Page 2 of 8 FirstFirst 12345 ... LastLast
Results 11 to 20 of 78
  1. #11
    Veteran Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    1,947
    Northern CA
    Default Re: Broken zerk -- can't get it out
    I have found the tapered square ones to be the best design for lightly seating in the existing Zerk hole and then twisting it counter-clockwise with a tap handle or a very small adjustable wrench. The ones that look like a very coarse reversed screw thread seem to slip more than the square type.
    Here is an example:
    Craftsman 5 pc. Screw Extractor Set - Tools - Hand Tools - Tap & Dies & Sets
    If you have a tractor then the chances are 95% that you have broken off a Zerk. Keep that EZ-Out with your Zerks for future use.
    The remaining 5% never have greased or are outright liars.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  2. #12
    Join Date
    Jul 2012
    Posts
    58
    Goochland, Va
    Bobcat 773
    I had a ruined grease point on my skid steer at the top joint of one of the loader arms and needed to work. I pulled the pin and packed it with grease then replaced the pin. A little bit of work - but good enough to get a day's work done.
  3. #13
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    I use the square ones but like the screw ones better. The force to hammer the square ones in can distort the remaining bit in the hole and make it harder to get out. I also like to use left hand drill bits the friction, vibration and left rotation frequently gets the left over nubbin out pretty easy.
  4. #14
    Super Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    7,728
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by gwdixon View Post
    Here is an example:
    Or are just very careful or very lucky? Have owned tractors and implements for over 20 years, grease on schedule, and have never broken a Zerk. I know I know, my time is coming.
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. Home-Brew 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. Satisfied Everlast PA160 welder owner
  5. #15
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    Quote Originally Posted by k0ua View Post
    James K0UA
    Him lucky? You sound like the lucky one! 20 years and no broken zerks... sheesh! I break at least a couple every year. Mostly on the back hoes though.
  6. #16
    Silver Member BuilderML's Avatar
    Join Date
    Nov 2012
    Posts
    199
    Tolland, CT
    CCY SX3100
    Ez out should work, if not just drill and tap for a new zerk. I would spray some PB and let that set for awhile before trying the ez out. Good luck!!
  7. #17
    Bronze Member Phil48's Avatar
    Join Date
    Mar 2012
    Posts
    70
    Eastern TownShip
    CK20 HST
    Broken zerk -- can't get it out-ya769.jpgBeing part of the 95 % pack, I really like those:
    Snap-on
    Phil
  8. #18
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I think I would drill out the zerk hole a bit first so that I could use the largest EZ out that I could. NOTHING worse than a broken EZ out as they are next to impossible to drill out. Dont put too much pressure on it when attempting to remove the zerk. If it doesnt come out easily, drill out the hole, retap to a larger sized zerk. Dont risk breaking off the EZ out in the zerk.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  9. #19
    Gold Member ddb123's Avatar
    Join Date
    Oct 2011
    Posts
    374
    Southwest MO
    Kubota L3540
    Default
    Okay, another question. How tight should the zerk be? I found a couple loose ones on my tractor. I just snugged them up.
    Kubota L3540 HST
    Kubota L4300 Gear *gone!*
    Ford F-350 6.9L diesel
  10. #20
    Join Date
    Jul 2009
    Posts
    1,947
    Northern CA
    Quote Originally Posted by ddb123 View Post
    Zerks are usually made from a softer metal I think. That way if the Zerk comes out whole, which has happened to me, then the Zerk threads are destroyed rather than the base metal (socket) threads.
    That softness may also be the cause of them breaking off seemingly so easily. Not really such a bad thing.
    So they should be tight but not too tight. Snug, as you state, is a good description. You don't want to bung up or strip those tiny threads.
    Usually there is grease on the threads so, just by use, they will eventually work loose and break more easily because sheer forces can be applied to the threaded shaft rather than be supported by the nut-like shoulder. Lock-Tite is NOT recommended.
Similar Threads
  1. ARGH! Broken zerk grease fitting for L3940 HARD TO FIND
    By beppington in forum Kubota Owning/Operating
    Last Post: 02-02-2011, 04:39 PM
  2. replacing a broken grease zerk
    By rimshot in forum Parts/Repairs
    Last Post: 08-02-2010, 09:58 PM
  3. Broken Zerk!
    By Doc_Bob in forum Parts/Repairs
    Last Post: 05-06-2008, 04:08 PM
  4. the zerk that won't
    By frigman in forum Chinese Tractors
    Last Post: 02-12-2007, 09:23 PM
  5. Help! Broken Grease Zerk in FEL
    By BoneheadNW in forum Kubota Owning/Operating
    Last Post: 06-29-2005, 01:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
