Results 1 to 3 of 3
10-13-2012, 04:27 PM #1New Member
- Join Date
- Oct 2012
- Posts
- 1
- Location
- kent
- Tractor
- ford
1994 ford 8340 sle
Hi
i was using a 3mtr power harrow today whilst driving my 1994 8340sle in 5L range with 4wd engaged and diff lock on, suddenly the tractor came to a halt, no noises no nothing it just stopped as though someone had swithched off a light switch, the dash showed fault code E19 however the transmissiomn pressure light had stayed on previous about 2 mins before hand but had gone off on its own just before, the power sreering still works as does the hydraulics and engine,when i engage any gear high or low range the dash shows that i am in gear but the tractor does not move then after 10 secs the "E19 light comes on.
Any Ideas Guys ?
Thanks
11-13-2012, 06:48 AM #2New Member
- Join Date
- Nov 2012
- Posts
- 6
- Location
- lincoln
- Tractor
- ford 3000, 5000, 6640sle
Re: 1994 ford 8340 sle
My 6640 just did the same thing. In my case the lube valve inside the transmission had come apart. Its a small spool type valve that shuttles oil. All the parts will be in the belly of the transmission. Check my post as I'm still dealing with a problem that I think may have caused it. I also had the same codes you talked about. The repairs are fairly simple if you are handy. I have the books on the tractors if I can help you.
11-13-2012, 06:50 AM #3New Member
- Join Date
- Nov 2012
- Posts
- 6
- Location
- lincoln
- Tractor
I just noticed the date on your posting. Have you figured out what went wrong?
Similar Threads
Ford 8340 service manual
By shafiqid in forum New Holland Owning/OperatingReplies: 1Last Post: 07-03-2010, 06:11 AM -
Ford SLE 16x16 transmission problems
By san isidro in forum New Holland Owning/OperatingReplies: 9Last Post: 12-12-2009, 08:05 PM -
Ford powerstar 8340 error codes
By Ndechu in forum New Holland Owning/OperatingReplies: 4Last Post: 12-04-2009, 06:27 PM -
By san isidro in forum New Holland Buying/PricingReplies: 1Last Post: 11-28-2009, 07:26 AM -
Brakes Seizing- 1994 Ford NAA
By Ortis in forum Parts/RepairsReplies: 5Last Post: 03-28-2005, 08:18 PM
