
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default Re: Gravel driveway maintenance
    Quote Originally Posted by s219 View Post
    I'm lucky that I can adjust my top link from the seat by reaching around back. I know where the max angle is, and set the stop nut there. Then at the end, to lessen the angle of attack for smoothing, back off from the nut by a certain amount (eyeball it). Over time, I bet you'll know where/how to set it by eye.
    I could probably reach the top link from the seat if I raised the implement, but the weight of the blade is enough that it requires some muscle to turn the link. I have found that there is a sweet spot where the box blade is perfectly balanced, and I can easily turn the link. I raise or lower the lift arms until I see the tension come off the top link retainer pin, then adjust the link until it gets tight again. Move the arms. Adjust the link. That way I'm not wearing out my forearms torqueing at the link.
  2. #12
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Quote Originally Posted by joshuabardwell View Post
    That what I did. Adjust some pick it up then let it down and adjust more, the same works on the sidelink. I have to do this on the bx but the implements are light. It needs a tnt.
  3. #13
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    I made an adjustable side link out of a rachet binder with a folding handle. Makes adjustments quick and easy.
    Gravel driveway maintenance-203733d1299992015-adjustable-lifting-link-cat
  4. #14
    Veteran Member troutsqueezer's Avatar
    Join Date
    Sep 2010
    Posts
    1,308
    Pilot Hill, CA.
    Kubota B21
    I maintain about two miles of gravel road. I use the BB most of the time. Occasionally I have to move gravel from the side back to center and I attach my Land Pride grader blade for that. As nice as the grader blade is to use, it does leave a rather tall windrow on one or both sides of the blade depending on whether you are moving gravel from one side to the other or have it 90 degrees to the tractor. In either case, you must make one or two additional passes to smooth the windrow. The box doesn't do this.
    - Dennis
    Once you see the bandwagon, it's too late.
  5. #15
    Gold Member pwright's Avatar
    Join Date
    Aug 2012
    Posts
    386
    San Antonio, NM
    2012 Bobcat CT225
    Quote Originally Posted by Mechanos View Post
    That's clever!
    Phil
    Bobcat CT225 with FEL and Bobtach.
    Landpride box blade, post hole digger and pallet forks.
  6. #16
    Join Date
    Jul 2004
    Posts
    1,986
    Bancroft, Ontario
    JD4300
    Don't have a box blade but do have about 300yds of hilly gravel driveway, so I made a "blade" which is a 3x8 foot rectangle of 4" angle with a bit (500lbs) of extra weight added, plus a few cuts and angles. It gets towed on a section of chain so it can be angled to drag the loose gravel back to the center, maintaining a crown on the road for better drainage.
    Once I spend an afternoon in the spring getting the driveway in shape it stays pretty good for a few years as long as I get a good growth of green holding things in place. I will touch up the odd spot with my bucket, filling potholes, etc but if I don't mess with the grasses and weeds in the center, the track stays pretty good.
    In the winter I am careful not to take too much of the base off so there is a frozen layer of ice all winter that I drop a bit of sand on.
    I'd sooner be working out back than continually fixing my driveway......
  7. #17
    Join Date
    Aug 2012
    Posts
    386
    San Antonio, NM
    2012 Bobcat CT225
    Sounds very similar to a land plane. Any pictures?
    Phil
  8. #18
    Join Date
    Nov 2003
    Posts
    148
    Western Wisconsin
    I use a landscape rake, because it's the only "tool" in my box. It's not the best for moving/leveling road gravel, because it separates the rock from the sand and clay components -- after a few passes, it pulls the rock along while leaving the fine stuff. Pretty soon you have a lot of rock in one area and precious little in others. A rear blade or BB would avoid that, although the rake (especially with gauge wheels) will level it out nicely.
    jim
  9. #19
    Silver Member Ron JD670's Avatar
    Join Date
    Jan 2012
    Posts
    168
    Jacksonville in S. Oregon
    for Cristmas 2011 found used Joh Deere 670 w/ 40 hrs and options
    Default
    One issue that I don't know how to solve is how to keep gravel from spreading off the side of the driveway. If I had a rake or a grader blade, I could pivot it to the side, to pull material towards the center. I wonder if I could cock the box blade slightly to the side with the sway bars to approximate that effect. Would that even do anything, since the material can't fall out the side of the box?
