Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,526
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: Is it really never a good idea to spend extra time to get a full bucket?
    Thanks for posting.
    The PUPIL who does not surpass his Master, fails his Master.
  2. #12
    Join Date
    Apr 2011
    Posts
    584
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Wow this takes all of the fun out of using the tractor! The longer you are on the tractor doing fun stuff the less time you are stuck on the honey do list!
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  3. #13
    Join Date
    May 2008
    Posts
    723
    Prince Edward Island, Canada
    Kioti DK45SC
    Quote Originally Posted by john_bud View Post
    Then again, you don't have to worry if you work this fast...
    http://s28.photobucket.com/albums/c2...n_bud/digging/
    It must have been hot working down in that hole. On the 29th, I see it hovered between 108 and 110 all afternoon.
    I was a little surprised that he didn't use the loader on the backhoe; it probably has twice the capacity per load as the FEL on the Kubota.
    BOB
  4. #14
    Platinum Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    993
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by Guesseral View Post
    That's easy. Make them the same list. And then because you were so good at it, you have to haul some away again.
  5. #15
    LD1
    LD1 is online now
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,484
    Central Ohio
    Kubota l3400
    Nice chart.
    What I do All depends on how far I have to move the dirt. As your chart shows, anything closer than 10 seconds and you move more NOT re-striking the pile. And I usually transport in 4th gear. Which is 4mph. in 10 seconds that equates to about 60'. But If I am hauling several hundred feet away, it is worthwhile to make sure you have a full load.
    When the owners manuals mention not re-striking, it is usually in the section about loading trucks and such. In which it DONT pay to re-strike cause they are usually within 20 feet of your pile.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  6. #16
    New Member
    Join Date
    Sep 2012
    Posts
    18
    Murfreesboro, AR
    Ford 550, 1945 Farmall Cub, 1949 Farmall Cub
    Above info is nice to know. I'm trying to move a lot of dirt about 100 years.
    I have a Ford 550 backhoe and I am trying to dig my pond down as deep as I can get it...hopefully 30 or 35 foot. I want to keep the walls as steep as I can with one pathway out (perhaps 200 feet or more long). So far I have been using the front end loader to dig. Would it be better to use the back hoe to pull down dirt from the walls before scooping it up? I can usually get a full load with one or two strikes but the ground is heavy clay with large gravel and it is getting harder. I want the pond deep to give me stable temperature water to use for geothermal system in my future house. Any advise would be appreciated.
    Last edited by Diamondcutter; 10-04-2012 at 01:55 PM. Reason: Should have did a new post.
  7. #17
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    Quote Originally Posted by rd_macgregor View Post
    BOB
    The camera was hotter in the sun. It was probably no hotter than 85 air temp, but sunny and warm.
    Yes, the BH has 2x the capacity per bucket..... but! I can do 5-6 round trips with the Kubota for each one with the old Ford. Plus where the dirt was being placed was on the side of the ramp up and the ground is soft. The 3 rib tires on the ford sink and you pucker so much the seat deforms! That's too much excitement for the old boy...
    Quote Originally Posted by Diamondcutter View Post
    1) You will be LUCKY to keep a 45 degree slope in the water. Probably closer to 30 degrees over time.
    2) Yes, dig with the hoe and make piles in convenient locations for the FEL to scoop out.
    3) learn to strike the pile and while still going forward, raise and full curl the bucket. As the bucket fills, start going backwards. As you back, turn and simultaneously place the bucket at low transport height.
    4) dump with the curl and back up as it's finishing dumping
    5) Avoid spinning tires at the FEL load pile, those holes make you go slow
    6) Keep the transport distance short. I'd buy a cheap used dump truck or flat bed with a dump function and load that.
    here's the type of truck I'm thinking about. $3500
    1986 F-700 Grain Truck
    Is it really never a good idea to spend extra time to get a full bucket?-5ib5fa5j83i73fc3lcca163243d4a05541270.jpg
    7) keep the transport path smooth so you can go as fast as possible
    You may be money ahead to hire a medium size dozer to come out and starting from the center, push out the dirt 400 ft in all directions. You can probably get a guy on "a cash basis" to work 10 hours on a Saturday for 1000. Then you can make the center deeper if you desire.
  8. #18
    Join Date
    Jul 2004
    Posts
    1,553
    Bancroft, Ontario
    JD4300
    I think JB's # 7 should have been closer to the top of the list. Easier on equipment & driver....
  9. #19
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,544
    Ohio
    JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
    Excellent post and effort. Thank you.
    Don't sweat the small stuff...
  10. #20
    Join Date
    Feb 2011
    Posts
    1,743
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    nicely done!
    Ryan
Similar Threads
  1. Would you spend the extra on 2660 vs 2360?
    By newdeal in forum Kubota Buying/Pricing
    Last Post: 04-12-2010, 02:15 PM
  2. Full synthetics a good Idea?
    By ericher69 in forum Kubota Owning/Operating
    Last Post: 01-18-2009, 04:28 PM
  3. Good idea? Bad idea? Buy it or make one myself?
    By Dougster in forum Attachments
    Last Post: 02-16-2007, 02:57 PM
  4. Spend More Of Our Money--On Attachments This Time
    By Anonymous Poster in forum Power Trac
    Last Post: 06-15-2003, 10:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
