Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Jul 2012
    Posts
    3
    Spicewood, TX
    Kubota SU 3700
    Default adjusting 3-point hitch on Kubota
    What does everyone use to turn the adjustable rod assembly to let one side down lower than the other?
    I had been using the hole on the end of a crescent wrench, but I have worn down the points on the assembly so that this no longer works. I was thinking a short, thick-walled, small diameter pipe.
    Thanks
  2. #2
    Join Date
    Feb 2012
    Posts
    67
    Newport ME
    Kubota BX 2660 Kubota MX 5100
    Default Re: adjusting 3-point hitch on Kubota
    Grease up the threads and you should be able to turn it by hand.
    SARCASM: Just another service I have to offer!
  3. #3
    New Member
    Join Date
    Jul 2012
    Posts
    3
    Spicewood, TX
    Kubota SU 3700
    Will that work even with a box blade attached?
  4. #4
    Platinum Member troutsqueezer's Avatar
    Join Date
    Sep 2010
    Posts
    613
    Pilot Hill, CA.
    Kubota B21
    Absolutely. But the BB needs to be setting on the ground (no weight on the arms) or maybe setting on a rock (one side) if you want to angle it. I have no problem turning mine. Make sure the threads are good and maybe a little WD-40 would facilitate.
    - Dennis
    - B21
    Once you see the bandwagon, it's too late.
  5. #5
    Gold Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    352
    Deep in the Heart of Dixie- Central Alabama and the Mississippi Delta
    2003 Mahindra 3510
    You can also take the arm apart and clean the threads on everything, grease well and re-assemble. sometimes there are small pieces of metal from the manufacturing process.
    PROUD AIR FORCE DAD
  6. #6
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    5,897
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    If you want it real easy, you could spend a few dollars and install a hydraulic side link. Then you can make all those adjustments without stopping the tractor an getting on & off the tractor so much.
    Attached Thumbnails Attached Thumbnails adjusting 3-point hitch on Kubota-img_0274.jpg
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  7. #7
    Member
    Join Date
    Nov 2012
    Posts
    48
    Parrottsville TN
    Kubota
    I have mine set up so that it can only be turned by hand.
  8. #8
    LD1
    LD1 is online now
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,484
    Central Ohio
    Kubota l3400
    Its not a good idea to turn or try to turn it with a load on it. It will wear out the threads MUCH faster. Lower the BB to the ground to make your adjustments. If you want one side higher than the other, but a block of wood or something under it and set it down and make the adjustment. I have never needed any tools to adjust mine. Always by hand, but sometimes takes playing with the 3PH raising or lowering to take weight off.
    Same goes for the TL. MUCH easier to do without a load on it.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  9. #9
    New Member
    Join Date
    Jul 2012
    Posts
    3
    Spicewood, TX
    Kubota SU 3700
    Thanks
Similar Threads
  1. Box Scraper Adjusting Three Point Hitch for new Box Blade
    By kvmapr in forum Attachments
    Last Post: 07-26-2012, 09:29 PM
  2. Adjusting the height of a 3-point hitch snowblower
    By check in forum Kubota Owning/Operating
    Last Post: 03-08-2012, 10:04 AM
  3. help adjusting 3 point hitch lever
    By spoon059 in forum Kubota Owning/Operating
    Last Post: 12-24-2007, 10:09 AM
  4. 3-Point Hitch Used adjusting straps for 3 point hitch
    By browncountyoh in forum John Deere Owning/Operating
    Last Post: 12-13-2004, 11:50 PM
  5. 3-Point Hitch 3-point Hitch BX Series Kubota
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 07-10-2000, 07:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