    Another issue with the box blade, that I forgot to mention, is that it just left the big pile of material at the end of the run the pile out and made it harder to pick up and spread back out again after the leveling had been done.
    I did not read anything about angling the box made and it does not appear fro the photos there is much crown to the road so water runs to the edges and does not puddle. If you angle the BB with the side link so it is higher on the side towards the center the BB will tend to leak gravel to wards the center especially were there are deep ruts. The side panel should keep material from going to the outside as noted earlier.
    I like to do the outside first because it is easier to move to the center again assuming there are ruts. This also this tends to be dirtier gravel. Then I level the BB and move the some what cleaner center gravel out to the ruts covering up the outside gravel in the ruts. Someplace a picked up a chart showing a road crown angle of 4" over 7'.
    As for the piles when doing the sides I go up one side and then back down the other so the angle on the BB Is angled to move gravel in towards the center going and coming. Dumping piles as needed as I go. I the use the FEL to back drag and level piles pulling at an angle the towards the center of the road. This may not be by the book but it works for me. I also ha a tooth bar to reduce wear a tear on my FEL edge. It appears the pros us the BB to doz the piles going backwards but I still don't have the skill or neck and back for it.
    Here are some other resources I found when I got started.
    Best wishes
    RoN
    Check out You Tube Search under
    "Using a subcompact tractor to ______"
    The following one is good.
    http://www.youtube.com/watch?v=yoc2Mf5yRZI&sns=em
    Also check out
    Wilsonoutdoors
    How To - Tractor Land Plane - Gravel Road Maintenance - YouTube
    Also there are some very good threads on here on TBN see if you can find these two.
    Beginners guide to using a box blade
    Rear Blade: How to grade a driveway
    Ron JD 670
    Found used JD670 with 40 hrs barned with FEL, 5' Rake, 7' Blade, 9" X 3' Rankin Auger.
    Have added Box Blade, RM, Forks, plus some blood sweat and tears.
  10. #20
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Quote Originally Posted by Ron JD670 View Post
    Regarding the crown, both sides of the driveway are on quite a slope, and it seems to me like a crown would be undesirable in that case. The left-hand side slopes to the "outside" across its entire length, rather than having a crown in the center. The right-hand side is more or less flat, but also quite downhill. This causes water to run down it and make ruts, which I haven't exactly figured out what to do about yet--other than re-dress it before the ruts really get started. There really isn't much of anywhere to direct the runoff to is the problem. The "island" in the eye of the driveway's loop is higher up than the driveway, so directing the runoff toward the left-hand side and on downhill into the field isn't an option. Unfortunately, the driveway is the lowest point on the right-hand side for most of its length, so the runoff is going to go down it. It's just a question of where. If I had my druthers, I would slope the right-hand drive to the left slightly (the "eye" of the loop) and put a runoff ditch lined with large rocks. Then I would put a culvert in to allow that to pass under the left-hand side of the drive. and empty out somewhere near the front of the property. But there are a lot of other projects ahead of that one on the to-do list.
    The other problem I have with the right-hand side drive is it is so steep for most of its length that it seems like it would require a pretty substantial side-slope to overcome the water's desire to run downhill to any significant degree. No?
Similar Threads
  1. Dirt/Gravel Driveway Major Maintenance
    By flyer in forum Owning/Operating
    Last Post: 06-03-2015, 08:45 PM
  2. Gravel driveway help.
    By mjncad in forum Projects
    Last Post: 09-25-2010, 02:21 AM
  3. gravel driveway maintenance
    By apease in forum Kubota Owning/Operating
    Last Post: 06-07-2010, 06:57 PM
  4. Gravel Driveway (again)
    By mntnvew in forum Projects
    Last Post: 10-04-2008, 12:17 PM
  5. Gravel driveway
    By RocketJSquirrel in forum Rural Living
    Last Post: 04-28-2002, 03:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
