Results 11 to 18 of 18
09-20-2012, 07:50 PM #11
- Join Date
- Feb 2011
- Posts
- 8,975
- Location
- Virginia
- Tractor
- yes
Re: Creaper
09-20-2012, 08:01 PM #12
- Join Date
- Mar 2002
- Posts
- 52,712
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: Creaper
yep.. 4spds were tall..
5spds better.. but wasn't untillt he 8spd came out that they finally got a few useable gears... not counting the sos 10spds..
09-20-2012, 08:29 PM #13
- Join Date
- Feb 2008
- Posts
- 319
- Location
- Northern NH
- Tractor
- Kubota B7510HSD(sold) B3200(new 6/15/09)
Re: Creaper
I use the lowest gears on the mf 6290 that I use to pull the mixer wagon while feeding the cows and have MANY times I could use a lower gear. I have to go forward and back a few times while trying to get all the feed out of the wagon in the space available. lower gears would let me do it in one pass.
b3200, 60" land pride finish mower, 3pt log spitter, pallet forks, lawn sweeper, bottom plow, Loader mounted snow plow, 3pt quick hitch.
09-20-2012, 09:50 PM #14
- Join Date
- Jul 2004
- Posts
- 1,986
- Location
- Bancroft, Ontario
- Tractor
- JD4300
Re: Creaper
Sounds like a good thing they invented Hydrostat trannies
09-21-2012, 09:41 PM #15
09-23-2012, 05:16 PM #16
- Join Date
- Jan 2012
- Posts
- 168
- Location
- Jacksonville in S. Oregon
- Tractor
- for Cristmas 2011 found used Joh Deere 670 w/ 40 hrs and options
Originally Posted by Don87
Last week end I was clearing a ditch and it was easier to watch the box blade and the front creeping before I had or created a new problem. I figure I'm so far ahead with a tractor I can afford to go a bit slower.
RoNRon JD 670
Found used JD670 with 40 hrs barned with FEL, 5' Rake, 7' Blade, 9" X 3' Rankin Auger.
Have added Box Blade, RM, Forks, plus some blood sweat and tears.
09-26-2012, 01:26 PM #17
- Join Date
- Jan 2006
- Posts
- 1,147
- Location
- Mass, Northshore, Merrimack Valley
- Tractor
- B6100DT
Re: Creaper
I've also seen implements where a rider (on the implement) manually plants saplings. This is a very slow speed operation.
.Dan C.
B6100DT, FEL, BH
12-04-2012, 12:08 AM #18
Re: Creaper
The creeper gear was to allow high engine speed--whether for running an implement or just for pure pulling power--while giving a lower ground speed.
