Results 1 to 8 of 8
  1. #1
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,183
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default What the Heck!. why is my rotary cutter digging a furrow in the lawn!
    I am just finishing up mowing one of my extreme slopes in the side yard, with the big Kioti because the JD lawn mower wont make it up the hill. I looked back and noticed that the left gauge wheel (I installed them) in my rotary cutter was digging in as I went up the hill. I was apprehensive that probably what had happened was the the keeper pin had come out of the CAT1 link pins and I was dragging the mower up by one lower link.. But looking back while on the tractor, all seemed well. I raised the mower and it seemed to be level, at least as much as I could ascertain from the seat. So I drove to a level area and bailed off of the tractor to see what was broken. It did not take me long to notice a rather large rock that was jammed between the steel wheel and the frame of the mower. The rock of course was preventing the wheel from turning (locked into some of the casting ribs on the inside of the wheel) and was tearing up the ground. Moral of the story is, when something doesn't seem right, get off and check it out!
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  2. #2
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: What the Heck!. why is my rotary cutter digging a furrow in the lawn!
    Good advice.
    The PUPIL who does not surpass his Master, fails his Master.
  3. #3
    Join Date
    Apr 2000
    Posts
    1,798
    North Central Arkansas
    John Deere 4520,
    Quote Originally Posted by k0ua View Post
    James K0UA
    James Branson has beautful rocks and almost all are antique. Put it on shelf to show when some one asks why the gouge in the yard.
    I have rocks the size of a bush hog that keeps getting among my tractor and equipment.
    My Father bought a G.P. John Deere with moleboard plow to replace the mules. And plowing would hang the plow on a rock and steel lug wheels would spin. and could not back up with plow hung. So us kids carried slegh hammers 9 pounders and would bust the rock and load onto a rock float pulled by mules to the side of the field.
    And to think in high school the coach said we were to light weight to play foot ball.
    ken
  4. #4
    Join Date
    Jun 2009
    Posts
    28,183
    Branson, Mo.
    Yeah we have the rocks alright,..In Hawaii they call them Hawaiian "love stones" around here we just call them...uh... rocks
    James K0UA
  5. #5
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    James, do you have a photo of your gauge wheel setup?
    Bill
  6. #6
    Join Date
    Jun 2009
    Posts
    28,183
    Branson, Mo.
    Quote Originally Posted by Notforhire View Post
    Bill
    Actually I don't but imagine some 8 inch steel wheels attached to the front edge of the mower with some Heavy C channel steel bolted thru the mower deck. the wheels are on 5/8 inch grade 5 bolts for hubs. I will try to get some photo's but it may be a bit, as I don't get home until it is dark.
    Florida Casters and Wheels, Inc.*::*Wheels*::*Cast Iron Wheels Product Line*::*CA / CW / CH Premium Cast Iron Wheels: up to 8000 lbs.*::*Cast Iron
    James K0UA
    James K0UA
  7. #7
    Join Date
    Nov 2011
    Posts
    853
    JD 5055E
    No rush on the photos. I don't work that fast anymore. The casters do sound like a good idea.
  8. #8
    Veteran Member LarryD's Avatar
    Join Date
    Mar 2004
    Posts
    1,157
    Whidbey Island, WA.
    TC33D
    I've got the J Bar Scorpion rotary cutter with four gauge wheels. The link is for their finish mower but the guage wheel setup shows better in this picture. The square stock arm pivots on the rear pin and moving the forward pin adjusts the height. The wheel is held by a tube with an ID just a little more than the OD of the wheel riser. A simple U-shaped piece of steel holds the assembly to the square stock.
    Make welfare as hard to get as a building permit
Similar Threads
  1. My Kubota GR2100 is digging up my lawn !!
    By mpt1123 in forum Owning/Operating
    Last Post: 07-13-2012, 07:08 AM
  2. furrow/row marker for rotary tiller
    By tonyw in forum Build-It Yourself
    Last Post: 04-23-2012, 11:27 PM
  3. Attachment for digging asparagus crown furrow?
    By browndd1 in forum Attachments
    Last Post: 02-23-2009, 08:14 PM
  4. Rotary cutter tailwheel digging in
    By Z-Michigan in forum Owning/Operating
    Last Post: 06-26-2007, 10:51 PM
  5. furrow/row marker for a rotary tiller
    By tonyw in forum Customization
    Last Post: 07-09-2003, 11:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
