Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
  1. #1
    Bronze Member S Putnik's Avatar
    Join Date
    Nov 2012
    Posts
    58
    Portland, OR
    Yanmar YM336D
    Default How much pto Hp is needed for a 48" brush mower?
    Just curious what is recommended and what one can get away with by slowing down a bit.
    Thanks.
    Yanmar YM336D - "Schlepper" with loader and other toys
    Grow hard or go home!
  2. #2
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,752
    Northern, IL
    Branson 2400H, JD X540
    Default Re: How much pto Hp is needed for a 48" brush mower?
    I ran a 48" bush hog with kubota BX1850. Only issue was front end was light when going up hill carrying the mower. I was cutting grass 12 - 18" high with no brush.
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
  3. #3
    Super Member daugen's Avatar
    Join Date
    Feb 2012
    Posts
    9,889
    Washington NC (Inner Banks)
    Kubota L5740HSTC, MF 2615, MF 1230, IH Super A
    my memory in reading posts here was about 5hp per foot of mower and that was likely for a light load. I used a five foot mower on my 21hp pto tractor and it did fine, but it was not pushed hard. Definitely need front weights; I had to build a weight box for the front of my tractor.
    I found this helpful: TractorData.com - Mowing with tractors
  4. #4
    Join Date
    Jul 2011
    Posts
    512
    SW Arkansas
    Rusty junk
    5hp per foot is the minimum recommended rating. At 5hp/ft you will be dramatically slowed in the thick, tall grass. 8hp/ft and you can breeze right through the thickest of grass or brush.
  5. #5
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,188
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    5hp/foot is the rule of thumb (as has been said). We have a 5' brushhog that we run behind the B7500 (16PTO HP) and our L3830 (32 PTO HP).
    You can bog the L3830 down with a 5' mower, but it takes some doing. The B7500 makes you crawl unless mowing light weeds.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  6. #6
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Quote Originally Posted by S Putnik View Post
    Thanks.
    My research shows these specs on a Shibaura SU1540 that you have listed in your profile. Engine HP-18 PTO HP-15 In my opinion, a lot would depend on the terrain that you are mowing and the type and height of the material that you are mowing. Hilly land requires more power than flat land. Are you just mowing grass or are there saplings present? BTW, best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  7. #7
    Super Member smstonypoint's Avatar
    Join Date
    Oct 2009
    Posts
    6,351
    SC (Upstate) & NC (Piedmont)
    NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
    Check the various manufacturers' recommendations regarding minimum HP requirements. For example, Woods lists a minimum of 15 HP for their 4' cutters: Rotary Cutters.
    Steve
  8. #8
    Join Date
    Feb 2012
    Posts
    9,889
    ditto
    when I was mowing one field with a long incline, it was clear I was taking all the hp out of the engine, and I'd get some occasional puffs of smoke. All normal, but if you are running near the limit, keep an eye on your temp gauge.
    I thought you might find this pic interesting to confirm comments on front weights. When I first got this mower, which is as big as the tractor, it was Land Pride's lightest weight 60", intentionally, since I was mowing field grass, never brush.
    When I raised the mower up, and stepped on the rear of the mower deck, the front wheels of the tractor lifted up. That sure got my attention. 300 pounds of front weights later, all was well.
    Attached Thumbnails Attached Thumbnails How much pto Hp is needed for a 48" brush mower?-p1010615-jpg   How much pto Hp is needed for a 48" brush mower?-p1010308-jpg
  9. #9
    Elite Member
    Join Date
    May 2005
    Posts
    2,662
    Balls Creek, NC
    New Holland Workmaster 50, Ford 4610 SU
    I have no trouble pulling a 5' squealer bush hog with my New Holland 1720 that is rated @ 23.5 pto hp...
    The 5 hp per foot rule is IMHO right on the money but you can get by with 4...
  10. #10
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,029
    Central Ohio
    Kubota MX5100
    Just depends on how slow you want to go. If you want to crawl along in lowest possible gear, you can do fine with MUCH less than 5hp per ft.
    I have seen people use 6' cutters behind old wore out N-series fords that probabally only mustered 20-21 PTO power. (they were 23 when new and fresh). So that is just a tad over 3hp per ft.
    Using that ratio, 13-14hp would equate to about the same.
    Curious why you are asking though? do you have a particular tractor in mind? Or just shopping?
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
Similar Threads
  1. Replies: 5
    Last Post: 09-12-2014, 07:31 PM
  2. "Brush Hog" Mower price
    By Wyobuckaroo in forum Attachments
    Last Post: 09-06-2012, 08:44 AM
  3. How much PTO hp needed for 66" 2 stage blower?
    By Mechanos in forum Attachments
    Last Post: 01-05-2012, 02:28 PM
  4. brush / wood chipper 6" 3 pt PTO near W MI
    By Cinco in forum Wanted Ads
    Last Post: 04-01-2010, 01:23 PM
  5. Craftsman 42" Mower deck part needed
    By Keppie in forum Craftsman / Sears
    Last Post: 04-02-2009, 01:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
