Results 1 to 6 of 6
  1. #1
    Member
    Join Date
    Feb 2012
    Posts
    36
    Kalama wa
    Kioti DS 4110
    Default Best way to remove subframe backhoe
    Hi I have a Kioti DS4110 with a Kioti KB2475 backhoe.. I seldom take it off, but when I do I am wondering if there any tips to make it easier to put back on. I am getting better at it but always seem to have trouble getting the hyrodraulic lines reattached. And takes a while to get everything lined up. I know there must be good tips out there. THanks
  2. #2
    Silver Member roman's Avatar
    Join Date
    Apr 2010
    Posts
    136
    New Hampshire (live free or die)
    Ford 1720
    Default Re: Best way to remove subframe backhoe
    Block up the hoe frame on a flat surface using the downriggers and hoe to distribute the unit evenly. Make sure the mounting points are stress free. I use the hoe to power down the front mounting point so after the hydro lines are disconected the tractor drives away from the hoe.
    I don't have an issue with connecting the lines. If you mean they have pressure behind the ball, just wrap the male end in a clean rag and tap with a hammer.
    Ford 1720, Sims cab, FEL, Woods subframe backhoe, Fisher 7' hydro angle plow, Wallenstein 3 pth splitter, 5' blade, 3 pth carry-all, 3 pth ballast
  3. #3
    Join Date
    Feb 2011
    Posts
    163
    Outside of Detroit, MI
    DK50SE Cab
    Quote Originally Posted by Kioti Lee View Post
    First and foremost....take it off on the most level ground you can....including the ground in front of the tractor. That alone will make putting it back on much easier. Get your hoe in a 3-point stance (do I hear snickering out there??) and as stated above, get the weight off the rear mounting bracket. If you have it right, you'll be able to drive the tractor forward w/o dragging the hoe more than a couple inches. After you have it off the tractor but before you unhook the hydro lines, turn the tractor off and then work the controls of the backhoe until it is resting on the ground and all the pressure is out off all the lines. This will make putting the lines back on the tractor much, much easier.
  4. #4
    Platinum Member rimshot's Avatar
    Join Date
    Jan 2008
    Posts
    576
    Michigan
    Kioti CK20 (S) HST
    I usually place my backhoe in my pole barn when I take it off and it is placed on a concrete floor. I place the hoe on furniture dollies so when I load it back on the tractor I can actually roll the frame and hoe precisely beneath the tractor in proper alignment. As soon as I back over subframe close enough to hook up hoses for hydraulic I block the outrigger pads and bucket and boom transferring weight to pads on outrigger and bucket. I do this because I want the frame to stay put and not roll dollies because the wheels are very small. Those dollies come from Lowes or Home Depot and cost about $20.00 each. They are rated at 1000 lbs each and I sheet them up on top with a piece of 3/4 plywood or hardwood lumber. It is best to place the dollies beneath outrigger hinge pin next to frame so it does not settle over time. An alternative is to use something like 3/8's plywood as wheel blocks to retard rolling the hoe away on the dollies from an attachment so unit can be pinned in final position. Works for me but practise makes perfect.
    rimshot
    Attached Thumbnails Attached Thumbnails Best way to remove subframe backhoe-backhoe-storage3-medium-.jpg   Best way to remove subframe backhoe-backhoe-storage2-medium-.jpg   Best way to remove subframe backhoe-backhoe-storage4-medium-.jpg
    CK20(s) HST , snow blower, hoe, FEL
  5. #5
    Member
    Join Date
    Feb 2012
    Posts
    36
    Kalama wa
    Kioti DS 4110
    Thanks will keep this advice in mind..Rimshot love your setup, would be very handing for rolling out of way. Sadly i do not yet have that nice a building.
  6. #6
    Join Date
    Jan 2012
    Posts
    753
    Ma
    Kubota b2920
    I also use a dolly for my Kubota and have build instructions posted (search for bh65 dolly). I imagine you could do something similar. It makes it MUCH easier to put on and take off since theres no positioning, just roll up, hook hydro lines push it into place and do the rest with the boom.
Similar Threads
  1. SUBFRAME-BACKHOE
    By Binderman in forum Private Party Ads
    Last Post: 06-16-2011, 09:35 AM
  2. Remove/install snowblower subframe on x728
    By dannyk in forum John Deere Lawn & Garden
    Last Post: 04-12-2011, 05:52 PM
  3. Backhoe Backhoe subframe and backhoe not attached together?
    By Calvin in forum Attachments
    Last Post: 01-11-2009, 11:01 AM
  4. Backhoe ? 3 PT Backhoe Subframe
    By Lasgambler in forum Attachments
    Last Post: 07-15-2007, 04:32 PM
  5. Backhoe Subframe Help
    By okgat in forum Build-It Yourself
    Last Post: 03-24-2007, 12:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
