Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    6
    Yamhill,OR
    New Holland TN75DA, international 544 hydro, d4 cat 7u, minneapolis u,case 300
    Default joy stick w/3rd function switch
    I have a grapple on my loader. I installed an after market valve and it came with a switch that I mounted on the joy stick externally. It functioned well untill it broke. I then installed a rocker switch which works well but doesn't fit the joy stick very well. I would like to find a joy stick with a switch mounted in it and be a lot cleaner and less cumberson. Does anyone have one like that? I searched it and it appears that kubota may have a factory switch but I haven't looked into it yet. Any help would be appreciated.
  2. #2
    Platinum Member CBW1999's Avatar
    Join Date
    May 2008
    Posts
    857
    Northern Vermont on the 45th parallel
    Kubota 7510, Toro Groundsmaster 217D
    Default Re: joy stick w/3rd function switch
    Check E Bay. I've seen different ones from time to time for heavy equipment.
    I have even thought of using a computer joy stick that has extra buttons on it. If the handle portion and switch can be disassembled and mounted in place of what is already on the tractor.
    Purely from a "that would look cool" standpoint- I was trying to figure out just how many buttons I might be able to use. this pic is fairly simple but I have found sticks with too many buttons!
    joy stick w/3rd function switch-flightstick_pro_usb_1-jpg
    I thought the "top hat" would control the top and tilt functions, open and close switches for the grapple/front outlet.... i guess the sky is the limit...and so is the cost! Obviously for each function would require the appropriate electric over hydraulic valves.
    I thank God everyday for all of the blessings he has given me- especially for the one's I do not recognize or see!
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    2,032
    Columbia, SC
    Kubota L3830HST
    WrLong is my recommendation. Look at item #1.
    Spare Parts
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  5. #5
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,839
    South West MI
    John Deere 2030, John Deere 6415
    If your joy stick is hollow JD has several knobs with 3rd function switch that might work.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  6. #6
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,426
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Should be able to get something for around $100.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  7. #7
    New Member
    Join Date
    Sep 2012
    Posts
    6
    Yamhill,OR
    Thanks for all the info.
  8. #8
    Gold Member
    Join Date
    Apr 2012
    Posts
    368
    Pomona Park Florida
    Yanmar EX450, Ford 8N/2N, Case 580C backhoe, Massey 185
    I had the remotes to the front (FEL) when I bought the tractor, and they used WR Long. Well built handle, switch works well.
Similar Threads
  1. ATV winch switch for 3rd function
    By bigballer in forum Hydraulics
    Last Post: 04-13-2012, 12:51 AM
  2. 3rd function loader control switch help
    By B3300SU in forum Hydraulics
    Last Post: 02-21-2011, 10:52 AM
  3. DIY - 3rd function joy stick - kind of
    By Couple of Achers in forum Customization
    Last Post: 11-19-2009, 04:22 PM
  4. 3rd function switch
    By flINTLOCK in forum Owning/Operating
    Last Post: 04-05-2007, 01:16 PM
  5. Another version of 3rd Function FEL diverter switch
    By Beau in forum Build-It Yourself
    Last Post: 01-30-2007, 07:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
