Re: Tractor making me sick?
Could it be sun stroke. I got that once when baling hay. Needed a good cold drink and some shade and I was good.
Do you have a cab? Does it have a cabin air filter? Maybe something in that?
1 Attachment(s)
It's an enclosed cab....
Attachment 291704
Quote:
Originally Posted by
QwikDraw
Perhaps mold or something in the HVAC?
Does it have a cab... could it be carbon monoxide poisoning.
Buckgnarly
Buckgnarly
These two things are what jumped to my mind. I would clean the air filtration system out, spray a STRONG bleach solution in the duct work, let it set and dry then spray it again and hose it out, then repeat if it was still dirty. But I have a deep "respect" for the power of molds -- they are bad bad ju-ju. Bleach them dead! If there is an AC system, I'd also pay attention to the condenser and stuff.
Could be mice or rats in the system too.
john_bud
John_bud, I did a quick search on the net and that tractor has a cabin filter. If moisture is getting into the air system there could very well be mold. Yes it is indeed bad juju. The mold doesn't have to be on the filter but in the ducts. I think you hit it square. I've seen mold on an AC condensers that the drain was partially clogged was the cause of it.
Thanks guys. I'll check it out. yes it does have AC and cabin filters...and I did see a little mold on the roof. It also has some water stains on the fabric on the roof so I may have had a door not fully closed that allowed some water in. I hope this is the problem.
It's no fun to be scared to get in your tractor!
